Introducing "Unobtanium" March 23, 2016 07:21PM |
Re: Introducing "Unobtanium" March 24, 2016 05:02AM |
Re: Introducing "Unobtanium" March 24, 2016 05:29AM |
Re: Introducing "Unobtanium" March 24, 2016 05:35AM |
Re: Introducing "Unobtanium" March 24, 2016 11:01AM |
filipeCampos
One question: you are going with an enclosure, then why the little black panel at bottom and not go directly with the enclosure solution?
I see you have an E3D v6 to print abs too. It will be nice if you put a complete enclosure on top, you can go with the chain cable solution David was used.
Re: Introducing "Unobtanium" March 24, 2016 02:50PM |
Re: Introducing "Unobtanium" March 24, 2016 04:47PM |
Re: Introducing "Unobtanium" March 27, 2016 03:25PM |
Re: Introducing "Unobtanium" March 28, 2016 10:51AM |
Re: Introducing "Unobtanium" March 28, 2016 11:50AM |
Re: Introducing "Unobtanium" March 28, 2016 12:35PM |
Ok, now the stop make sense...Quote
Nosmo
The stops are when the Z-axis moves down one layer.
Nosmo
How much tension do the belts need? They are reasonably tight at the moment but I can still pull them about 10mm towards me at the point where the cross (mid-front), they are not so tight that you can use them as piano strings.
Re: Introducing "Unobtanium" March 28, 2016 03:25PM |
Re: Introducing "Unobtanium" March 29, 2016 05:41AM |
Re: Introducing "Unobtanium" March 29, 2016 03:29PM |
Nosmo
jaguarking11
What touchscreen is that? How does it interface with MKS-Base?
The screen is a 3.2" touchscreen from MKS. This is the Aliexpress link.
The screen is connected to the Aux1 connector of the controller.
Re: Introducing "Unobtanium" March 29, 2016 03:31PM |
filipeCampos
Cables guides, all cables with a perfect length. Very nice and clean... my cables of my printer are a mess in relation to yours.
two suggestions:
1) endstops: I prefer the endstop without red plastic wheel and metal. reasons: better precision and you can gain some mm in the axis.
2) Yours printed pieces that secure the belt are not in contact with the carriage and your are losing some mm in the X axis because of this. The bed is only 20cm and for now you do not need this extra mm, but it will be necessary if you decide in the future to change to a dual hotend.
Re: Introducing "Unobtanium" March 30, 2016 05:57PM |
Re: Introducing "Unobtanium" March 31, 2016 07:01AM |
Re: Introducing "Unobtanium" April 04, 2016 05:31PM |
Re: Introducing "Unobtanium" April 05, 2016 05:10AM |
Re: Introducing "Unobtanium" April 05, 2016 09:26AM |
Re: Introducing "Unobtanium" April 06, 2016 11:33AM |
Re: Introducing "Unobtanium" April 06, 2016 12:28PM |
Re: Introducing "Unobtanium" April 06, 2016 12:52PM |
Re: Introducing "Unobtanium" April 07, 2016 12:03PM |
Re: Introducing "Unobtanium" April 07, 2016 12:09PM |
Re: Introducing "Unobtanium" April 27, 2016 08:46AM |
Re: Introducing "Unobtanium" April 27, 2016 12:12PM |
Nosmo
Just a quick update,
Although the print quality wasn't bad at all I still wasn't happy with the reliability of the extruder, especially when using more than 2mm retraction or when using fast retraction. The extruder motor (and driver) couldn't handle the high torque and was causing the filament to get stuck inside the heatbreak.
The solution was to use a geared extruder so I bought the new E3D Titan. This little beasty can produce almost 5 times as much torque as the MK8. After upgrading to the Titan all my retraction issues have disappeared.
I also mounted the transparent side panels. I have used small (8mm) neodymium magnets to stick them to the frame. This makes it very easy to remove them for maintenance or easy access to the print bed.
I think that this project is finished, at least until I get infected with a bad case of upgraditis again.
Re: Introducing "Unobtanium" April 27, 2016 12:42PM |
Re: Introducing "Unobtanium" April 27, 2016 12:46PM |
Re: Introducing "Unobtanium" April 27, 2016 01:02PM |
