Re: Do CoreXY belts need to be of equal tension? May 03, 2016 08:33AM |
Re: Do CoreXY belts need to be of equal tension? May 03, 2016 12:49PM |
realthor
I can't write python for my CAD.
I am using a proprietary (unfortunately) CAD and I have thousands of objects in the file ...can't easily port it over to OnShape or OpenSCad ... I have no time for that and I barely know this software (DesignSparkMechanical).
I usually just delete whatever objects I notice are bad design or have some fault or need replacing, otherwise I modify that object. Not many options to revert back a change
but on the other hand this software is stellar at fast prototyping, it's very easy to redo something, if not very complicated. I haven't had many issues with it so far but I'd like to switch to something open source in the near future ... I have my eyes on Antimony for some time but haven't had the chance to dive into it.
Re: Do CoreXY belts need to be of equal tension? May 03, 2016 01:01PM |
... so no point in uploading them to a wiki, besides what you call a source for others to see where I went wrong etc ... but basically i would call that pointless information overload. People barely look to complete/proven designs...|
Re: Do CoreXY belts need to be of equal tension? May 03, 2016 05:07PM |
the_digital_dentist
ikcl,
When designing in CAD, I start a folder for a project. There's usually one file into which final or near final components get assembled into the overall design, and multiple files for individual component designs. When a part design is finalized, I stop messing with it. When it comes to big things like how to lay out linear guides for a CoreXY machine I am currently designing, I draw one layout, then make a copy of it in the same file and modify the copy for an alternative and compare the two. The winner stays and the loser gets deleted.
Supporting "the community" is nice and I try to contribute where I can, but I don't let "the community" determine my design choices or the CAD software I use. My designs are for my own education and use and I don't worry about others being able to duplicate them exactly.
I prefer to make the best printing machine I can using whatever tools make the design and construction easiest for me. I don't like to use printed plastic parts and I don't mind including designs that require a milling machine. I use a lot of surplus machine parts that are unlikely to be available to someone else in the same combinations. Someone would have to be pretty determined and have pretty deep pockets to duplicate my designs. There's plenty that can be learned from looking at photos or CAD images (that's where I get some of my best ideas, thanks to "the community").
In the course of designing a machine I sometimes model "popular" components to check fit, clearances, etc. I post those models to Youmagine.com. I just posted a model of the E3D Titan extruder last week, for example, so others don't have to buy it first to determine if it's going to fit their machine.
Re: Do CoreXY belts need to be of equal tension? May 04, 2016 05:18AM |
Re: Do CoreXY belts need to be of equal tension? May 16, 2016 09:38AM |
realthor
http://reprap.org/wiki/SCOUTcorexy
something for a start ...
-how do I upload a picture for the "|image =" section in the upper right corner?
Edit: I managed somehow but didn't quite get the usual way to do it
- or how do I bulk upload pictures for the gallery ...
- why don't I have the green framing around the top-right description of the machine
is there a way to embed github folder for the gallery in the wiki? (so that it displays pics found in a github folder)
