Re: Foldable, portable CoreXY (Fusebox derivative) April 06, 2016 01:45AM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 06, 2016 09:26PM |
pen25
looks good. congrats on getting this to work.
how well does it maintain print calibration when you fold it move it and set it back up to print?
i just had to take the box apart and the z-assembly today, to fit new attachments. i fixed two issues: first, the wing nuts kept jamming against plastic and metal, so i've turned them round and/or moved them away from screws, extrusion and other parts. second, those metal corners i found on ebay are enormous: 50mm on the square-sides, which is good for structural bracing but bad for space. i've had to redesign the attachments to take the corner-braces into account. so it'll be a total recalibration after reassembly anyway.
took a while to explain, but if i don't put the groundwork in place and try the assemble-calibrate-disassemble-move-assemble test with things as they are, it's a guaranteed "ehhmm.... no". honestly though i would be quite happy to recalibrate on every setup, as i would consider it to be just "good engineering practice" to double-check precision equipment regularly. so it's not been a design goal to require "no calibration" between setups.|
Re: Foldable, portable CoreXY (Fusebox derivative) April 07, 2016 01:26PM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 07, 2016 07:06PM |
FA-MAS
Sounds like is coming along. Pretty good for a first print. The bridge came out good.
While the corner cubes sound like they'd help, It's been proven they reduce rigidity over connecting the extrusions directly to each other, but rather add extra parts (however insignificant). Connecting them directly like this would be more rigid Dentist's Post on connecting Extrusion. and require less parts and cost less.
never occurred to me to drill a hole in the extrusion so that you could tighten up a hex-bolt. niiice.Quote
I'm sure you're aware either situation will require really precise cutting of the extrusion.
Which is why it's recommended to cut and then mill the ends square. Non square cuts will make it go out of square. I know you were using an Angle Grinder at the end and it's probably fairly difficult to get square cuts, and looks unsafe.
Not having a Mill myself, or a Chop Saw and not wanting to blow the budget buying either, I'd get a Miter Box like this one here and screw it to a workbench. I'd use a couple of Clamps to hold down the extrusion against one of the rails and cut it with a Hacksaw. Lastly check with a Carpenter's Square like this one here and file it.
I'd make every attempt to make those cuts square cause depending on how out of square the extrusion end cuts are, you may end up with portions that don't touch the corner cube or the other extrusion (if going without corner cubes)
Looking forward to more progress
anyway, those guitar-case clasps, despite being off of ebay, fit perfectly. i've got the hook-parts turned through 90 degrees, i'll cut a hole for them in the hardboard: likewise for the spring-loaded clip. maybe not... maybe put that on top of the hardboard.... the nice thing about the clasps, is, they actually overlap the bars, creating a nice way to keep the two halves in alignment (they don't slip in other words). if i put them on top of the hardboard, instead of direct on the frame, they won't overlap on the frame... but ah ha! they'd overlap on the hardboard, so that would be ok.|
Re: Foldable, portable CoreXY (Fusebox derivative) April 08, 2016 07:21AM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 08, 2016 06:03PM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 08, 2016 10:45PM |
FA-MAS
That's looking from the top down when it's in deployed setup?
Re: Foldable, portable CoreXY (Fusebox derivative) April 09, 2016 08:06AM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 10, 2016 06:55AM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 10, 2016 07:27AM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 10, 2016 05:48PM |
Edvardas
What kind of nozzle are you using?
28mm3/s is something that only a Volcano should be capable of melting. Usual nozzles have around 10mm long melt chamber
.Quote
And 3mm is not really efficient at high volume melting because it has a lot bigger cross section than 1.75mm (filament needs to be melted right to the center)
I am not sure about the size of those prints but 350mm/s is something that requires a long distance to reach unless you are using a very high acceleration. I doubt that you are really reaching that speed anywhere on the prints. Oh and even Marlin has a maximum speed of 300mm/s set for X-Y so I hope that is changed.
Re: Foldable, portable CoreXY (Fusebox derivative) April 10, 2016 05:52PM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 11, 2016 04:59AM |
Edvardas
And 3mm is not really efficient at high volume melting because it has a lot bigger cross section than 1.75mm (filament needs to be melted right to the center).
Re: Foldable, portable CoreXY (Fusebox derivative) April 11, 2016 06:23AM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 12, 2016 11:29AM |
ok that does it, i'm going to get a volcano adapter set.
Re: Foldable, portable CoreXY (Fusebox derivative) April 12, 2016 10:05PM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 15, 2016 06:02AM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 17, 2016 04:59AM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 17, 2016 06:59AM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 17, 2016 12:13PM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 17, 2016 05:46PM |
Edvardas
Looks like you have got a so called Z-banding issue. It is caused by an M8 threaded rod that is not straight. Pitch on M8 rod is 1.25mm and it looks like the repeating banding happens at this distance which proves it all.
i should probably try a lead screw. harumph. FA-MAS thanks for the reference to that z-axis decoupling idea. i'm puzzled because there is 70mm between the z-nut and the z-rods, which is an awful long way. mind you, i can clearly see the threaded bar going round off-centre by a good mm or so... so it's deefinitely not straight
Re: Foldable, portable CoreXY (Fusebox derivative) April 18, 2016 10:44AM |
lkcl
oo! oo! i want one!ok that does it, i'm going to get a volcano adapter set.
in a couple of places it's clear that the filament skipped a beat, and then took like... 20mm to settle down again.
Re: Foldable, portable CoreXY (Fusebox derivative) April 21, 2016 04:57PM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 24, 2016 11:55AM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 26, 2016 06:37AM |
this is an experiment (right and centre) to do a rotating z-nut idea based on a sphere. there's a concave spherical indentation in which the actual nut-holder can rotate. the "beetle" part has two protrusions that fit into a slot, which stops it from rotating when the threaded bar turns. however, in order to be effective, the level of those protrusions has to be dead-centre with the middle of the nut, meaning that the sphere has to be quite a large diameter... it just got all too complicated and i decided to go with a straight nut-holder.|
Re: Foldable, portable CoreXY (Fusebox derivative) April 27, 2016 01:17PM |
i am surprised however that the LM12UU bearings tend to "judder" and jam quite significantly - a lot more than LM8UU and LM8LUU bearings.|
Re: Foldable, portable CoreXY (Fusebox derivative) April 27, 2016 01:43PM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 27, 2016 08:59PM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 28, 2016 09:37AM |
Re: Foldable, portable CoreXY (Fusebox derivative) April 28, 2016 04:56PM |
