Re: CoreXYNZ build June 29, 2016 04:35PM |
the_digital_dentist
I'm not being negative, just trying to understand how you can use such a device to align a printer with the required accuracy and precision. If it works I'll buy a laser leveler, but every laser I've ever seen produces a relatively wide beam with indistinct edges - suitable for hanging pictures or framing a deck, but precision alignment?. Between that and the basic +/- 4 degree spec I can't see how it would be possible to perform an accurate alignment. If you have a technique that works I'd love to hear some details about it.
Re: CoreXYNZ build June 29, 2016 09:46PM |
Re: CoreXYNZ build June 30, 2016 07:32AM |
Re: CoreXYNZ build June 30, 2016 01:06PM |
Re: CoreXYNZ build July 01, 2016 07:32PM |
Re: CoreXYNZ build July 03, 2016 11:31PM |
Re: CoreXYNZ build July 04, 2016 09:04AM |
Re: CoreXYNZ build July 04, 2016 05:07PM |
Re: CoreXYNZ build July 04, 2016 09:29PM |
Re: CoreXYNZ build July 04, 2016 09:57PM |
Re: CoreXYNZ build July 05, 2016 03:21AM |
Re: CoreXYNZ build July 05, 2016 07:57AM |
Re: CoreXYNZ build July 05, 2016 08:09AM |
Re: CoreXYNZ build July 05, 2016 08:19AM |
Hmm I am tempted to get a Titan as I want a volcano block and some hardened steel nozzles. I thought I might seriously lighten this 80 tooth pulley and make an extruder. 4/1 or 5/1 with either a 20 or 16 tooth pinion.Quote
the_digital_dentist
It doesn't come with a motor. I've seen claims (not by E3D) that it reliably drives filament with just a 20 mm long pancake motor, but I have my doubts about it. I'm just using the old extruder's motor and it seems to work fine. I think it's a 35 mm motor.
Re: CoreXYNZ build July 05, 2016 08:29AM |
Re: CoreXYNZ build July 05, 2016 08:38AM |
For me it is about availability and freight costs to New Zealand (about as far away from anywhere that you can go) There was a local supplier of 2020 so I got 2x 5.8 meter lengths. The hardware is from China which for me is nearly localQuote
the_digital_dentist
I have never used 20mm extrusion but may give it a try at some point. The 1 1/2" or 40 mm stuff I use is industrial surplus that I buy at scrap yards for $2/lb, but it isn't always available when I need it or in the quantities that I might need. Does using all those corner blocks and hardware plus 20 mm extrusion cost less than using 40 mm extrusion without all the extra stuff?
Re: CoreXYNZ build July 05, 2016 09:01AM |
Re: CoreXYNZ build July 05, 2016 11:35PM |
Re: CoreXYNZ build July 06, 2016 01:07AM |
the_digital_dentist
Be sure to put the belts into your model and check for clearances at both ends of the Y axis
Re: CoreXYNZ build July 08, 2016 12:09AM |
Re: CoreXYNZ build July 10, 2016 06:02PM |
Re: CoreXYNZ build July 10, 2016 07:41PM |
Re: CoreXYNZ build July 10, 2016 09:06PM |
Re: CoreXYNZ build July 10, 2016 10:42PM |
Re: CoreXYNZ build July 11, 2016 01:58PM |
Re: CoreXYNZ build July 11, 2016 07:53PM |
Great spotting. Thanks a lot. That's serendipity. I will rework the design and see how it goes. It looks like no print space would be lost.Quote
FA-MAS
Take a look at this. When I was looking at datasheets for these rails. I believe the holes are spaced perfectly so you could extend the X Rails a bit and connect them to the blocks on the Y, using 2 screws. That would make it alot more rigid, and you wouldn't need to fabricate the "ears" on the green part.
Re: CoreXYNZ build July 11, 2016 11:31PM |
Re: CoreXYNZ build July 12, 2016 11:27AM |
Re: CoreXYNZ build July 13, 2016 01:21AM |
Re: CoreXYNZ build July 15, 2016 03:36PM |
