belts path on the same plane using a belt twist July 19, 2016 06:30AM |
Re: belts path on the same plane using a belt twist July 19, 2016 07:56AM |
Re: belts path on the same plane using a belt twist July 19, 2016 09:51AM |
Re: belts path on the same plane using a belt twist July 19, 2016 10:01AM |
Re: belts path on the same plane using a belt twist July 19, 2016 01:36PM |
PDBeal
Stacking the pulleys on top of each other reduces the amount you can travel very so slightly as the closer you get to the pulleys, the belt teeth begin to line up and eventually interlock before you reach the complete end of travel. On smaller machines, its not as noticeable, but I ran into this with my 300x300 coreXY build and redesigned my rear parts. Thingiverse.com
