Heated enclosure - What kind of heaters and power? December 03, 2015 09:08AM |
Re: Heated enclosure - What kind of heaters and power? December 03, 2015 09:25AM |
Re: Heated enclosure - What kind of heaters and power? December 03, 2015 05:32PM |
Re: Heated enclosure - What kind of heaters and power? December 04, 2015 07:25AM |
Re: Heated enclosure - What kind of heaters and power? December 04, 2015 07:59AM |
Re: Heated enclosure - What kind of heaters and power? December 08, 2015 08:48AM |
Re: Heated enclosure - What kind of heaters and power? December 08, 2015 09:18AM |
pen25
i am taking it you want radiant heat to prevent any air currents or at least reduce it. remember heat rises so you can probably get an electric space heater that has the nichrome wire. take an aluminum plate and mount the nichrome on the bottom. use a thermister and relay to turn the heat plate on and off. 1500 watts should be plenty as it will heat a 10'x10' room to 80*f with no problem. if you can take that aluminum plate and create ridges in it like a sink it will give more surface area allowing it to dissipate more heat and allow it to heat faster.
Re: Heated enclosure - What kind of heaters and power? December 08, 2015 09:39AM |
Re: Heated enclosure - What kind of heaters and power? December 08, 2015 12:40PM |
Re: Heated enclosure - What kind of heaters and power? December 08, 2015 06:04PM |
Re: Heated enclosure - What kind of heaters and power? December 08, 2015 07:17PM |
LarsK
pen25
Yes that is a good idea. Só what you are saing is that i can harvest the wire from a Space heater? Hmm, how about a hairdrier? Is that the same thing?
I think if I can get the wire I will wrap it in on a 30x30 extrusion that I can then suspend inside the printer. I think that will look nice and have a lot of area.
Re: Heated enclosure - What kind of heaters and power? December 08, 2015 07:18PM |
patrickrio
yes, differential inside an object versus outside could be a problem. I think you would use higher chamber temperatures with convection though, since it can be quite accurate. I think your goal with Forced Convection Heating would be to try to keep an object JUST structurally sound enough to support the layers above without sloughing or bending due to weight or extruder forces. You might then SLOWLY drop the chamber temp once done to give the whole object time to cool uniformly.
Re: Heated enclosure - What kind of heaters and power? December 09, 2015 07:21AM |
Re: Heated enclosure - What kind of heaters and power? December 09, 2015 08:28AM |
Re: Heated enclosure - What kind of heaters and power? December 09, 2015 10:50AM |
the_digital_dentist
The Stratasys machine that the two heaters came from had two 5.25" fans blowing air over them, so I don't think that a little air movement inside is going to cause any print problems. I wouldn't direct the air flow at the print, but in a closed box the air is going to move if there's a fan. It doesn't seem to hurt Stratasys any...
Re: Heated enclosure - What kind of heaters and power? December 09, 2015 12:57PM |
Re: Heated enclosure - What kind of heaters and power? December 09, 2015 02:47PM |
Re: Heated enclosure - What kind of heaters and power? December 09, 2015 03:30PM |
Re: Heated enclosure - What kind of heaters and power? December 09, 2015 04:11PM |
LarsK
Maybe I got it wrong - It is my understanding that the wire temperature calculated is what I would get if suspended in air (?). The heat-transfer should be magnitudes higher in the oil.
Re: Heated enclosure - What kind of heaters and power? December 09, 2015 04:47PM |
Re: Heated enclosure - What kind of heaters and power? December 09, 2015 05:23PM |
the_digital_dentist
LarsK
Even if that is the free-air temperature and the heat transfer to oil is very rapid, I would be concerned about anything that gets hot enough to boil/burn the oil. You don't have to run the wire that hot- you only need the enclosure to get to 50-70C- I'd check the boiling point of the oil and try to size the wire to stay below that temperature. That should give you plenty of margin to heat the system up quickly without having to worry about an explosion that throws burning or boiling oil all over anyone standing nearby.
I think you'd be better off buying a second-hand toaster, pulling the heaters out, and running them under PID control with a small fan blowing over them.
Re: Heated enclosure - What kind of heaters and power? December 10, 2015 09:17AM |
Re: Heated enclosure - What kind of heaters and power? December 10, 2015 01:37PM |
Re: Heated enclosure - What kind of heaters and power? December 10, 2015 02:06PM |
Re: Heated enclosure - What kind of heaters and power? December 10, 2015 04:03PM |
patrickrio
When I think about it, the cheapest small heating devices that are everywhere in Brazil are hair blow dryers and electric hair straighteners. As I remember from my time there, every single woman has a box full of this equipment and probably has an old one lying around somewhere. I bet one of those "low frizz" hair dryers would be great because you could have several lower heat level settings and several lower fan settings, all in a very small package. You could locate the whole setup easily in your design because it is small.
Then all you need is a Solid State Relay and a PID connection from your controller.
Fala com a mulherada da casa... provivelmente voce ja tem quasi tudo que voce preciso.
Re: Heated enclosure - What kind of heaters and power? December 10, 2015 05:00PM |
Admin Registered: 16 years ago Posts: 13,874 |
Re: Heated enclosure - What kind of heaters and power? December 10, 2015 07:44PM |
VDX
... when I was a child I've used heater wires out from old flat-irons - a long wire, embedded in ceramic beads ...
My father used glass tubes filled with quicksilver in the '70er years to conduct heat ...
My last 'non-air' transfer-heater was filled with Galinstan (a pretty expensive, but less toxic replacement for quicksilver) - boils at >1300 degC ...
But you can try with simply waterglass too, if the containment is airtight enough, so the water won't exit over time ... otherwise the residue will solidify to silicate ...
Re: Heated enclosure - What kind of heaters and power? December 10, 2015 08:15PM |
Re: Heated enclosure - What kind of heaters and power? December 10, 2015 11:25PM |
Re: Heated enclosure - What kind of heaters and power? December 11, 2015 03:38AM |
