Re: My coreXY design is progressing to the build stage August 08, 2016 05:09AM |
Re: My coreXY design is progressing to the build stage August 08, 2016 08:37AM |
Kasahabo
First, you mention using 24mm by 8mm linear rails. Where did you purchase these? If they are something that you got second hand, would an acceptable substitute be found on the Alibaba web site?
Kasahabo
Second, you are using a 9mm wide timing belt. What is the pitch the belts. Lastly, The pulleys that are mounted to your steppers. How many teeth do they have.
Re: My coreXY design is progressing to the build stage August 09, 2016 05:44AM |
Re: My coreXY design is progressing to the build stage August 09, 2016 12:45PM |
Re: My coreXY design is progressing to the build stage August 09, 2016 02:47PM |
Re: My coreXY design is progressing to the build stage August 09, 2016 03:41PM |
Re: My coreXY design is progressing to the build stage August 10, 2016 12:11AM |
n8bot
One thing you'll want to be aware of, is that the corex/y algorithm approximately doubles the resolution of your steppers, so your 100mm/s move is actually 50mm/s in corexy space. I think 1.8 degree steppers would be fine if you find the speed is too limited with 0.9.
Re: My coreXY design is progressing to the build stage August 11, 2016 01:58PM |
), I was just pointing out that being able to move the 0.9 at "100mm/s" in real space, it will equate to a slower actual feedrate when printing. Just something to be aware of. It was one of the things I considered when thinking about the corexy solution: 1.8 degree steppers could be sufficient resolution, due to the way corexy increases the resolution.
Re: My coreXY design is progressing to the build stage August 11, 2016 02:00PM |
Re: My coreXY design is progressing to the build stage August 13, 2016 05:09PM |
Re: My coreXY design is progressing to the build stage August 14, 2016 11:22PM |
Re: My coreXY design is progressing to the build stage August 16, 2016 05:20PM |
Re: My coreXY design is progressing to the build stage August 16, 2016 05:54PM |
Re: My coreXY design is progressing to the build stage August 17, 2016 01:19AM |
hobbymods
Fully agree with supporting the pulley axles top and bottom.
Are you using precision shoulder bolts there?
hobbymods
Have you considered coming up from below with the steppers?
I'm going to mount mine underneath and make some kind of bearing/housing to hold extended shafts coupled onto the stepper shaft. Once I've got it all right I might even order steppers with longer shafts to eliminate the coupler.
Re: My coreXY design is progressing to the build stage August 17, 2016 03:52AM |
Re: My coreXY design is progressing to the build stage August 24, 2016 12:26PM |
Re: My coreXY design is progressing to the build stage August 24, 2016 01:23PM |
Re: My coreXY design is progressing to the build stage September 25, 2016 10:39PM |
Re: My coreXY design is progressing to the build stage September 26, 2016 02:52PM |
the_digital_dentist
Something else occurred to me. I have been planning to build the CoreXY machine's Z axis with as much as 1 m of travel. The problem, of course, is that the machine would be very tall and a little difficult to transport to places like the Maker Faire. That got me thinking that since the coreXY mechanism is modular, I could build two different assemblies, one with a short and one with a long Z axis and then move the coreXY module between them. If the controller board goes with the coreXY mechanism, the Z axis assemblies would only require connection of the Z axis motor and maybe the Z axis limit switch(es) to the controller. Hmmmm.
Re: My coreXY design is progressing to the build stage October 01, 2016 10:53AM |
Re: My coreXY design is progressing to the build stage October 01, 2016 11:08AM |
Re: My coreXY design is progressing to the build stage October 02, 2016 08:47PM |
Re: My coreXY design is progressing to the build stage October 05, 2016 05:53PM |
Re: My coreXY design is progressing to the build stage October 12, 2016 05:30PM |
Re: My coreXY design is progressing to the build stage October 12, 2016 06:54PM |
Re: My coreXY design is progressing to the build stage October 19, 2016 01:20PM |
Re: My coreXY design is progressing to the build stage October 20, 2016 12:12AM |
Re: My coreXY design is progressing to the build stage November 07, 2016 05:09PM |
Re: My coreXY design is progressing to the build stage November 07, 2016 05:54PM |
Re: My coreXY design is progressing to the build stage November 07, 2016 07:14PM |
