Anonymous User
Re: Is Nema17 1.2A too weak for 3d printing? May 17, 2016 02:40PM |
Indeed a safer approach than a hotbed powered from the main supply. To make it even safer, don't you use a thermal fuse ?Quote
VDX
realthor
VDX
... I've powered my first heated bed simply with a bare [email protected] transformator (which gives roughly 16 to 14 Volts AC depending on load) and switched the current with an AC-SSR.
This can be done with any available transformator (found several from [email protected] to [email protected] in my scrapery), but for heated beds I'll avoid output powers above 50 Volts and currents greater than 20 Amps for safety reasons (and it's hard to find proper connectors).
You know what you're talking about, I couldn't understand half of it. I would venture in electronics but I don't know if it's smart to do that as a beginner. I think I'm going with an ATX power source (I have one around) and see from there. I believe there are good tutorials around the web how to use that (i've seen a good one but I can't seem to find it).
Here's the ATX one I can use:
[attachment 78241 IMG_20160517_122534.jpg]
... here's a sketch to show the driving of a heated bed with a transformer and switching it with an AC-SSR (solid-state-relay):
[attachment 78242 HB-Test.png]
Re: Is Nema17 1.2A too weak for 3d printing? May 17, 2016 04:58PM |
Admin Registered: 15 years ago Posts: 13,765 |
Re: Is Nema17 1.2A too weak for 3d printing? May 17, 2016 05:02PM |
MKSA
realthor
@MKSA you're not helping and this type of attitude is only perpetuating a tensed environment. What about some common sense in these forums ...
Tensed ? No, just funny ! Common sense ? Not very common, reading your non sense !
I am just wondering, do you know nothing about everything or everything about nothing ?
Re: Is Nema17 1.2A too weak for 3d printing? May 18, 2016 05:45AM |
cozmicray
ikcl There you go again
What are timing belt issues doing in a topic about NEMA 17 current draw?
BTW the more contact (wrap) of a belt on a pulley is better for power transmission
keeping in mind that the belt has to be able to withstand a sharp bend by a small diameter pulley.
Re: Is Nema17 1.2A too weak for 3d printing? May 18, 2016 05:52AM |
MKSA
I know who is who !
I worked in a nut case asylum and I can identify the real Washingtons from the fake ones !
Re: Is Nema17 1.2A too weak for 3d printing? May 18, 2016 05:57AM |
lkcl
cozmicray
i've sent you a private message, cozmicray.
... and that the load on the belt is distributed across less teeth if it is a smaller diameter pulley, resulting in more (localised) stress on it. also, the higher the angle the belt turns through, the larger the inertia of the actual belt's material to contend with as it is "flung" round the belt. at low speeds this effect will not be such a problem, but at higher speeds it will be. also, belts on smaller gears will have each tooth on the belt being bent through a sharper angle. at some point, that bend isn't going to be a bend, it's going to be resistance. that will result in both vibration of the belt as well as stretch it in irregular ways in proportion to how engaged one tooth is as it comes on (and off) the belt. if this isn't clear, take it to the extreme and imagine what would happen if there were only 5 teeth (or even 4) on the belt. the belt would be a "square wheel" in effect, and if you saw what they did with mythbusters when they made square wheels for a car, they had to get it up to speed and *rely* on vibration to smooth out the motion of the car... but it was still a hell of a rough ride. and a very funny episode.
anyway, so there are a heck of a lot of good reasons why you should think twice about using small gears and angles approaching 180 degrees. but, y'know what? if it works, it works.
MKSA
Re: Is Nema17 1.2A too weak for 3d printing? May 18, 2016 07:30AM |
Koko76
It's almost like they wrote a document, to which you keep referring but refuse to read. In that document they call out a minimum recommended pulley size for GT2 pulleys, and surprise it happens to be 16t. Same document talks about speed as well. It's on the website (www.sdp-si.com), and available freely. Perhaps you might consider reading it before dispensing theory.
Re: Is Nema17 1.2A too weak for 3d printing? May 18, 2016 07:39AM |
I find a lot of noise is generated by people who talk without knowledge. I don't make recommendations without a foundation of knowledge. I'm sorry if you take it personal that you get called out for not knowing what you are talking about. I would advise that you refrain from uneducated comments, and then your problem will be resolved.Quote
lkcl
Koko76
ok so that's great! thank you for bringing to my attention important information that i can use to improve my own printer as well as pass that knowledge on to others in this quite small and exclusive community, in the future.
now, why did you have to bring that knowledge to our attention in a way that made yourself look better than anyone else? is it *absolutely* necessary for you to be sarcastic at other people's expense, denigrating to others, and to place yourself as being better than other people *at the same time* as providing really, really useful information and corrections to other people's lack of knowledge?
does doing that make you feel like you are a better person? what, specifically, do you gain from such clear demonstrations of anger and resentment? and why would you expect us to have to work harder than it should be, to filter out the noise that you are making in order to find the valuable information that you've provided?
Re: Is Nema17 1.2A too weak for 3d printing? May 18, 2016 01:38PM |
Koko76
lkcl
Koko76
Again, this is freely available stuff that can be found (as I did when I looked for it many years ago) online. Instead of writing a multi page report on what you think is right try searching for already done work. You are adding noise on already settled subjects. Most of the things discussed here are settled science. Despite people's ego most if my everything discussed on these forums are rehashes of decades old tech, much of it documented if you can be bothered to research it.
Re: Is Nema17 1.2A too weak for 3d printing? May 18, 2016 03:10PM |
lkcl
watch out for that, though: *don't* wrap the corexy belt through 180 degrees round GT2-16t's. put an idler bearing in (or two) so that the belt loops back on itself through 90 degrees instead.
Re: Is Nema17 1.2A too weak for 3d printing? May 18, 2016 09:42PM |
Re: Is Nema17 1.2A too weak for 3d printing? May 19, 2016 01:56AM |
Re: Is Nema17 1.2A too weak for 3d printing? May 19, 2016 09:05AM |
Re: Is Nema17 1.2A too weak for 3d printing? May 19, 2016 01:06PM |
