CoreXY sensitive to belt tension? April 02, 2016 07:14AM |
Re: CoreXY sensitive to belt tension? April 02, 2016 12:51PM |
Re: CoreXY sensitive to belt tension? April 02, 2016 02:22PM |
Re: CoreXY sensitive to belt tension? April 02, 2016 06:28PM |
Re: CoreXY sensitive to belt tension? April 02, 2016 06:37PM |
Re: CoreXY sensitive to belt tension? April 02, 2016 07:04PM |
Re: CoreXY sensitive to belt tension? April 04, 2016 09:58AM |
bani
[www.youtube.com]
it's claimed here that corexy is sensitive to belt tension compared to other designs.
anyone found this to be the case?
Re: CoreXY sensitive to belt tension? April 04, 2016 10:24AM |
bani
i am looking at designs here and on openbuilds. virtually 100% of them are bowden by design.
it looks like the only ones using direct drive are from people who got frustrated with the original bowden design and converted to direct drive afterwards.
Re: CoreXY sensitive to belt tension? April 07, 2016 10:44AM |
Re: CoreXY sensitive to belt tension? April 08, 2016 04:51AM |
Re: CoreXY sensitive to belt tension? April 08, 2016 05:17AM |
bani
so if corexy is not a high speed design, then why would anyone use it over ultimaker type design?
Re: CoreXY sensitive to belt tension? April 08, 2016 05:24AM |
Re: CoreXY sensitive to belt tension? April 08, 2016 05:39AM |
Re: CoreXY sensitive to belt tension? April 08, 2016 05:47AM |
Re: CoreXY sensitive to belt tension? April 09, 2016 10:16AM |
Re: CoreXY sensitive to belt tension? April 12, 2016 09:56PM |
Re: CoreXY sensitive to belt tension? April 14, 2016 03:28PM |
bani
Re: CoreXY sensitive to belt tension? April 14, 2016 03:31PM |
DjDemonD
It was a necessary compromise before flying extruders and flex3drives became available. Perhaps a rare earth magnet geared nema 11 extruder is light enough that we won't need bowden.
Re: CoreXY sensitive to belt tension? April 14, 2016 04:18PM |
Re: CoreXY sensitive to belt tension? April 14, 2016 07:18PM |
DjDemonD
There is no doubt that the best design is the delta - stationary bed, stationary motors, lightweight print head its got it all going on. But they're a pain to setup, they're more delicate and they're a bit limiting on x-y size (but great in z - not that its all that useful most of the time), with flying extruder you get nearly the whole package (you can enclose it then as well, as there's no bowden tube flapping around.
Re: CoreXY sensitive to belt tension? April 15, 2016 04:20AM |
Re: CoreXY sensitive to belt tension? April 15, 2016 06:38PM |
DjDemonD
[direct extruder recommendations on a delta printer] It's cheap and simple and it considerably improves the packaging of the delta printer.
The flex3drive is now on my corexy and its wonderful but its a more complicated and expensive piece of equipment. There are other limitations such as the flex drive itself cannot be cut to length or it loses its strength.
Re: CoreXY sensitive to belt tension? April 15, 2016 06:44PM |
the_digital_dentist
As I understand deltas, resolution varies depending on XY coordinates - the resolution is higher near the center of the bed and decreases as you move away from the center. .
Re: CoreXY sensitive to belt tension? April 16, 2016 12:34PM |
lkcl
the_digital_dentist
... and i'm printing 230mm-long parts where the aesthetics are important, and there are critical-accuracy ends that have to fit into other parts. some of the parts are printed upright, and others are at right-angles. even *assessing* whether the 230mm long parts would print out well on a delta printer and fit together well is a headache! so... Big No
