Why does this design of pulley used less in Corexy
Posted by faith
June 02, 2016 03:33AM
Hello everyone! I'm a new designer of Corxy Machines.And now the arrangement of the pulleys makes me confused.as show in picture,why does this design of pulley used less in Corexy i have ever seen.
Edited 1 time(s). Last edit at 06/02/2016 03:34AM by faith.
Re: Why does this design of pulley used less in Corexy
June 02, 2016 04:13AM
First, the image is the design of a hbot setup and not a corexy.
The corexy is a "evolution" from the hbot to solve a twist problem the carriage suffer because the belt push from the same side. But If you use a rigid frame and good linear movement you can go with this setup.
PS: you must have 2 belts, all 4 belt end´s must be secured in the carriage.
From the image it appears you have only one big belt, and i assumed is a error when you have made the image.
If is not a error, them it will simply not work.
Edited 3 time(s). Last edit at 06/02/2016 04:34AM by filipeCampos.
June 02, 2016 06:07AM
filipeCampos
No, 2 belts are not needed in an H bot design. One big belt is exactly how it works, and there is not an error in the image.
June 02, 2016 08:00AM
Koko76
filipeCampos
correct, my mistake..
