CoreXY belt / idler juddering issue (belt teeth against bearings) April 17, 2016 06:15PM |
Re: CoreXY belt / idler juddering issue (belt teeth against bearings) April 18, 2016 01:23AM |
Re: CoreXY belt / idler juddering issue (belt teeth against bearings) April 18, 2016 03:10AM |
Re: CoreXY belt / idler juddering issue (belt teeth against bearings) April 18, 2016 09:47AM |
Dalius98
I am using toothed idler pulleys (6mm GT2). At first I made my own from miniature flanged bearings and 8mm bore pulleys, but there's a better solution - Aliexpress or ebay. Just search for GT2 idler pulley, and there will be some with teeth![]()
If that twist is there to reduce teeth contact with the bearings, you could just replace all those bearings with toothed idlers, maybe get rid of the complicated twist. Though I can't tell if that will improve print quality, most printer designs I've seen just use smooth idlers...
Re: CoreXY belt / idler juddering issue (belt teeth against bearings) April 18, 2016 09:49AM |
gforce1
I would replace the idler for a GT2-pulley.
In my design i have the motor in the corner, so i don't need the (2) extra pulleys. I have also twisted the belts in the same place.
I can slide the motors back- and forwards for tensioning the belts.
Re: CoreXY belt / idler juddering issue (belt teeth against bearings) April 18, 2016 12:58PM |
Re: CoreXY belt / idler juddering issue (belt teeth against bearings) April 18, 2016 05:41PM |
FA-MAS
How about this? Keeps the motor inboard, puts the teeth on the outside of the idlers, no twist in the belt, requires one less idler.
Re: CoreXY belt / idler juddering issue (belt teeth against bearings) April 18, 2016 10:35PM |
Re: CoreXY belt / idler juddering issue (belt teeth against bearings) April 19, 2016 07:23AM |
cozmicray
Well the truth be told
The diagram in the initial post
is ONLY one half (or one level) of a coreXY belt arrangement
Correct me if I am wrong, fuzebox CoreXY belt route shown below
[attachment 76676 Fuzebox_Belt.jpg]
You believe the belt teeth moving over the smooth pulleys is causing juddering (jolting, pulsing)
in your X Y movement?
Have you considered larger diameter smooth pulleys
TIMING BELT DESIGN AND INSTALLATION SUGGESTIONS: GENERAL GUIDE LINES
Idlers, either of the inside or outside type, are not recommended and should not be used except for power takeoff or functional use. When an idler is necessary, it should be on the slack side of the belt. Inside idlers must be grooved, unless their diameters are greater than an equivalent 40-groove pulley. Flat idlers must not be crowned (use edge flanges). Idler diameters must exceed the smallest diameter drive pulley. Idler arc of contact should be held to a minimum.
Re: CoreXY belt / idler juddering issue (belt teeth against bearings) April 19, 2016 08:34PM |
Re: CoreXY belt / idler juddering issue (belt teeth against bearings) April 21, 2016 08:48AM |
cozmicray
Mechanical excellent grasshopper
Hicups in X , Y or both?
Pure X and pure Y prints should be done and examined
Diagonal print may also show something
Difficult to separate X , Y axis issues in CoreXY system
For resonance -- you may want to put a large weight on printer (avoid crushing printer)
see if that changes things.
200st/sec, yes.Quote
What stepping is selected on stepper drivers? Are they all the same?
if it makes any sense, they "sound" fine when moved by hand.Quote
Tape a red line on pulleys --- does it rotate smoothly?
in a country of the blind --- everything is heard / felt !
-- even the errors from the 3D printer of the one eye king
Re: CoreXY belt / idler juddering issue (belt teeth against bearings) April 21, 2016 10:49AM |
lkcl
cozmicray
a single piece with square corners printed straight on x and y showed 0.5mm warbling on both sides.
that's a good idea. will try that.
Re: CoreXY belt / idler juddering issue (belt teeth against bearings) April 21, 2016 12:51PM |
Re: CoreXY belt / idler juddering issue (belt teeth against bearings) April 21, 2016 04:47PM |
cozmicray
Grasshoppaa
"What stepping is selected on stepper drivers? Are they all the same?"
Are the driver jumpers (under drivers full step, half step, 1/4 step, 1/8 step,1/16 step,1/32 step)
set the same
maybe try another step setting
Perhaps try a much slower / faster printing speed?
The line on pulleys (maybe a toothpick) may show a / all pulleys juddering!
Extruder juddering?
or Build stage shaking around?
Perhaps placing printer out in well groomed zen garden next to Bonsai tree with proper fung shui?
