SmartrapCore Question April 27, 2016 09:58PM |
Re: SmartrapCore Question April 27, 2016 10:22PM |
Re: SmartrapCore Question May 01, 2016 03:47AM |
long part sticking to printbed question May 22, 2016 05:51AM |
engmaster
I try use a simple glass, but with PLA we have warp in big lenghts without heated bed =/ See my print in foto1
Re: SmartrapCore Question May 22, 2016 05:56AM |
DjDemonD
I've got a smartrapcore alu and its a mk2b pcb heater with float glass clipped on top. I use 60 deg for pla without any adhesion promoter and can easily remove parts once the bed temp is below 44 deg C.
Re: SmartrapCore Question May 22, 2016 08:08AM |
Re: SmartrapCore Question May 22, 2016 02:46PM |
DjDemonD
I printed a washing machine door for a childs toy which was almost the size of the glass print bed.
[attachment 78485 2016-03-2612.17.02.jpg]
This was no-name PLA. once it was cool it just came away. No warping, no adhesion promoters, just pla onto clean glass (clean it before printing with proper pure isopropyl alcohol - not hand gels stuff which has slippery additives).
Re: SmartrapCore Question May 22, 2016 02:55PM |
Re: SmartrapCore Question May 23, 2016 05:35AM |
DjDemonD
Ickl - Okay so the OP is getting warp without a heated bed. Fairly easy fix - get one. I accept your parts look fiendishly difficult to print. Send me an STL I'll have a try....
Re: SmartrapCore Question May 23, 2016 05:50AM |
Re: SmartrapCore Question May 23, 2016 11:06AM |
DjDemonD
Okay I'll take a look.Might take a while by all accounts.
Are you fixed on using PLA? I have an enclosed printer so could print ABS in a heated chamber.
ABS however was nowhere near strong or rigid enough, despite the laptop only being 1.1kg parts bent way beyond acceptable limits, tended to crumble, and even snapped. bear in mind, the thickness in some places is only 1mm, so ABS just couldn't cope.|
Re: SmartrapCore Question May 25, 2016 06:32PM |
Re: SmartrapCore Question May 26, 2016 01:40PM |
Re: SmartrapCore Question May 26, 2016 05:18PM |
DjDemonD
Okay so first attempt at the back_base. Printed with no support or brim or raft.
I agree they are quite strong, its a clever design even if something that gave the printer a workout.
yeah when joining the arches together i found that they curled up a tiiny bit, and as the next layer began to be added the printer would go "ker-chunkk" against the raised edge.... not a nice sound and it contributed to the part being ripped off eventually....Quote
Simplfy3d made light work of it, but I did load it in slic3r and the resulting preview was laughable.
There is some lift I'd roughly measured the 6-7mm at each end has warped by a maximum of 0.3mm at the very end. Sorry if its hard to make out in the images. How does this compare to what you typically see?
Re: SmartrapCore Question May 26, 2016 05:25PM |
DjDemonD
Second attempt today with some pads attached on the ends, circular to spread out the contraction forces. No lift on the part at all, there's a little bit of lift on the right hand set of pads.
Using Excelvan black PLA at 200 deg C, bed at 70 degC, extra hold hair spray on float glass.
The Cad has messed up the top edge
no wonder people keep writing new gcode generators... maybe slicing is harder than we think it is...|
Re: SmartrapCore Question May 26, 2016 05:26PM |
Re: SmartrapCore Question May 26, 2016 06:03PM |
Re: SmartrapCore Question May 29, 2016 03:41PM |
DjDemonD
Okay so I can bend the back_base part quite a bit and it returns to its original shape, which for PLA is quite impressive I was expecting it to shatter into shards. I suppose it is quite thin and therefore flexible, despite being PLA. I am not quite willing to break it, it looks like it would take quite a bit of effort.
yeah it would eventually shatter, if you did try it please be careful. yeah i figured if they made cathedrals that have stood for a thousand years with arches like that then they must have got something rightQuote
I am getting bleed through yes not too severe but its there.
I've had a go at the back_KBD_runner and printed it with just pads like the first part, flat as a pancake. So how many do you want?
Do you have an image of the complete laptop I'm curious to know what these parts end up looking like?
Re: SmartrapCore Question May 29, 2016 04:00PM |
Re: SmartrapCore Question May 30, 2016 02:59PM |
DjDemonD
The laptop looks great really innovative. Laptops are so boring and generic I'd buy one like that on style grounds alone, add to that it's, I presume, recycled components and you've got a winner.
Keep me posted.
As for why these parts don't stay flat when you print them I have no idea. What's your setup?
it was repsnapper, then cura 15.04, with a 0.4mm nozzle, layer height 0.15mm (0.1mm was a bit too much for the mendel90). the glass i believe wasn't actually properly flat (as in, the *glass* wasn't flat)... all that's gone now, replaced by the sandwich200v2 which i have had to pack up for now and i have to redo the carriage to use something that's derived from the Sli3DR.|
Re: SmartrapCore Question July 01, 2016 01:16AM |
DjDemonD
The laptop looks great really innovative. Laptops are so boring and generic I'd buy one like that on style grounds alone, add to that it's, I presume, recycled components and you've got a winner. Keep me posted.
Re: SmartrapCore Question July 01, 2016 04:47AM |
Re: SmartrapCore Question July 01, 2016 12:52PM |
