G&C Printer [Metal Upgrade] September 14, 2016 04:28PM |
Re: G&C Printer [Metal Upgrade] September 14, 2016 08:44PM |
Re: G&C Printer [Metal Upgrade] September 15, 2016 09:30AM |
Re: G&C Printer [Metal Upgrade] September 19, 2016 04:22AM |
Re: G&C Printer [Metal Upgrade] September 22, 2016 07:39AM |
Re: G&C Printer [Metal Upgrade] September 22, 2016 09:07AM |
Re: G&C Printer [Metal Upgrade] September 23, 2016 12:49PM |
Re: G&C Printer [Metal Upgrade] September 23, 2016 02:27PM |
Re: G&C Printer [Metal Upgrade] September 23, 2016 02:33PM |
Re: G&C Printer [Metal Upgrade] September 23, 2016 02:44PM |
Re: G&C Printer [Metal Upgrade] September 23, 2016 03:59PM |
Re: G&C Printer [Metal Upgrade] September 23, 2016 04:10PM |
Re: G&C Printer [Metal Upgrade] September 24, 2016 05:05AM |
Re: G&C Printer [Metal Upgrade] September 24, 2016 09:54AM |
Re: G&C Printer [Metal Upgrade] September 24, 2016 10:09AM |
Re: G&C Printer [Metal Upgrade] September 25, 2016 04:18AM |
Re: G&C Printer [Metal Upgrade] September 26, 2016 05:44AM |
Re: G&C Printer [Metal Upgrade] September 26, 2016 07:15AM |
Re: G&C Printer [Metal Upgrade] September 26, 2016 10:36AM |
Not sure if i have the space to put the motor on top, i need to check if can be done without big notification.Quote
the_digital_dentist
Your bed is quite heavy. The screw (and motor bearings) are the only thing that supports that weight. The screw wants to bow because of all that weight. Here's an experiment- move the Z motor up close to the top of the machine and try another print. The Z screw length between the bed and motor will be shorter and less likely to bow. If the print comes out better, you may need a larger diameter screw.
already try the z lift on retraction and used a cura addon to move on each layer, get zero improvement. My acceleration of the z bed is 10mm/s for both printing and moving, with a top speed of 30mm/s.Quote
the_digital_dentist
Are you using z lift on retraction? With a cantilevered bed you may have to turn the Z axis acceleration quite low to prevent the bed from bouncing when you make Z moves of any kind.
without the screw the bed move smoothly without any noticeable stops, only with the 2060 bar installed (without the bed) the bearing will move from top to down almost was there are following. There is zero lateral play on the side where is the bearings and z screw, on the other side is possible by hand move up/down or left/right some mm, but i think is because of the union of the two 2020 bar to the bigger 2060 bar.when printing i never noticed any vibration transmitted in the bed, printing close of the bearings or the other edge i get the same print results.Quote
the_digital_dentist
With the screw removed, does the Z axis glide smoothly up and down without binding or "walking"? Is there any detectable lateral play in the bed?
sure, can do the cube. I printing blue pla because is more easy to see the problems.Quote
the_digital_dentist
Can you print something besides a tugboat? The vertical edges of a cube can be very revealing of printer motion problems- look at all four vertical edges, preferably under a microscope, and note any differences...
Re: G&C Printer [Metal Upgrade] September 26, 2016 10:58AM |
Re: G&C Printer [Metal Upgrade] December 10, 2016 05:31AM |
Re: G&C Printer [Metal Upgrade] December 10, 2016 07:18AM |
Re: G&C Printer [Metal Upgrade] December 10, 2016 11:43AM |
Re: G&C Printer [Metal Upgrade] December 11, 2016 04:50AM |
Re: G&C Printer [Metal Upgrade] December 11, 2016 07:13AM |
