Is it possible to deport motors far from work zone March 02, 2016 05:59PM |
Re: Is it possible to deport motors far from work zone March 03, 2016 04:23AM |
Admin Registered: 16 years ago Posts: 13,874 |
Anonymous User
Re: Is it possible to deport motors far from work zone March 03, 2016 08:21AM |
VDX
... you'll only get more elasticity from the longer belts.
For shielding against EM you can use iron sheets (better Mu-metal) for a housing ... but don't forget to shield all your cables too ...
Re: Is it possible to deport motors far from work zone March 04, 2016 11:52AM |
Re: Is it possible to deport motors far from work zone March 04, 2016 01:31PM |
Re: Is it possible to deport motors far from work zone March 04, 2016 02:17PM |
Re: Is it possible to deport motors far from work zone March 04, 2016 04:49PM |
Re: Is it possible to deport motors far from work zone March 04, 2016 05:44PM |
grat
If you put a stacked pulley where the motors normally would be, then you could relocate the motors farther away, and use a single closed loop belt from each motor to drive the stacked pulley.
Or, thinking three dimensionally, you could relocate the motors to *under* the box, and drive the pulley(s) from a rod attached to the motor(s).
dc42
Can you move the head to where you want to read the field, then turn the motor current off while you read it? That would eliminate the magnetic fields generated by the coils and cables, leaving just the permanent magnet rotors of the motors to interfere with the reading.
