Which core XY should I build? April 04, 2016 09:49AM |
Re: Which core XY should I build? April 04, 2016 04:51PM |
Re: Which core XY should I build? April 04, 2016 05:26PM |
Re: Which core XY should I build? April 04, 2016 11:43PM |
cozmicray
If the Digital Dentist comes out with a design that would be great.
Re: Which core XY should I build? April 05, 2016 11:17AM |
Re: Which core XY should I build? April 05, 2016 12:08PM |
the_digital_dentist
I'm working on it...
Re: Which core XY should I build? April 05, 2016 01:40PM |
Re: Which core XY should I build? April 06, 2016 01:51AM |
Re: Which core XY should I build? April 06, 2016 06:53AM |
Re: Which core XY should I build? April 06, 2016 10:30AM |
Re: Which core XY should I build? April 06, 2016 11:50AM |
Re: Which core XY should I build? April 06, 2016 01:44PM |
Re: Which core XY should I build? April 07, 2016 04:11PM |
Re: Which core XY should I build? April 07, 2016 04:23PM |
Re: Which core XY should I build? April 08, 2016 06:55AM |
the_digital_dentist
XY assembly on a flat steel plate (?)
Re: Which core XY should I build? April 08, 2016 08:35AM |
Re: Which core XY should I build? April 08, 2016 12:01PM |
the_digital_dentist
If I use a piece of cast aluminum tooling plate for the XY mechanism base, the hole cut in the center of the plate may become the print bed plate and other parts, so material use will be relatively efficient. I can deal with the thermal expansion of the plate by adding a second bearing block to the X axis guide rail.
Re: Which core XY should I build? April 08, 2016 12:27PM |
Re: Which core XY should I build? April 08, 2016 12:29PM |
the_digital_dentist
Quality costs.
Re: Which core XY should I build? April 08, 2016 03:01PM |
Re: Which core XY should I build? April 08, 2016 03:55PM |
realthor
the_digital_dentist
This means that it will be doable only by guys with access to a machining shop to cut the plate for them right? You are talking something like this: [youtu.be] ...
Re: Which core XY should I build? April 08, 2016 07:02PM |
the_digital_dentist
It will meet all the basic requirements for a quality printer and look a lot my current machine:
Rock solid 40mm square t slot aluminum frame
electronics in a drawer?
fully enclosed
linear guides for all linear motion
32 bit controller
DSP drivers on X and Y axes
no autotramming
high voltage supplies for motors
minimal/no printed parts- all metal
and
bed lifted by 3 screws and 1 motor
heated bed?
print envelope: 300 x 300 x 600+ (?)
As always, print quality will be highest priority. I will control costs by using used parts wherever practical (I already have 3x Japanese linear guides from ebay and all frame parts from a scrap yard) and doing all required machining myself.
Re: Which core XY should I build? April 08, 2016 10:10PM |
