appjaws-D-Bot progress April 21, 2016 02:57AM |
Re: appjaws-D-Bot progress April 21, 2016 11:12AM |
Re: appjaws-D-Bot progress April 24, 2016 09:43AM |
Re: appjaws-D-Bot progress April 24, 2016 01:34PM |
deckingman
That's looking good.
It'd just mean longer uprights and lead screws as well as longer and thicker Z guides would it not?
Of course, there are the usual caveats about stiffness etc but looking at your pics, it doesn't seem to be too difficult to add diagonal bracing and/or chunkier corner barckets. Is this a feasible idea or have I missed something? I know nothing about corexy printers apart from what I have read on these forums over the last week or 2.
Re: appjaws-D-Bot progress April 24, 2016 03:38PM |
Re: appjaws-D-Bot progress April 24, 2016 07:22PM |
deckingman
That's looking good. I'm looking to build another printer but my main requirement over the Mendel3 I have at the moment is extra height (a lot of extra height). I looked at Delta designs but I'm using a Diamond hot end so mounting the 3 extruders while keeping Bowden tube lengths manageable becomes difficult.
Re: appjaws-D-Bot progress April 24, 2016 07:59PM |
deckingman
All good stuff. That's very encouraging and thanks for the links.
Although I build garden decks for a living these days, this is career number 5 (or 6 or 7 - I've changed tack so many times I've kind of lost count). However, when I first started work in 1969, it was as an apprentice tool maker and I spent about 30 years as an automotive engineer in one form or another. Although that was a very long time ago, I still remember basic engineering principles so I think I could cobble together something that is stiff enough. Of course, my day job is designing and building structures that are stiff and strong and subject to loads of up to a couple of tons (or more), but they are made from 4.8 metre lengths of timber and they are allowed to flex a bit, so not quite the same thing.
What I don't have is access to metal working machinery.
What I do have is a 3d printer so if I can use a plastic part, I will. After all this is the RepRap forum. I was thinking along the lines of plastic corners just to hold the pieces together but with metal bracing going from top left to bottom right, and top right to bottom left on each side of the frame to take any loads or twisting forces. Just flat strip would do.
That way, there wouldn't be any significant loading on the plastic parts. Of course, the front would need to be left open to get the printed part out so some other arrangement would be needed on that face.
I don't like the idea of a cantilevered bed though. It just sort of goes against grain somehow.
I think I'd be looking at maybe 3 lead screws or some such arrangement. Lots to think about......
Re: appjaws-D-Bot progress April 25, 2016 02:39PM |
dc42
deckingman
The Bowden tubes on a 3-extruder delta don't need to be any longer than on a single-extrusion delta. OTOH if you were thinking of using a flying extruder, that would be more difficult with 3 extruders.
Re: appjaws-D-Bot progress April 25, 2016 03:15PM |
lkcl
yeahhh i've worked in the building trade, too: i thought about that, but i wondered how the two strips could be tied together in sufficient tension. then i realised, if they cross in the middle maybe you could tension them up... but then.. mmm... how do you equalise the tension in a precise, known way? if you get it wrong you'd actually end up doing more harm than good. yes, sure you could measure the diagonals: if they're the same, great, you got it right... but it just doesn't feel like it's a "precision reproducible instrument" to me. in the end i went, "naaah, let's get some plywood or hardboard"
i can guess what's going through your mind. you're thinking in terms of the amount of stress that the arrangement would put onto a wood structure like that, which is a good thing. you're probably also thinking, "if this were scaled up 10:1 and i was standing on that, would i survive the fall?"
Re: appjaws-D-Bot progress April 25, 2016 03:27PM |
deckingman
Whereas with a CoreXY design, the Bowden tube(s) would only have to be long enough to accommodate movement in the XY plane. At least, that was my reasoning but I bow to anyone's superior knowledge.
Re: appjaws-D-Bot progress April 25, 2016 03:33PM |
deckingman
Maybe I didn't explain myself well. The bracing doesn't need to be pre-tensioned. You build a rectangular frame - say one of the sides, fixing the corners by whatever means you choose, and make sure it's square. Then you cut 2 flat strips the length of the diagonal, drill a hole in each end and bolt them to the side of the frame at the corners. You'd maybe need to space one of the strips away from the frame by the thickness of the first strip so that they will cross without interference.
You could also screw the two strips together where they cross just tpo stop them "flapping around". This will keep the rectangle square because if you press on any one corner, the diagonal bracing would be under compression. Repeat for all the other sides and you should have a pretty rigid cuboid, even with plastic corners. Of course, it won't stop the frame from bowing. For that you need thicker extrusion or horizontal bracing but that's easy to do on a core xy because the bed doesn't move in the x or y direction, unlike a Mendel for example.
More like, if it collapsed with a customer and his friends and family on it, would I survive the court case.
Re: appjaws-D-Bot progress June 08, 2016 10:07AM |
Re: appjaws-D-Bot progress June 13, 2016 01:41PM |
Re: appjaws-D-Bot progress June 15, 2016 02:58AM |
Re: appjaws-D-Bot progress July 05, 2016 07:31AM |
Re: appjaws-D-Bot progress July 05, 2016 05:47PM |
Re: appjaws-D-Bot progress July 07, 2016 08:00PM |
Re: appjaws-D-Bot progress July 08, 2016 07:35AM |
Re: appjaws-D-Bot progress July 08, 2016 09:07AM |
Re: appjaws-D-Bot progress July 11, 2016 11:35AM |
Re: appjaws-D-Bot progress July 11, 2016 03:22PM |
appjaws1
rethinking the Z setup, looking for ideas.
Re: appjaws-D-Bot progress July 13, 2016 06:33AM |
