Re: My coreXY design is progressing to the build stage November 14, 2016 03:29PM |
Re: My coreXY design is progressing to the build stage November 15, 2016 02:45PM |
Re: My coreXY design is progressing to the build stage November 15, 2016 02:58PM |
Re: My coreXY design is progressing to the build stage November 18, 2016 06:15PM |
Re: My coreXY design is progressing to the build stage November 24, 2016 09:48AM |
Re: My coreXY design is progressing to the build stage November 24, 2016 10:24AM |
Re: My coreXY design is progressing to the build stage November 24, 2016 10:44AM |
Re: My coreXY design is progressing to the build stage November 24, 2016 12:59PM |
Re: My coreXY design is progressing to the build stage November 24, 2016 01:01PM |
Re: My coreXY design is progressing to the build stage November 24, 2016 03:03PM |
cozmicray
Teeter Totter
Are the trolleys on rails really that slop free (rotation on rail)?
Perhaps use two trolleys -- spaced out -- on each rail
Departure from your 3 or 4 point suspension?
Teflon blocks to make bed Teeter Totter better --- or thermal break?
Will you use brake on motor or just let bed fall 700mm?
Re: My coreXY design is progressing to the build stage November 28, 2016 01:09AM |
Re: My coreXY design is progressing to the build stage November 28, 2016 10:07AM |
Re: My coreXY design is progressing to the build stage November 28, 2016 10:51AM |
I have mixed feelings about using the M8 screws because they have M6 threads, but I'm going to give them a try and see if they work. If I don't like the way they behave, I'll drill out the holes and use M8 bolts.
Re: My coreXY design is progressing to the build stage November 28, 2016 11:45AM |
Re: My coreXY design is progressing to the build stage November 28, 2016 03:50PM |
the_digital_dentist
6 mm shoulder screws have either M4 (M5?) threads. I feel like that's getting pretty small to withstand the lateral force due to the belt tension without flexing/tilting. If each of those 8 screws flexes just a little, the belt is going to be riding on the outer flanges all the time. I have mixed feelings about using the M8 screws because they have M6 threads, but I'm going to give them a try and see if they work. If I don't like the way they behave, I'll drill out the holes and use M8 bolts. Then all I have to worry about is the 1/4" aluminum plate flexing.
The belt should ride on the central, flat part of the pulley and shouldn't be running against the flanges at all if it can be prevented. 0.6 mm clearance assumes the belt is pretty good quality. I've been using cheapo belt from Folger Tech and found that their slicing isn't very consistent so the width varies along the length of the belt. 0.6 mm clearance is cutting things a little too close for comfort . The motor pulleys for 9 mm belt are usually 11 mm wide and the F608zz bearings match that width.
The toothed idlers are nice, but you have to use shoulder screws with them (though most people probably don't) because they don't have spacers between the center rings of the bearings. The shoulder screws that fit them have to be pretty small to accommodate the bearings plus the additional size of the aluminum part of the pulley. I see many such pulleys for 6mm wide belt, but not many for 9mm wide belt. Maybe the greater load that is assumed with 9mm wide belt would be too much for the skinny shoulder screws, but a more likely explanation is that 9mm wide parts cost more so aren't as popular with the hobbyist 3D printing market. 3D printing hobbyists are usually cheapskates, and shoulder screws are pretty expensive as hardware goes, so you don't usually see them offered for sale with the 6mm pulleys.
Re: My coreXY design is progressing to the build stage November 29, 2016 10:20PM |
cozmicray
Teeter Totter
Re: My coreXY design is progressing to the build stage November 30, 2016 08:23AM |
Re: My coreXY design is progressing to the build stage December 11, 2016 11:29PM |
Re: My coreXY design is progressing to the build stage December 12, 2016 09:09AM |
Re: My coreXY design is progressing to the build stage December 12, 2016 07:51PM |
Re: My coreXY design is progressing to the build stage December 12, 2016 09:07PM |
Re: My coreXY design is progressing to the build stage December 14, 2016 12:08AM |
Re: My coreXY design is progressing to the build stage December 14, 2016 01:14AM |
cozmicray
I know its not intended for this use
but
a forsner bit can bore a nice big hole for your motor
drill a pilot -- forsner tip just can't do it.
I was surprised with the nice aluminum foil shavings it produced
Extreme --- Bored out a 3 inch rod to 2 inch depth with 1.5 inch forsner bit
Re: My coreXY design is progressing to the build stage December 14, 2016 06:38AM |
Re: My coreXY design is progressing to the build stage December 14, 2016 09:18AM |
Re: My coreXY design is progressing to the build stage December 14, 2016 09:26AM |
Re: My coreXY design is progressing to the build stage December 14, 2016 04:48PM |
Re: My coreXY design is progressing to the build stage December 14, 2016 06:30PM |
Re: My coreXY design is progressing to the build stage December 16, 2016 07:41PM |
Re: My coreXY design is progressing to the build stage December 17, 2016 04:44PM |
