Foldable, portable CoreXY (Fusebox derivative) March 14, 2016 07:34PM |
Re: Foldable, portable CoreXY (Fusebox derivative) March 14, 2016 07:53PM |
Re: Foldable, portable CoreXY (Fusebox derivative) March 15, 2016 06:06AM |
same as the fusebox - 200x200. i chose that design to copy because of its low cost, clear BOM, and that it used primarily 3d-printed parts. the disadvantage (not really - more like a surprise) is that the empty space surrounding the bed is, for a corexy printer, really really large. i keep looking at it and i keep wondering how it would be possible to rearrange the motors and parts to lose at least 50mm on the left and right sides.Quote
Edvardas
How big is the printbed?
Re: Foldable, portable CoreXY (Fusebox derivative) March 15, 2016 08:24AM |
Re: Foldable, portable CoreXY (Fusebox derivative) March 15, 2016 09:37AM |
the_digital_dentist
A few dumb questions:
the_digital_dentist
Is your folded version any more portable than the printer you started with?
the_digital_dentist
What is the target for portability- fitting into a car, on an airplane, shipping in a box, carrying in a backpack?
the_digital_dentist
How do you guarantee that the XY plane is orthogonal to the Z axis when the printer is reassembled?
the_digital_dentist
Where are the electronics?
Re: Foldable, portable CoreXY (Fusebox derivative) March 15, 2016 10:45AM |
Re: Foldable, portable CoreXY (Fusebox derivative) March 15, 2016 03:07PM |
Re: Foldable, portable CoreXY (Fusebox derivative) March 15, 2016 05:19PM |
i definitely, definitely need a full 200x200 range. the reason is because i am printing parts for the EOMA68 15.6in Libre Eco-Laptop that i'm developing, and the longest parts are 230mm x 16mm x 12mm. the diagonal of a 200x200 is 280(ish) mm. so, i'm targetting a full 200x200mm range. height is no big deal for me, so i'll be happy if i get 150mm height. it should be way more than that using 280mm screw-rods.Quote
Edvardas
Do you need 200mm of printbed space on Y plane?
ok, here's a picture (below) which shows the current rearrangement, mostly i've focussed today on the top CoreXY parts. everything's lifted up by a huge 40mm margin so that the rods sit on *top* of the Misumi1515 extrusion. what that's allowed is the entire y-assembly to fit just underneath the front idlers, the motors and the idlers themselves have moved inwards by 15mm, and i've rearranged the position of the GT2 rollers themselves to be further over... all that has resulted in the width dropping by almost *60mm*.Quote
I would guess that you could make a printer with a 200mm wide frame in Y plane that has around 150mm of usable printbed space. Relocating the motors like on this printer would give some extra space [forums.reprap.org]
Have you considered the airport security's reaction about you bringing a reprap printer as a carry-on?
Re: Foldable, portable CoreXY (Fusebox derivative) March 15, 2016 05:34PM |
cool. well, when i'm confident with each assembly i'll let you know, i'll be buying bits very soon, i am on a rather tight deadline.Quote
FA-MAS
I'm interested in something like this.
yeah my brother got a laptop - a large one - for exactly the same reason: they fold it away and put it into the bookcase.Quote
Though my reasons would be easy storage rather than travel. I'll be moving into a very small place and there won't be room to have a printer out permanently.
correct. there will be some hinge arrangements (split hinges like you get for removable doors) on the diagonals of each box half, you'd just slot them together. i haven't quite thought yet how to make sure the two halves stick together conveniently whilst also not impinging on the outer dimensions.... have to think about that a bit more...Quote
One of the criteria would also be ease of unpacking. It would look to me like your design would require to take one of the triangular frames, detach it and flip it around for stowing.
i covered the rigidity in the post to digital_dentist (above) - i want to keep the number of wing-nuts to a minimum so that they're not lost. upright posts (probably M4 or M5 part-threaded bolts), which there will be corresponding lockins that can be dropped down onto them... quite straightforward. what i might do is have the lockins be "slotted" so that you don't actually have to take the wing nut completely off... yeah it's quite straightforward really.Quote
I'd also be curious how you'll attach the extrusion to one another at those sharp angles and ensure it's rigid.
well, feel free to make this one and/or help out if it's important to you, the git clone url is at the top of the thread, you'll need python2 and openscad. i'm planning to put the BOM (descriptions, urls) in the python program and have it be auto-generated - including QTY and yes that includes nuts and bolts.Quote
I'll say that I've had multiple designs rolling around in my head, from Cartesian to Delta to Core XY, and I like the idea of a folding Core XY
Re: Foldable, portable CoreXY (Fusebox derivative) March 15, 2016 06:21PM |
Re: Foldable, portable CoreXY (Fusebox derivative) March 15, 2016 07:56PM |
i liked this idea! so i thought about it seriously, here's what i thought would be problems:Quote
FA-MAS
How about placing the Z axis assembly on one of the squares of your support structure (lets say blue assembly)...
[snip]
actually, turns out, using cardboard models, you just need a hinge not a hard, solid clamp, so i plan to use something like those two-piece door hinges. the critical thing is, for that to work (hinges instead of hard-clamped attachment), all other 5 sides must *not* have any kind of shear, i.e. must be corner-braced, diagonally-braced or simply filled entirely with plywood / polycarb.Quote
all you'd have to do is develop a solid way of clamping where the blue and purple pieces meet at the bottom together.
Re: Foldable, portable CoreXY (Fusebox derivative) March 21, 2016 07:00PM |
Re: Foldable, portable CoreXY (Fusebox derivative) March 22, 2016 07:38AM |
Re: Foldable, portable CoreXY (Fusebox derivative) March 22, 2016 09:06PM |
FA-MAS
How about placing the Z axis assembly on one of the squares of your support structure (lets say blue assembly), then you could eliminate the need for those extra extrusions to support it on it's own and also not have to worry about how you're going to attach/detach it when you're setting up/tearing down.
Re: Foldable, portable CoreXY (Fusebox derivative) March 23, 2016 03:08PM |
Re: Foldable, portable CoreXY (Fusebox derivative) March 23, 2016 07:14PM |
FA-MAS
The pictures are pretty much how I envisioned it'd work and I like the way the casing would work.
I was also thinking about the collapsible print bed. I might suggest having it fold the opposite way from what you're planning. Reasoning being is that it's already cantilevered, and the bed itself and any weight put on end further from the rods may cause it to sag.
You'll want to be resisting it to sag rather than hinging it that direction, and even though not intentional, providing it further potential to sag that direction. I'm thinking there may be a less complicated, and potentially less room for error design. I might suggest looking into a design that folds the bed upward, that way when it's deployed, it folds down and hits a hard stop designed into the bed mount, maybe even adjustable to allow compensation for any potential sag.
Think of it like this, if you unfold to 90 degrees, the weight of the bed alone may push that to 92 degrees. If you say allow it to adjust to only go to 88 degrees, and the weight of the bed still takes it another 2 degrees, then you're at 90.
I'll see if I can model it up.
Re: Foldable, portable CoreXY (Fusebox derivative) March 23, 2016 07:37PM |
FA-MAS
I might suggest looking into a design that folds the bed upward.
Re: Foldable, portable CoreXY (Fusebox derivative) March 24, 2016 01:28PM |
Re: Foldable, portable CoreXY (Fusebox derivative) March 26, 2016 09:37AM |
Re: Foldable, portable CoreXY (Fusebox derivative) March 26, 2016 10:13AM |
Re: Foldable, portable CoreXY (Fusebox derivative) March 27, 2016 08:56PM |
Re: Foldable, portable CoreXY (Fusebox derivative) March 28, 2016 05:28PM |
Re: Foldable, portable CoreXY (Fusebox derivative) March 31, 2016 12:46PM |
First print on the Sandwich200 April 04, 2016 06:59AM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 04, 2016 07:05AM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 04, 2016 01:19PM |
Edvardas
What do you mean by an "extrusion rate of 200mm/s"?
Re: Foldable, portable CoreXY (Fusebox derivative) April 04, 2016 02:51PM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 04, 2016 03:22PM |
Edvardas
Do you notice any under-extrusion while accelerating or over-extrusion on deceleration?
I have noticed that this is a problem if I come close to extruding 10mm3 of plastic per second (which is widely considered the maximum). And with my 0.6mm nozzle and 0.3mm layer height that is already a very low 50mm/s maximum printing speed. Moving at 30mm/s gives great results and that is 6mm3 of plastic extruded per second but such a low speed is quite a shame for corexy printer.
Now I see why 0.4mm is such a popular nozzle.
Another solution would be a volcano nozzle from e3d. Now they have 0.4mm nozzles. Volcano should more than double the volume of plastic that could be extruded.
Re: Foldable, portable CoreXY (Fusebox derivative) April 04, 2016 04:45PM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 05, 2016 06:30PM |
FA-MAS
Sounds like you're close to getting it running. I'd like to see its first prints.
Also roughly how much Z travel do you estimate? It looks like the hinge system may take quite a bit.
