Re: CoreXYNZ build August 06, 2016 12:50AM |
Re: CoreXYNZ build August 07, 2016 08:13PM |
Re: CoreXYNZ build August 08, 2016 08:41AM |
Re: CoreXYNZ build August 09, 2016 01:34AM |
Re: CoreXYNZ build August 09, 2016 02:04AM |
Re: CoreXYNZ build August 10, 2016 05:17AM |
Re: CoreXYNZ build August 10, 2016 05:35PM |
Re: CoreXYNZ build August 11, 2016 01:20AM |
hobbymods
I love the way you are giving so much attention to the alignment of the linear rails, I think it will pay off for you.
Hope you're going to use some nicer looking bolts in the end lol
Re: CoreXYNZ build August 11, 2016 06:21PM |
Re: CoreXYNZ build August 11, 2016 06:45PM |
Re: CoreXYNZ build August 11, 2016 09:54PM |
Calvinx66
It's looking good.
Well done. I am in the middle of drawing my iteration of the coreXY just now. as I draw i am searching for each component as I require them, I found these lovely commercial belt tensioners, I might just try them...
Automatic belt tensioners
Re: CoreXYNZ build August 13, 2016 04:33PM |
Re: CoreXYNZ build August 13, 2016 04:41PM |
Re: CoreXYNZ build August 13, 2016 09:25PM |
Re: CoreXYNZ build August 16, 2016 05:28PM |
Re: CoreXYNZ build August 18, 2016 12:47AM |
Re: CoreXYNZ build August 18, 2016 06:43AM |
Re: CoreXYNZ build August 19, 2016 01:38AM |
Cheers thanks for the kind words. The fuse is a Fuji Jet Tf158 Deg C 10A 250V S154 S3X1 C. What I was unaware of was that the body is live which I found when I did a insulation test on it. My plan was to mount it to the side of the bed in this aluminium block. So now my plan is to enlarge the hole for it and insulate it with some Kapton tape. So it is work in progress.Quote
Amoniak
Nice build!
Awesome that you keep the thread updated with pictures.
Questions related to the thermal fuse, what fuse are you using and how are you connecting it?
I'm thinking of adding something similar to my own build.
Thanks.
BR//Amoniak
Re: CoreXYNZ build August 19, 2016 07:48PM |
FA-MAS
Thanks. Curious about the bearing part too. Like the inside diameter of it, as well as the thickness of the internal track. Looks to be possibly a 5mm hole. Just wondering if a bolt head too big is going to bind it up.
RodF
Here you go. I can't seem to insert an image I will in my thread. Anyway inside diameter is 11.94mm, outside diameter is 18mm, inside flanges is 6.4mm, outside flange is 8.6mm.
FA-MAS
In reply to [forums.reprap.org]
RodF
Looks like I can fit the XY platform on the mill bed so I can get it flat. However I might investigate getting a piece of granite. Once I get the XY running nicely I will sort out a way of attaching it to the Z axis frame with out distorting it.
Smooth and toothed idlers arrived today. Now I can check the dimensions.
[attachment 80526 idlers.jpg]
Hi, was wondering if you might take a measurement of the bearings in your idlers for me. Specifically the inside diameter as well as the thickness of the innermost ring.
Re: CoreXYNZ build August 19, 2016 08:40PM |
Re: CoreXYNZ build August 21, 2016 04:35PM |
Re: CoreXYNZ build August 22, 2016 11:45PM |
Re: CoreXYNZ build August 24, 2016 03:25AM |
Re: CoreXYNZ build August 24, 2016 05:08AM |
Re: CoreXYNZ build August 24, 2016 11:49AM |
Re: CoreXYNZ build August 24, 2016 10:46PM |
dc42
That's going to be a very nice machine when it is finished! How easy or hard is titanium sheet to machine, and how expensive is it? Does it have any advantages in this application, apart for being lighter than steel but stiffer than aluminium?
The Duet WiFi has started shipping - which pre-order batch are you in?
Re: CoreXYNZ build August 25, 2016 01:27AM |
Re: CoreXYNZ build August 27, 2016 10:47PM |
Re: CoreXYNZ build August 28, 2016 10:34AM |
Re: CoreXYNZ build August 28, 2016 10:51AM |
