Re: My coreXY design is progressing to the build stage April 27, 2018 08:02AM |
Re: My coreXY design is progressing to the build stage May 01, 2018 02:48PM |
Re: My coreXY design is progressing to the build stage May 01, 2018 03:18PM |
Re: My coreXY design is progressing to the build stage May 02, 2018 02:48AM |
Re: My coreXY design is progressing to the build stage May 02, 2018 06:46AM |
Re: My coreXY design is progressing to the build stage May 02, 2018 07:42AM |
Re: My coreXY design is progressing to the build stage May 02, 2018 08:40AM |
Re: My coreXY design is progressing to the build stage May 02, 2018 09:47AM |
the_digital_dentist
Yes. I like the techniques used to test different configurations. I copied the general shape and size of the CPAP blower that is optimized to provide pressure/flow with minimum noise. The blowers in the video are intended to maximize flow/pressure where a high noise level is more acceptable (dust collection in a wood shop). If I were going to pursue this further I might adopt some of the techniques used to optimize the design, but I'm moving on to other things- specifically trying to get the Duet board installed in UMMD. As far as the apple fan goes, I am pretty sure a printed impeller with evenly spaced and identical vanes will be balanced when it comes off the printer (and it does seem to be pretty good), but I wouldn't know how to balance an odd spaced vane design so that it will be OK at 10k rpm. Maybe Fusion360 has some special feature that will show the center of mass of a complex structure and allow it to be manipulated, but I'm not there with Fusion360 yet.
Re: My coreXY design is progressing to the build stage May 02, 2018 10:04AM |
Re: My coreXY design is progressing to the build stage May 02, 2018 10:49AM |
Re: My coreXY design is progressing to the build stage May 02, 2018 03:57PM |
Re: My coreXY design is progressing to the build stage May 02, 2018 04:22PM |
Re: My coreXY design is progressing to the build stage May 03, 2018 01:58AM |
cozmicray
It's about time to put real topics on these posts
"My coreXY design is progressing to the build stage" probably has run long enough?
Last few posts "cooling pump" not specific "core XY"
FWIW
Could be "the Digital Dentist sez"
Re: My coreXY design is progressing to the build stage May 09, 2018 03:35PM |
Re: My coreXY design is progressing to the build stage June 13, 2018 07:51AM |
Re: My coreXY design is progressing to the build stage June 13, 2018 09:31PM |
Re: My coreXY design is progressing to the build stage June 14, 2018 12:01AM |
Re: My coreXY design is progressing to the build stage June 14, 2018 12:25AM |
Re: My coreXY design is progressing to the build stage June 14, 2018 07:03AM |
Re: My coreXY design is progressing to the build stage June 14, 2018 05:07PM |
Re: My coreXY design is progressing to the build stage June 22, 2018 01:59PM |
Re: My coreXY design is progressing to the build stage June 22, 2018 02:43PM |
Re: My coreXY design is progressing to the build stage June 22, 2018 11:23PM |
Re: My coreXY design is progressing to the build stage June 23, 2018 03:56AM |
Re: My coreXY design is progressing to the build stage June 30, 2018 05:38PM |
Re: My coreXY design is progressing to the build stage July 21, 2018 10:03AM |
Re: My coreXY design is progressing to the build stage July 21, 2018 10:28AM |
Re: My coreXY design is progressing to the build stage July 21, 2018 10:10PM |
Re: My coreXY design is progressing to the build stage July 22, 2018 02:15AM |
There isn't any way to automatically reduce acceleration and speed as a function of the Z coordinate, is there?
Re: My coreXY design is progressing to the build stage July 22, 2018 10:43PM |
