Yet another CoreXY printer August 17, 2016 11:01AM |
Re: Yet another CoreXY printer August 17, 2016 12:16PM |
Re: Yet another CoreXY printer August 17, 2016 04:31PM |
Re: Yet another CoreXY printer August 17, 2016 05:23PM |
Re: Yet another CoreXY printer August 17, 2016 05:46PM |
Re: Yet another CoreXY printer August 17, 2016 08:44PM |
Mikk36
What do you mean by headroom for filament feed?
Re: Yet another CoreXY printer August 17, 2016 08:47PM |
Re: Yet another CoreXY printer August 17, 2016 09:48PM |
I'm sure that would work but only if the spool is inside the enclosure or there is a large enough opening in the top.Quote
the_digital_dentist
You may be able to reduce that height by allowing the filament spool to swivel to follow the extruder. OTOH, doing so may lead to filament tangles on the spool. I plan to find out.
Re: Yet another CoreXY printer August 19, 2016 05:37PM |
Re: Yet another CoreXY printer August 27, 2016 08:48PM |
Re: Yet another CoreXY printer August 29, 2016 02:01PM |
Re: Yet another CoreXY printer August 29, 2016 09:53PM |
Re: Yet another CoreXY printer August 30, 2016 08:29AM |
Just el-cheapo MGN12 rails with MGN12C blocks.Quote
n8bot
Very cool. Are those misumi high-temp miniature linear guides I spot?
Noted, will reevaluate amount of screws on assembly and tuning.Quote
cozmicray
Six bolts holding ballscrew nut.
Please allow this to float,
at least until all rails and ball screws are lined up.
If locked down, it will bind X, Y
All it has to be --- is accurate mover for Z
Re: Yet another CoreXY printer August 30, 2016 08:34AM |
Re: Yet another CoreXY printer August 30, 2016 07:09PM |
That will work and it is a nice look. However you do loose the slight adjust-ability of oversize holes and button or cap head screws and washers. With my machine I need that due to the relatively inaccurate method of constructionQuote
Mikk36
Also am pondering a bit on using countersunk screws on the effector platform to attach the plate to the blocks to get a flush finish.
The screw spec says 1.9 mm length for the countersunk head, plate itself is 3 mm.
Re: Yet another CoreXY printer August 31, 2016 05:10AM |
Re: Yet another CoreXY printer August 31, 2016 09:38AM |
Re: Yet another CoreXY printer August 31, 2016 12:49PM |
Mikk36
The bed is 340x340 and will have a 300x300 silicone heater. I'm assuming that that 20 mm gap won't be an issue thanks to the bed being 8 mm thick.
the_digital_dentist
The unheated 20 mm margin around the edge of the bed is going to create a temperature drop so your usable print area will likely be a bit less than the 300 mm square that is directly above the heater.
