[idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt April 27, 2016 01:47PM |
Re: [idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt May 03, 2016 07:29PM |
Re: [idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt May 04, 2016 04:59AM |
Re: [idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt May 04, 2016 01:34PM |
Re: [idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt May 05, 2016 03:15AM |
epicepee
If you're willing to add a second gantry, you can just use the Ultimaker's setup, where each gantry is controlled by a single motor through a driveshaft and a pair of rods:
Re: [idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt May 05, 2016 03:22AM |
filipeCampos
You are making some difficult/strange questions, i not a mechanical engineer/expert and not sure if i will tell next is correct or not...
but from your gimp image the belt have the "normal" corexy setup and you have mixed with some of the idea of the ultimaker design (added a axis one the X)
I think this second axis will add more rigidity and not allow the carriage to twist, but this twist problem is related with the h-bot design and not the corexy.
So resuming.. for me this design only make sense if you use a h-bot belt setup and add the second X axis to remove the twiste problem.
but it is a lot more easy to simply upgrade the linear movement, the second axis add to much complexity on the carriage...
Re: [idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt May 05, 2016 04:45AM |
Re: [idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt May 05, 2016 08:15AM |
filipeCampos
To be honest i think this is only a good theoretical exercise, but not make much sense in practical. You can simply take the extra cost of adding the second axis and buy a good guide linear rail, problem solved! This solution is adding way to much complexity to solve a problem that can be easy solved with a good linear movement, normally the simplest solution is the best.
Re: [idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt May 05, 2016 01:04PM |
Re: [idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt May 05, 2016 04:01PM |
filipeCampos
Well.. you are probably right about the use of carbon fibre, looks like to be a great material to use on the build of a printer. But this is not a new topic?
And you call the quadrap a fascinating design. To me is more like "build a printer with what you have at home...", is a big mess..
I my opinion you are going the wrong way, your are trying to fix a problem adding more complexity on the system.
What you need to do is the opposite, simplify the system. In this particular case, i will suggest to solve this using 12mm linear guide rail and use a simple h-bot mechanism.
This heavy setup will have enough rigidity and precision to not have the twist problem and is weight will not matter.
But this is only my opinion, nothing more.. You are trying a new design and if you believe it will work than go for it..
Re: [idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt May 07, 2016 04:41AM |
Re: [idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt May 07, 2016 07:36AM |
deckingman
Ref your OP. I think I see where you are coming from with this, trying to spread the load more evenly by adding central support to the carriages. However, as I understand it, one of the primary advantages of the corexy design is that it offers the potential for greater speed because all the motors are static and not fixed to any moving axis.
Therefore the moving mass is reduced allowing for greater acceleration and overall speed. The only thing that you are trying to move around is the hot end with any associated cooling fan so there shouldn't be much of a mass.
By adding the central bearings, you are increasing the mass that has to be moved around so potentially negating some of the speed advantage of the corexy design. Whilst it would be more rigid, I personally think that supports at either end will be rigid enough and so adding extra supports in the centre will only increase the mass and therefore reduce the maximum speed potential of the machine. That's just my opinion of course.
Re: [idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt May 07, 2016 01:24PM |
lkcl
question, though: i note in the openbuilds delrin double-v-rollers they have *two* 625 bearings per roller. is that absolutely strictly necessary? would tight friction press-fit over a double-v roller using a single deep groove 625 bearing be okay? if not *sigh* that would mean 18 625 bearings.
Re: [idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt May 07, 2016 02:31PM |
os3dp
lkcl
lkcl: The openbuilds rollers have two bearings and a 1mm spacer to make the roller. The spacer ensures the bearing sides don't touch at the outside when smashed together. There is a ridge in the middle of the roller that wouldn't allow the roller to be used with just one bearing unless you machined out that ridge.
-os3dp
Re: [idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt May 07, 2016 03:46PM |
lkcl
so, i know it's a long way down now from the original question, but to reiterate, i think relying on there only being one y-rod is not sensible, although i am aware that the quadrap does that, but they (and the ultimaker) both have belt arrangements that support the moving cross-rods at both ends. the corexy belts would support the x-rod, but the y-rod would be free and could move off of perpendicular. two y rods would stop that happening, although.. yeah, it's quite a lot more 625 bearings. hmm.....
Re: [idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt May 07, 2016 07:13PM |
deckingman
Lots to think about. The big question is, how much does any of it matter? Do I really care about getting an extra (say) 5% gain in speed? I guess it comes down to what you are trying to print. I'm toying with the idea of something that would potentially have a build volume around 400mm x 400mm x 800mm. So, 5% speed increase will translate in saving hours of print time. Therefore I do care - just answered my own question - sorry for the ramble.
Re: [idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt May 07, 2016 09:41PM |
deckingman
I'm trying to find out how the weight of 2020 aluminium compares to the weight of solid steel rods (anyone know?). I'm thinking that for what I'm planning, X and Y will be in region of 500mm so I'm guessing that I ought to look at 10mm rods as a minimum.
Re: [idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt May 08, 2016 04:21AM |
os3dp
deckingman
500mm 2020 V-slot weighs in at 222g
-os3dp
Re: [idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt May 08, 2016 07:54AM |
lkcl
so what do you think, deckingman - two pairs of aluminium square-section (2 for x, 2 for y), 12 or even 15mm square, you'd need 12 bearings to support the carriage on double-v-wheels. don't be tempted to make it less, i know people have tried to put the upper v-wheels on the x and the lower v-wheels on the y, then use a small amount of bend in the bars to keep the carriage stuck to the bars.... please don't do that
Re: [idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt May 08, 2016 09:28AM |
deckingman
The rods will be two at each of the front corners at one in the centre if the back giving 3 point lift. Initially the rods will be connected buy a belt and driven from a single stepper but the longer term plan is to have each one driven by it's own stepper when DC42 gets around to incorporating bed levelling by controlling each individual Z rod.
Re: [idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt May 08, 2016 09:45AM |
lkcl
deckingman
niiice. ok you don't need dc42 to do the bed levelling, you can just copy the deltaprinter homeall.g file and it's pretty much done. *but*.... what you *will* need - in the firmware - is to have Z0 to mean "do all 3 z motors" yet when you want to control individual ones you would refer to them as "Z1, Z2 and Z3" respectively. that _will_ need to be coded up in c++ only thing i can say is, though, aw poo! the duet 0.8.5 can't handle that on its own - i'd need to get the expansion board. oh well - at least it would be possible with the expansion board.
Re: [idea] CoreXY "+" - Alternative to "H" arrangement, keeping CoreXY belt May 08, 2016 09:52AM |
deckingman
Yup. With 3 extruders as well, I'll be using 8 steppers. Duet 0.8.5 does 5 and the expansion board gives another 4 so I'll have one spare channel.
