What CoreXY design to choose? April 26, 2016 10:35AM |
Re: What CoreXY design to choose? April 26, 2016 11:50AM |
Re: What CoreXY design to choose? April 26, 2016 02:51PM |
Re: What CoreXY design to choose? April 27, 2016 06:09AM |
Re: What CoreXY design to choose? April 27, 2016 08:00AM |
Re: What CoreXY design to choose? April 27, 2016 11:24AM |
Amoniak
I’m a complete novice to 3D printers but I’m a tinkerer thus my plan is to source and build it myself.
Not to have a super good 3D printer up and running as soon as possible, but rather enjoying the project of building one.
The biggest hinder in this is that I have no printer, thus I cannot print any parts myself
There is a Zyyx printer at work, but I’m not sure I’m even allowed to use it.
My first idea was to build the SmartRapCore using the wood box design. This was mainly due to the fact that the printed parts sells on their site.
And wood is cheap and easily customizable.
But since they are not responding to any e-mail I’m not sure this will be the final decision.
The Fusebox, or rather the rework of it FB2020 by AxMod has caught my interest (Basically Misumi 15x15 is to hard/expensive to get in Europe, but 2020 extrusions are more easily acquired).
But here’s where I’m stuck and hope for some advice on what design to choose.
Re: What CoreXY design to choose? April 27, 2016 01:12PM |
Re: What CoreXY design to choose? April 27, 2016 02:09PM |
Re: What CoreXY design to choose? April 27, 2016 04:10PM |
Re: What CoreXY design to choose? April 27, 2016 10:07PM |
the_digital_dentist
When I built my first 3D printer there were some critical things I didn't know about that would have saved me a lot of wasted time, effort, and money. Some are things that aren't obvious, others are things that you usually only find out about after you've been struggling for a while. Here's a few to get you started:
You can see some of the other things I did in my printer by clicking the link in my sig, below.
Re: What CoreXY design to choose? April 27, 2016 11:16PM |
Re: What CoreXY design to choose? April 28, 2016 06:50AM |
Re: What CoreXY design to choose? April 28, 2016 07:34AM |
Re: What CoreXY design to choose? April 28, 2016 09:01AM |
ivo95
So many replies, ranging from cozmicray's :"@#$%&! NOOB, don't even think about building 3d printer unless you have PhD in 3d printing", to the_digital_dentist: "You need about €3000 euro's to build a printer".
I have started to build Ax FB2020 with few modifications.
IMO buying kit is stupid, especially for printer that is based on standard alu profiles.
If you look at that SmartrapCore Alu basic kit (€325 shipped with LCD controller), you are getting underpowered PSU (10A), hotend that looks like $5 e3d clone, unknow steppers...
Re: What CoreXY design to choose? April 28, 2016 09:10AM |
Re: What CoreXY design to choose? April 28, 2016 09:12AM |
Amoniak
Let’s say I choose the SmartRapCore, would building it in a MDF box be a terrible idea compare to alu extrusions?
What would be the affordable option to a 8-bit RAMPS system for such a printer?
How would it work with the firmware?
With RAMPS there preconfigured marlin for the smartrapcore.
Re: What CoreXY design to choose? April 28, 2016 11:18AM |
lkcl
Amoniak
i don't see why not. if you run it a bit quick, you'll get vibrations running through the MDF, but that's easily dampened with the right creative mindset. alu extrusion is used i think because you can get a good all-round view, and assembly is a leetle easier because you've got access. but, that's solved by cutting out holes (not too big!) from the middle of the MDF.... bad idea if you want an enclosed box though
but, before making that decision, take a look at motedis.com, evaluate the cost of their extrusions, is it really that much extra?
DON'T get a kit that has separate steppers on tiny boards, for goodness sake. i don't know why people think that RAMPS and their ilke are good. i explained why, with lots of emphasis, to davedavedave, here: [forums.reprap.org]
Re: What CoreXY design to choose? April 28, 2016 11:34AM |
Re: What CoreXY design to choose? April 28, 2016 12:28PM |
the_digital_dentist
I suppose you're right. Why spend $40 on a cast bed plate that's flat, rigid, heats evenly, and prints stick, when you can spend $30 on a thin, flexible piece of aluminum and a piece of glass to try to flatten it? You saved $10! So what if you're going to be messing around for many hours over the life of the printer, trying to get prints to stick. Life is long, you have nothing better to do, and that $10 you saved is worth at least a couple cups of coffee you can sip while you're struggling with your 3D printer.
And why plan for eventualities like enclosing the machine? Planning is too much work. It's much less trouble to just rewire the whole machine later when you decide to enclose the machine. Besides, you may not like 3D printing enough to bother with enclosing the machine later.
Maybe the struggle to get prints to stick to the bed and all the other problems you're going to have to solve will convince you that 3D printing isn't for you and you'll be glad you didn't waste more than $300 on the machine.
the_digital_dentist
Re: What CoreXY design to choose? April 28, 2016 12:33PM |
Re: What CoreXY design to choose? April 28, 2016 01:43PM |
Re: What CoreXY design to choose? April 28, 2016 01:44PM |
filipeCampos
this thread was already lot of line of text but not mutch that help Amoniak..
So.. for 400€ or less someone think there are a better of the SmartRapCore? if so, why?
Re: What CoreXY design to choose? April 28, 2016 05:12PM |
Re: What CoreXY design to choose? April 28, 2016 05:17PM |
Amoniak
Would a RAMBO controller board be an option?
Re: What CoreXY design to choose? April 28, 2016 05:22PM |
Re: What CoreXY design to choose? April 28, 2016 05:36PM |
David J
Amoniak - are you thoroughly confused yet?
I think deckingman is saying the same as me - pick a simple design, have a go at building it, make some mistakes and try again (and again), and gain experience as you go. Go 'advanced' later on.
Note: Like him I'm a '60-something' tinkerer who loves building things: I knew nothing about 3D printing 2 years ago, and since then I've had a lot of fun by progressing through the hobby. I did have some prior skills - I've done some model engineering, up to including a large-scale steam engine, and I've played with electronics for many years, but they're all skills I've picked up as I've gone along.
Re: What CoreXY design to choose? April 28, 2016 06:07PM |
DavidJ
deckingman
I only got into 3d printing about a year ago (I'm a 60 something carpenter)
Re: What CoreXY design to choose? April 28, 2016 06:25PM |
Re: What CoreXY design to choose? April 28, 2016 06:46PM |
