Idler pulleys with spacers between their bearings..??? August 22, 2016 03:41AM |
(Well, to be fair, about half of the ones I got had bearings that ran smoothly).|
Re: Idler pulleys with spacers between their bearings..??? August 22, 2016 09:06AM |
Re: Idler pulleys with spacers between their bearings..??? August 22, 2016 10:10AM |
Re: Idler pulleys with spacers between their bearings..??? August 22, 2016 02:50PM |
Re: Idler pulleys with spacers between their bearings..??? August 22, 2016 06:27PM |
Re: Idler pulleys with spacers between their bearings..??? August 22, 2016 06:50PM |
Re: Idler pulleys with spacers between their bearings..??? August 23, 2016 03:15AM |
Re: Idler pulleys with spacers between their bearings..??? August 23, 2016 12:06PM |
Re: Idler pulleys with spacers between their bearings..??? August 23, 2016 01:07PM |
Well, a 40-tooth pulley is still quite a bit bigger than a 20-tooth one, so a toothed idler is still a preferred option if space is of concern.Quote
the_digital_dentist
I run the tooth side of GT2 belt on a smooth pulley made from stacked bearings (F625zz IRIC, 16 mm dia) in the X axis of my printer. I see no difference between the X parallel surface of prints and the Y parallel surface that is driven by a precision ground ball screw.
SDP/SI says smooth pulleys in contact with belt teeth should have equivalent 40 tooth pulley diameter which is about 25 mm for 2mm pitch belt.
Re: Idler pulleys with spacers between their bearings..??? August 23, 2016 05:59PM |
Re: Idler pulleys with spacers between their bearings..??? August 23, 2016 11:05PM |
hobbymods
Information overload....
I based my whole design on 20T timing and idler pulleys.
I made sure I had toothed on the toothed side and vice versa, but now am reading that the idlers should be at least 1.5 times the dive pulleys diameter.
For me it makes sense at a glance, but I'm buggered if I can find anyone with 30T smooth and toothed idlers.
I'd probably be prepared to go with 20T drive/30T idlers, or even 16T drive/32T idlers.
Anyone with links/suppliers?
Re: Idler pulleys with spacers between their bearings..??? August 24, 2016 12:51AM |
Re: Idler pulleys with spacers between their bearings..??? August 24, 2016 04:23AM |
Re: Idler pulleys with spacers between their bearings..??? August 24, 2016 08:42AM |
Re: Idler pulleys with spacers between their bearings..??? October 26, 2018 12:15AM |
