Preferred Z Axis Style? August 31, 2016 10:56AM |
Re: Preferred Z Axis Style? August 31, 2016 11:39AM |
Re: Preferred Z Axis Style? August 31, 2016 03:29PM |
Re: Preferred Z Axis Style? September 02, 2016 05:20AM |
Re: Preferred Z Axis Style? September 02, 2016 10:39AM |
Dalius98
I am using three screws connected with a belt (powered by one motor). I've chosen 2mm pitch/lead screws, so I could be using full (or half) steps to move Z and still get reasonable layer heights. I don't think microstepping would be able to provide accurate heights alone... Z speeds are quite low with this setup, but it's not like you need them to be fast...
Re: Preferred Z Axis Style? September 02, 2016 10:43AM |
Re: Preferred Z Axis Style? September 02, 2016 10:54AM |
Re: Preferred Z Axis Style? September 02, 2016 03:12PM |
Origamib
For most applications, screws are the way forward. I've never been keen on the belts method as it can't hold its own weight, and belts tend to wear faster. Belts are much better for high speed applications, but the Z Axis will never have to move that fast. A leadscrew is the way to go. I'm not even sure why people go for belts, as surely a length of GT2 belt and pulleys costs just as much as a screw + nut?
As for the cantilever, this is probably one of the most complained about issues of the ultimaker style machines with many 'fixes' floating around. I'd personally go for 2 or 3 leadscrews and guides. I'm not saying cantilever is bad, many parts of our machine are 'unsupported' and work just fine, but this must be adequately designed to work. Cantilever does have a clean look though, and is simple to implement.
Re: Preferred Z Axis Style? September 03, 2016 04:44AM |
Re: Preferred Z Axis Style? September 05, 2016 03:22PM |
Re: Preferred Z Axis Style? September 06, 2016 08:09AM |
Well, it will depend on the length...Quote
MatthewHall
Thanks dalius, how much did the whole z assembly cost?
Re: Preferred Z Axis Style? September 07, 2016 08:04AM |
Re: Preferred Z Axis Style? September 07, 2016 02:22PM |
MatthewHall
How do you think using just three leadscrews and no smooth rods would work?
Re: Preferred Z Axis Style? September 07, 2016 03:51PM |
Re: Preferred Z Axis Style? September 08, 2016 01:11PM |
Re: Preferred Z Axis Style? September 14, 2016 02:36PM |
Re: Preferred Z Axis Style? September 14, 2016 02:39PM |
Re: Preferred Z Axis Style? September 29, 2016 04:09PM |
Re: Preferred Z Axis Style? September 29, 2016 04:13PM |
Re: Preferred Z Axis Style? September 29, 2016 04:58PM |
Re: Preferred Z Axis Style? September 29, 2016 06:07PM |
Re: Preferred Z Axis Style? September 30, 2016 06:43AM |
filipeCampos
Cantilevers is the easy solution for small bed, but the bed structure need to be rigid.
I using a cantilevers 200x200, supported by 2 x 12mm rods and one 8mm lead screw with 2mm pitch, using this setup for almost 1 year and it works with no issue.
I know upgrading to a 310x290 with 2 x 16mm rods and 8mm lead screw with 1.5mm pitch, but this was not tested and can not guaranty it will work.
Any bigger bed and i think cantilevers is not more a option.
Re: Preferred Z Axis Style? September 30, 2016 07:43AM |
Re: Preferred Z Axis Style? September 30, 2016 11:55AM |
unromeo21
filipeCampos
How about a 400x400 bed with aluminium tooling plate 8mm thick cantilevered ? works without issues on two 16mm smooth rods. The plate that holds the 4 linear bearings and the support brackets is 15mm thick. You just need beefy components and support brackets. It works actually for any size. The secret is to scale up the whole assembly, not only the bed ... Does it worth it ? Well, it was extremely easy to build and assemble, only one stepper, and costs were extremely low. Would I upgrade to two or three lead-screws ? I don't have any reason to do it at the moment, I get high quality prints with no Z artifacts. Let me know if I should post some photos.
Re: Preferred Z Axis Style? October 01, 2016 07:59AM |
Re: Preferred Z Axis Style? October 01, 2016 01:38PM |
Re: Preferred Z Axis Style? October 04, 2016 02:58PM |
Re: Preferred Z Axis Style? October 04, 2016 03:56PM |
Re: Preferred Z Axis Style? October 07, 2016 05:43AM |
the_digital_dentist
Can you post a photo of the Z axis mechanism and closeup of a couple prints made at the far end of the bed? Cantilevering is simple mechanically which is appealing, but I have yet to see one that doesn't bounce.
Re: Preferred Z Axis Style? October 07, 2016 06:27AM |
