extruder ripples in outer wall
Posted by ekaggrat
May 04, 2016 03:18AM
or my corexy i tried a direct drive extruder with a mk8 hobb . I am getting these wierd ripples in the prints. ( the rippples are visible in the plan like inconstant extrusion. The steps per mm for the motor are right, the hot end is new and not clogged. the nozzle is 0.5mm so the force needed to extrude is not so much ( u can easily push with 2 fingres ) . Up until now i have been using geared extruders and never had this problem
I tried 2 different motors and drivers ..
motor 1 :
12v
27 ohm
40mm nema 17
dont have any more details
motor 2
6 v
7.5 ohm
7.5 mh
0.8 amp
drivers :
1 drv 8825 in 1/16 mode
2 a 4988 in 1/16 mode
motor 1 works better with drv 8825 but has the ripples like in the pics, with the a4988 the ripples are double the amplitude( deeper and higher )
motor 2 works better with a4988 but again with the same ripples as the pics . With the drv 8825 the ripples are doubled
controller :
ramps 1.4
drivers for x and y sd 6128 in 1/32 mode
hot end e3d v6 with 0.5 mm nozzle
print z resolution 0.25
firmware repetier ( downloaded from online configuration wizard )
steps per mm for x, y : 160
steps per mm z : 400
steps per mm e : 140
any idea why this is happening ?
i did the following tests
printed with ALL DIRECT DRIVE MK8 ).4 nozzle e3d
a4988 stepper drivers at 0.8A ... ripples exist
drv 8825 1/32 0.3A-0.8A
sd 6128 1/32 0.8A
Then I did tests with a 1:3 geared extruder with mk8 hobb 0.4 e3d nozzle
Last i printed with twisting the belts so that the back side of the belt goes over the pulleys
I even tried two separate hot ends and two separate power supplyies . One a 6 Amp and the other a 30 AMp
the ripples exist in all prints..
they are least with the belt reversed and the print with a flow ratio of 150%
It looks like a under extrusion issue ( like on other forums ) but the measured extrution with is coming to 0.44 mm and the specified width is 0.4mm (auto in slic3r)
a4988
sd 6128 at 1/32 and 0.8 A
geared extruder with belt revered on pulley and sd 6128
[lh3.googleusercontent.com]
detail
I am stumped that the frequency of the pulsing is same for the direct and the geared extruder.. If it was the extruder creating the problem the frequency would vary with the gearing of the motor. Reversing the belts and increasing the flow helps but doent remove it completely
firmware : repetier
slicr : slic3r 1.1.7
Any guesses whats going on?
thanks
Re: extruder ripples in outer wall
May 05, 2016 07:12AM
Hi Ekaggrat,
I followed the link from the "what causes..." thread. I don't think this is the drv missing steps problem that the diodes can help with. The lines in your photos always seem to be vertical, where as the missing steps problem produces diagonal lines. The slope of the lines changes with extrusion volume because it's tied to the rotation of the extruder. The fact that your lines always seem to be vertical suggest it's something to do with the XY motion mechanics.
May 05, 2016 08:48AM
You increased the mass carried on the carriage, perhaps this s a result of that. Does it get better printing slower/lower acceleration? Is the attachment of the direct hot end rigid? Hanging out a whole lot more from the attachment point than before (greater moment).
May 05, 2016 08:55AM
Are the ripples on 2mm spacing? I'd be suspicious of the small diameter smooth idlers you are using on the toothed side of the belt path. Replacing those with toothed idlers would be worth a try.
May 05, 2016 10:44PM
Deltas have this problem all the time. My small delta has this problem a lot more than my large one. I don't think that it's extruder related, it's more likely positioning error, more specifically, the frame resonating at certain speeds of X/Y positioning.
You can:
1) Use 0.9 degree steppers instead of 1.8 degree steppers
2) Use 32 bit microstepping instead of 16
3) Slow down print speeds
4) Ensure that as little of the frame resonates as possible
5) Add the 'diode hack' to your stepper drivers
Good luck.
May 06, 2016 03:51AM
@james
I tried the reversed belts but no change.
@nebbain
slowing down does help
the drivers are already 1/32
the frame is very rigid so i dont think that is resonating. I amnot sure if the cantilever bed causes this
May 06, 2016 04:32AM
Check out this thread for more info:
[forums.reprap.org]
May 06, 2016 08:10AM
Try tweaking the extruder motor current.
August 11, 2016 02:11AM
as i see the same ripples in my prints i wanted to ask if you ever found a solution for that problem?
Regards
August 11, 2016 02:22PM
The only time I've seen this is with very low extruder steps per mm (80-100) and is a pulsing extruder but its odd that it still happens with gearing. I get very small ripples on the kossel mini with e3d titan using 3:1 gearing, 290 steps/mm but I always assumed this was frame resonance maybe it's still pulsing. Maybe try 5:1. I got this on my corexy with mk8 extruder but not anymore with flex3drive it's using 1500 steps/mm at 40:1 gearing and 1/8th microstepping.
Edited 1 time(s). Last edit at 08/11/2016 02:23PM by DjDemonD.
Simon Khoury
Published:Inventions
August 12, 2016 03:11AM
the_digital_dentist
Yes, I was thinking that too...
I've seen something written in the past regarding too much extruder current (or too little?) doing this.
August 12, 2016 05:32AM
i tried changing the current but nothing helped. I finally found a sweet spot at 40mm/s perimeter speed which shows minimal ripples. what i figured was that the ripples showup in models with more segments like in curved surfaces. I think it has to do something with the acceleration and de acceleration of the motor when going though the segments. I have been using the printer since last 3 months and printing a lot.. I gave up fixing the problem as i can't seem to find the cause .Maybe it is a combination of mechanical issues and firmware issues doing wierd things. I will soon be upgrading the xy motion to linear rails and then see if the extra stiffness helps... My printer can print a lot faster if only the damn ripples wouldnt show up at higher speeds!!!..
August 12, 2016 06:35AM
I have some suggestion of a test you can do:
The idea of the test is to check if the problem is with the extruder or x, y motions.
print a 20/10 mm test cube with a 45 degree rotation, this will allow to print all the outside wall using only one motor.
if you still have ripples, them is probably extruder problems.
August 12, 2016 11:33AM
do you have a fan on the part ?
