criss-cross pattern needed? August 31, 2016 12:45PM |
Re: criss-cross pattern needed? August 31, 2016 01:14PM |
Re: criss-cross pattern needed? August 31, 2016 06:03PM |
Re: criss-cross pattern needed? September 01, 2016 03:32AM |
Re: criss-cross pattern needed? September 01, 2016 03:18PM |
Mikk36
One flaw that I see with your design is that as you tighten the X belt you will put a constant sideways (tilting) load on the X axis and with that on the Y movement system creating additional resistance and wear.
This could be mitigated by having the Y motor also drive the left side of the X axis (through a shaft, for example, think Ultimaker) or having another motor there.
Re: criss-cross pattern needed? September 01, 2016 05:36PM |
n8bot
Mikk36
There is no inherent flaw, the flaw would be in the specific implementation. Any linear motion system of sufficient rigidity could easily resist the force from the belt tension.
Re: criss-cross pattern needed? September 01, 2016 08:57PM |
PvtPrivate
n8bot
Mikk36
Then what about H-bot? it only has 1 plane, no criss-cross, 1 belt, easy belt tension, simplicity. Only downside is longer belt then.
Re: criss-cross pattern needed? September 01, 2016 09:29PM |
Re: criss-cross pattern needed? September 02, 2016 03:07PM |
FrankPropaneTank
Not quite, if memory serves this is the MarkForged Mark 1 belt system:
Re: criss-cross pattern needed? September 02, 2016 04:42PM |
Re: criss-cross pattern needed? September 05, 2016 11:26PM |
Re: criss-cross pattern needed? September 08, 2016 01:37PM |
n8bot
Mikk36
Re: criss-cross pattern needed? September 08, 2016 06:11PM |
DjDemonD
n8bot
Mikk36
@mikk36 - or reciprocated by going around the x and y axis on the right and therefore be a proper corexy mechanism.
@n8bot - But surely this is one of the real benefits of corexy you don't need or want massive rods and bearings. The reciprocating nature of the belts means the x axis is held orthogonal to the y axis with modest sized linear guides, and importantly balanced belt tension on a and b belts. That's why it's fast and accurate, it's lightweight enough to do both. On my corexy the x axis will "bend" relative to the y axis if the belt tension is unequal, it's not so it doesn't matter that this give exists in the linear guides, they are incomplete without the belts.
The problem with the proposed scheme is that the y axis will be rotated anticlockwise as viewed from above under belt tension. So whilst it looks good you might as well put the x motor on the x axis and have a nice short simple belt but will require big heavy rods and bearings and you'll lose the speed you wanted in the first place.
Corexy is much more clever than it gets credit for, and whilst I'd love to see someone improve on it, I don't think this is it - it looks good on paper but....
Re: criss-cross pattern needed? September 09, 2016 02:33AM |
