end stop switches with duet board May 31, 2016 10:43AM |
Re: end stop switches with duet board May 31, 2016 12:46PM |
Re: end stop switches with duet board May 31, 2016 12:51PM |
Re: end stop switches with duet board June 01, 2016 08:14AM |
Re: end stop switches with duet board June 01, 2016 09:28AM |
Re: end stop switches with duet board June 01, 2016 01:06PM |
appjaws1
Thanks you for the help, I now have the end stops wired correctly
I had to change the homey to be G1 Y240 F3000 S1, it was G1 Y-240.If I home Y I cannot then move in the negative direction
I have M574 X1 Y1 Z1 S1 in my config file but am not sure if that is correct seeing that Y end stop is positive.
The Z endstop will also be triggered when the bed is high, so again not sure how to let the firmware know this.
Re: end stop switches with duet board June 02, 2016 05:24AM |
Re: end stop switches with duet board June 02, 2016 06:36AM |
Re: end stop switches with duet board June 02, 2016 08:03AM |
Re: end stop switches with duet board June 02, 2016 12:13PM |
Re: end stop switches with duet board July 06, 2024 12:38PM |
Re: end stop switches with duet board July 09, 2024 01:56AM |
