Re: Rugged CoreXY May 31, 2016 10:00AM |
lkcl
hobbymods
Sorry....Australian middle aged male....can't help you with deep and meaningful philosophy, but can I interest you in a sarcastic comment?
arrhh yeahhh!
[www.youtube.com]
Re: Rugged CoreXY June 01, 2016 03:26AM |
Re: Rugged CoreXY June 01, 2016 03:58AM |
lkcl
hiya hobbymods, welcome to the forum. some links to analysis that may help,
- look at what the_digital_dentist did, with son-of-megamax, his printer design is extremely comprehensive and accuracy is extremely good.
- [forums.reprap.org] for an analysis as to why you should use dual rails/rods and triple lead screws. dual screws is not enough. multiplying up the number of rails does not "fix" the problem of bed rotation about [only 2] screws, it just minimises it. triple lead screws is GUARANTEED to stop rotation, the rails (only 2 needed) stop lateral movement. anti-backlash nuts on all 3 lead screws and you're laughing.
- [forums.reprap.org] you're using rails but is there any rotation in the rail carriage part (about the x y *or* z axes) i.e is the linear carriage *perfect*? if not, take a look at rods instead, set up as described in the thread there. experimental idea so YMMV, other people may have better advice here.
- [forums.reprap.org] follow the belt layout outlined here. keep the entirety of each belt in the same plane, offset them slightly (staggered heights). make sure that the belt goes *exactly* through right-angle turns, do *NOT* be tempted to do 89.5 or anything like that. use 2 bolts in the x-ends and stagger the bearings so that the belts come in on *exactly* the same centre line which should be along the centre of gravity of the carriage... and the hotend should be exactly on that centre of gravity.
- above a 300mm span don't use 8mm rods. anywhere. they bend too much.
- i got a meanwell LRS-350-24 prices are very good, they're also quite thin which is nice. but that was for a 200x200 printbed, you may want to get a mains-operated bed heater then the LRS-350-24 would do you fine... yep that's what you're planning. don't bother with 12V any more. make sure the fan from the PSU points *away* from the printbed...
- make sure you use 0.9 degree per step NEMAs, dc42 is extremely knowledgeable about this, you get far better accuracy and can do up to 1000mm/sec with them on a corexy.
- go for a Duet NG, again, dc42 knows what he's on about, REALLY don't bother with RAMPS or anything that uses arduinos.
- put fans pointing at the Duet's stepper ICs.
- consider a Flex3Drive, they are a combination of the best of both the bowden and direct extruder worlds *and then improve on that even more*. mutley3d is an extremely knowledgeable engineer.
- [forums.reprap.org] don't for god's sake bother with a bowden, they're basically shit. i know people say "oh i have no problems at all" - these people have never had a Flex3Drive. the reality is that bowden tubes are not robust, there's far too much to go wrong, they waste filament, and every single one of the problems i listed on that post was something i encountered MULTIPLE times over an extremely intense and very annoying period of 3 weeks. but, it boils down to this: as an engineer, retract of *five* millimetres as compared to 1.5mm for a flex3drive or direct drive extruder really should tell you everything you need to know.
- based on the same analysis as for the z bed i came up with a trick to use 3 springs and 2 fixed screws for bed-levelling. just as in the z-bed analysis the 2 fixed bolts stop rotation and lateral movement, and the 3 springs allow bed-levelling. if you used smooth rods (or part-threaded M3 bolts) and got the drill holes to good tolerances you could ensure that the printbed really really does not move laterally, i have a tiny amount of potential lateral movement because the 2 fixed bolts sit in slightly oversized holes. something for me to fix later.
- enclosed you will not be able to use PLA for parts, they will melt. find a material that has a high enough temperature or just go all-aluminium.... i think you said that's what you planned
- E3Dv6 i recommend going immediately to a volcano upgrade, unless you really really have a need to use 0.3mm nozzles or below.
- i use mechanical endstops and find them to be fine, but i have no experience with anything else yet so cannot make a comparison.
errr that's all i haven't covered everything, as i am learning as i go along, so have not commented on things i don't know about (or have said "i don't know" if i have). you'll like the Duet. it has ethernet and a built-in web interface, and you can get an LCD for it as well.
there's plenty of great people here who are knowledgeable. there's some angry ones, stressed-out ones (including me) and some inexperienced ones too, but that's okay, we're all learning. enjoy
Re: Rugged CoreXY June 01, 2016 05:07AM |
Vigilant
From my experience in my recently build printer, if you're going linear rails you'll probably do fine. I got the CoreXY up and running at first try without any hitch.
The hardest in my opinion is the Z axis. Took me quite some time to get this up to where I want it to. Cantilevered bed will work but you have to move extra slow so that the bed end doesn't oscillate too much.That's not really a problem because the Z axis only needs to move 0.1mm/0.2mm layer height each time. Moving faster won't improve your print time.
If you're using 2mmlead lead screw, the reduction is good enough for you to carry 3-4 kgs of load using a typical nema 17 motor.
The Z axis have to be very consistent and accurate and it doesn't take much to create Z Wobble artifacts,
Re: Rugged CoreXY June 02, 2016 10:02PM |
hobbymods
Vigilant
Yes, I'm definitely on the same page.
As I mentioned before, my business runs Zortrax M200's which are renown for print quality but sometimes unpopular due to its closed software and limited materials/options (but the best option for a business knocking out ABS end user parts).
It runs a cantilevered shelf with 2x 12mm rods and 1 lead screw and gives very good Z resolution.
I am seriously considering buying one of those busted arse Wanhao Zortrax clones and gutting it (which is all they are good for) and doing my "lift off" corexy gantry on top of the box as well as converting the Z rods to precision rails.
A cursory glance holding my E3DV6 hotend in place suggests I could get the full 200x200 build volume as well as 240-260mm height. A good improvement on the approx 180x180x180 it gives with the H gantry.
By the time I muck about building a water jet cut box and buy all the bits, I'm sure to have spent the 1200 bucks that a D6 costs.
Then there's the fact that I get steppers, power supply and display, and I can sell the motherboard and complete hot end as well.
Could be the way to go...
This might be a better chance of success with a very respectable build volume, and a much less complicated Z axis for a first time around.
Re: Rugged CoreXY June 03, 2016 09:25AM |
Vigilant
hobbymods
Vigilant
If you're going through that route, you might want to consider the ultimaker clone frame.
[www.aliexpress.com]
Don't purchase the whole printer set, I think it is crap. Just the frame and then figure out a way to mount the aluminium extrusion within the frame
OR build everything again using your own components. This guy here who got both ultimaker and the ultimaker clone claimed better printing quality after using custom components on the ultimaker clone.
[www.youtube.com]
One thing after building my corexy printer, is that although it functions pretty well, it is not the prettiest to look at. In fact I'm right now trying to figure out how to make it look prettier.
Re: Rugged CoreXY June 03, 2016 09:29AM |
Re: Rugged CoreXY June 03, 2016 09:36AM |
the_digital_dentist
Most people building printers focus on the mechanism and don't consider enclosure or placement of the electronics or wiring until after they've built the mechanism. I see a lot of people trying to shoehorn the mechanism into the smallest possible space which usually means the frame gets used as part of the linear motion mechanism. That makes enclosing the printer a problem.
I've been designing a CoreXY printer with a 250 mm square bed that will be easily encloseable. It is going to have about 600 mm x 600 mm footprint which sounds ridiculous compared to the bed size, but calculate how big the enclosure has to be for a printer that uses the frame as part of the linear motion system and you'll quickly get to the same sort of size. Most of the CoreXY machines you see have open tops with the extruder cable and filament guide making a big arc that stands up over the top of the machine. How do you enclose that? You can try to keep the height down using a drag chain laid horizontally so it makes a big loop, but it's hard to feed filament through it. Maybe the machine has to be made taller...
It's always best to plan this stuff in advance. Resisting the urge to start building as soon as you get the mechanism figured out is hard to do, but worth it in the end.
Re: Rugged CoreXY June 03, 2016 11:04AM |
Vigilant
hobbymods
Vigilant
[www.youtube.com]
Re: Rugged CoreXY June 03, 2016 01:27PM |
hobbymods
Looking at a 500x500 cabinet footprint I can most likely get a 300x300 platform with a proper corexy gantry and 3 ballscrew Z axis.
Re: Rugged CoreXY June 03, 2016 06:13PM |
deckingman
hobbymods
Yes, that's what I thought too but I've had to increase the size from to 600 x 600 and with that I'll get 320 on the Y and 340 on the X maximum. Mind you, I'm planning mine around a Diamond hot end which, because it has 3 heat sinks sticking out at about 27 degrees, makes it a wide beast in all directions. I'm also planning to sling it between 2 X rails so that adds width and takes away from the maximum Y travel. Also, having all the motors and pulleys inboard so that it could easily be enclosed, takes away axis travel. I guess using a "sensible" hot end with a smaller footprint then 300x 300 platform inside a 500 x 500 frame might just be doable but it'll be tight with everything mounted inboard.
I'm also planning to use 3 lead screws but with 2 linear guides to keep the bed in position so that the screws only provide lift and can "float about". Initially, the screws will be driven by a single stepper and connected by a belt. DC42 has it on his list to do automatic bed levelling for the Duet with 3 screws and individual steppers and I'm planning the design so that I could easily change over to that at some time in the future.
Re: Rugged CoreXY June 04, 2016 06:20AM |
hobbymods
deckingman
hobbymods
Yes I'm looking at 2 parallel X rails as well, and also 2x rail on the Z axis at the back with a floating screw (giggity) between them and one on each front corner.
Mine's all based on 15mm precision rails.
I've got a simple way that I've managed to locate the motors outside of the enclosed section, which looks like it might be a good thing, and a way I'll run the 2 belts on different levels to avoid the crossing/twisting.
Of course it's not real until it's built.
Re: Rugged CoreXY June 04, 2016 08:44AM |
Re: Rugged CoreXY June 04, 2016 10:28AM |
Mikk36
Out of curiosity, those of you planning or already having built the 3-ballscrew with a single stepper Z-axis systems, how are you attaching the pulleys to the ballscrews?
Are you just buying a cheap trapezoidal/acme leadscrew with multistart and then machining it to have a smooth bore to attach the pulley to or is there another trick to it?
Sure, one option would be to get the ballscrews from Misumi (with the ends already machined), but at ~60-70 € a piece it seems a bit too expensive.
Re: Rugged CoreXY June 04, 2016 06:40PM |
Mikk36
Re: Rugged CoreXY June 05, 2016 04:03AM |
Re: Rugged CoreXY June 05, 2016 05:23AM |
deckingman
Well I've order some Chinese lead screws, 8mm dia 1mm pitch single start. My thinking is that multi start and/or 8mm pitch would be too course for the z axis - we need resolution not speed.
Re: Rugged CoreXY June 05, 2016 06:46AM |
the_digital_dentist
deckingman
I have 1/2" lead screws (yes, imperial!) in the Z axis of my printer and a 20/42 pulley reduction and get flawless prints. You're going to print in 100 um (or more) layers. Why on earth would you need 3200 steps per mm in the Z axis?
Re: Rugged CoreXY June 05, 2016 08:59AM |
the_digital_dentist
deckingman
Re: Rugged CoreXY June 05, 2016 09:25AM |
1/16 microsteppingQuote
deckingman
the_digital_dentist
deckingman
Sorry, don't understand your maths. 1mm pitch single start means 1 revolution is 1mm in height. I revolution is 360 degrees. 1 motor step is 1.8 degrees so 360 degrees is 200 steps making it 200 steps per mm. How did you make it 3,200?
Re: Rugged CoreXY June 05, 2016 11:21AM |
hobbymods
So you've got 20t pully on the stepper then 42t on each of the lead screws?
That would be a fair amount of reduction in itself I'd imagine.
Any tips on my belt/pulley questions above?
Re: Rugged CoreXY June 05, 2016 11:28AM |
Re: Rugged CoreXY June 05, 2016 11:34AM |
the_digital_dentist
hobbymods
Re: Rugged CoreXY June 05, 2016 11:41AM |
hobbymods
A ridiculously basic mock up with no money out but 12 bucks worth of pine square dowels.
Where can I get the following?
1. Idler pulleys, including toothed/plain/single/double. Maybe some cheapies for mockup, got a bunch of ebay bits coming already. Certainly nothing I'd use in the end. So maybe some ebay and quality sellers if you know them.
2. Some sort of nema17 size bearing mount/yoke/extension wit a 5mm bearing that I can bolt on the opposite side of the plate to the long shaft motor, to add some support as the pulley will set high and I don't want it swinging unsupported. I can print something in PC, but a nice ally one off the shelf would be ideal.
3. What sort of belt would be suitable? Don't want to blindly go with 6mm GT2 on this one. Thinking more like an 8-10mm belt, and am open to different types if there's something better.
Re: Rugged CoreXY June 05, 2016 05:18PM |
Re: Rugged CoreXY June 05, 2016 05:35PM |
Re: Rugged CoreXY June 05, 2016 07:15PM |
deckingman
...Anyway, the reason for using 1mm pitch is that (as I mentioned), I'm planning on using the lead screws for bed levelling. It may not work but my thinking is that I have 3 point lifting so why not use it for bed levelling as well?
Re: Rugged CoreXY June 06, 2016 03:12AM |
the_digital_dentist
deckingman
If the bed is going to be heated, you're still going to stand it off an undercarriage that's connected to the lead screws. Those fine pitch stand-off screws can be used to set the bed level when you first set up the machine.
Re: Rugged CoreXY June 06, 2016 05:40AM |
Re: Rugged CoreXY June 06, 2016 06:44AM |
hobbymods
I'm not trying to confirm or change the principles of corexy, just looking at it in the flesh in my application.
