Re: Rugged CoreXY June 12, 2016 09:24PM |
Re: Rugged CoreXY June 16, 2016 11:32PM |
Re: Rugged CoreXY June 17, 2016 07:43AM |
Re: Rugged CoreXY June 17, 2016 07:53AM |
LarsK
On that printer the idlers on the Y axis are cantilevered. That is, they are not supported from both top an bottom. You see the screw comes through what looks like a 5mm plate and that and the clamping should hold the idlers in place.
I have come to believe that The Digital Dentist is right in his proposal where he supports all the idlers both top and bottom. It does make installation a bit more of a pain because you can't slip on the belts from on-top, but I believe it is the right thing and something I will myself be doing on all future builds.
Re: Rugged CoreXY June 17, 2016 08:20AM |
LarsK
Re: Rugged CoreXY June 17, 2016 08:51AM |
hobbymods
Don't like the jukebox look cosmetically, but quite a few similarities in my gantry design here.
[www.kickstarter.com]
Re: Rugged CoreXY June 17, 2016 08:55AM |
Re: Rugged CoreXY June 17, 2016 05:48PM |
Re: Rugged CoreXY June 20, 2016 05:38AM |
Re: Rugged CoreXY June 20, 2016 12:19PM |
Re: Rugged CoreXY June 20, 2016 02:09PM |
Re: Rugged CoreXY June 30, 2016 06:56AM |
Re: Rugged CoreXY June 30, 2016 07:29AM |
Re: Rugged CoreXY June 30, 2016 08:42AM |
LarsK
Wow, those printed parts you have are so nice. I have seen a lot of printed parts on these forums, and it is usually only when people really really try hard they can make something like that... And you just made it for trial assembling...
The brown part that holds the fan, how did you print that? Support material? I am afraid that it will crack because you have the layers going in that direction and a thin square area where it comes out. Are you running high infill or what are your thoughts about that?
Re: Rugged CoreXY June 30, 2016 09:51PM |
Re: Rugged CoreXY June 30, 2016 10:23PM |
Re: Rugged CoreXY July 01, 2016 03:47AM |
Re: Rugged CoreXY July 01, 2016 04:11AM |
Re: Rugged CoreXY July 01, 2016 04:25AM |
Re: Rugged CoreXY July 01, 2016 09:40AM |
Re: Rugged CoreXY July 01, 2016 04:06PM |
LarsK
I get how the plug works on that, but what cable will you use with that?
Re: Rugged CoreXY July 01, 2016 07:33PM |
Re: Rugged CoreXY July 01, 2016 08:27PM |
Re: Rugged CoreXY July 01, 2016 08:36PM |
the_digital_dentist
Have you checked to see if any air comes out of the fan nozzles? Axial fans don't work worth a damn against any sort of back pressure, and such nozzles create back pressure.
Re: Rugged CoreXY July 01, 2016 08:46PM |
Re: Rugged CoreXY July 02, 2016 01:46AM |
LarsK
Hey,
Looks really nice but seems a lot of work if you don't do pla printing. You for example said those parts you printed for the mock up is abs?
Are all those fans just for pla or is there something about printing I am completely oblivious to?
Re: Rugged CoreXY July 03, 2016 09:01PM |
Re: Rugged CoreXY July 04, 2016 06:20PM |
LarsK
Interesting.
I really only have experience with ABS. I never got into PLA. Giving up all the advantages of ABS just because PLA is easier and faster just seems wrong. Some time back a guy printing Nylon threw that exact same argument in my head
That said, my experience is that even an open window putting a breeze on the print can give radical different results. A continuous thin wall with some widths and heights is only possible if I reduce the speed to prevent putting too much material before the material has cooled down and settled.
For me the next step in 3d printing is making a heated enclosure to avoid those problems. Heating enclosure as a temperature regulated space that can reach above 60C.
Now you come an tell me you put 20% fresh air blowing on the print and you haven't with one word mentioned heated enclosure even as you talk about exotic materials I have yet to even see real life.
What is your thoughts about that? You haven't even mentioned putting enclosure on the printer?
Re: Rugged CoreXY July 04, 2016 09:25PM |
Re: Rugged CoreXY July 05, 2016 03:53PM |
the_digital_dentist
I heat my printer's enclosure the same way. It just happens to get to 45-50C from the bed heater. I discovered that when it was in my cold basement this winter it didn't quite get warm enough, so I plan to add a supplemental heater. I'll probably use the smoothieboard controller to regulate the enclosure temperature using an unused thermistor input and MOSFET output to switch the heater on and off.
I am designing and building a coreXY machine right now and like my other machine, it is being designed to be enclosed/heated from the start.
