GIANT Core-xy build August 05, 2016 12:01AM |
Re: GIANT Core-xy build August 05, 2016 05:03AM |
Re: GIANT Core-xy build August 05, 2016 11:15AM |
Re: GIANT Core-xy build August 05, 2016 12:39PM |
Re: GIANT Core-xy build August 05, 2016 01:33PM |
Origamib
A very nice looking build you have so far, but will the bed be stable enough with only 2 wheels per extrusion?
The normal set up (3 / 4 wheels per piece of extrusion) works well as the wheels can 'clamp' on to the rigid extrusion, and I assume that you are trying to do the opposite by torquing the wheels outwards on to each piece of extrusion, but when the bed reaches the center of the extrusion, it will be able to flex it more, and you may see movement in the bed.
Re: GIANT Core-xy build August 05, 2016 01:35PM |
Re: GIANT Core-xy build August 05, 2016 01:44PM |
wbwing
I'm certainly no expert, so take what I say with a grain of salt. But here is what I am noticing based on spending time here and my own intuition
-Have you considered using a belt and 1 motor to drive your Z-axis? This way they never get out of sync.
-The x and y axis. I'm no expert on rails again, I know they are supposed to be a great solution, but should they not be mounted on a more rigid surface? Atleast 1 axis?. Even if they can take the load, seems like there would be deflection in the middle of the span. And at the very center of the plate, you would add the deflection of the x and y axis. Might not be tremendous, but it adds up in a precision machine (I assume you want to build a very robust large machine). I would think about adding two extrusions, or something (perhaps machined piece) below two of the rails so overall deflection in the center of the build plate is reduced.
-Is the 8mm lead screw thick enough? Should it be secured at both ends?(Don't know, but a question for the experts on here)
-Have you considered a Flex3drive extruder? Based on my sleuthing, seems to be the best (perhaps maybe tied with the new E3D Titan)
-How many points is the bed leveled with? 3 point manual leveling is the best method. (my own experience with a very high precision polishing machine)
Looks like a good concept though. The frame seems strong and rigid. I like that the bed is well supported. Might even take one of those heavy but very cool basalt beds.
Look forward to your progression and the comments of the people who really know what's going on. I'm really looking for a very good, bulletproof design with a larger build space. 9"x9" is just too small.
