Voron 3D printer uses just one bearing per XRod... is that a smart choice? June 11, 2016 07:20PM |
Re: Voron 3D printer uses just one bearing per XRod... is that a smart choice? June 11, 2016 08:09PM |
Re: Voron 3D printer uses just one bearing per XRod... is that a smart choice? July 17, 2016 05:14AM |
Re: Voron 3D printer uses just one bearing per XRod... is that a smart choice? July 17, 2016 01:46PM |
DjDemonD
I have to say all this talk about play in bearings and nozzle centre of rotation is very nice in theory but my corexy has vertically stacked x rods and the nozzle is wobbly if you stick your finger on it and wobble it. It does not translate into poor print quality even at 175mm/s average speed it doesn't wobble when printing. So whilst a rock solid nozzle is desirable it is measurably not necessary.
Re: Voron 3D printer uses just one bearing per XRod... is that a smart choice? July 17, 2016 02:01PM |
Re: Voron 3D printer uses just one bearing per XRod... is that a smart choice? July 18, 2016 02:57AM |
That looks a lot like a sudden temperature change, for example from a shorter time to print a single layer.Quote
LarsK
Totally ignoring that; This picture is of a part I made with a hotend that could really wobble, it is my believe that the deep lines you see of a single layer offset is a consequence of this. As long as the nozzle makes the same movement all the time it is displaced the same. For this reason part of the print looks OK. Then when it moves from one contour to another it "resettles" and gets these offsets.
PICTURE OF PRINT
That is at least my hypothesis and I haven't seen these types of lines on my newer printers which have more firm hot-end supports. I should say that on the printer that made the above it was pretty grave. Both the mounting point of the belts was much above the center of rotation and the hotend much below.
Re: Voron 3D printer uses just one bearing per XRod... is that a smart choice? July 18, 2016 04:32AM |
Re: Voron 3D printer uses just one bearing per XRod... is that a smart choice? July 18, 2016 07:54AM |
Mikk36
LarsK
PICTURE OF PRINT
Re: Voron 3D printer uses just one bearing per XRod... is that a smart choice? July 18, 2016 07:56AM |
Re: Voron 3D printer uses just one bearing per XRod... is that a smart choice? July 18, 2016 08:10AM |
