Corexy movement Help
Posted by dthomas6184
Re: Corexy movement Help
November 22, 2016 02:02AM
2 questions,
1. Are the LEDs and 1k resistor necessary for the operation of a heated PCB?
2. Has anyone here had any experience with the REX-C100 PID?
November 22, 2016 08:35AM
No, LED and resistor are not necessary. They are a convenience to show you when power is applied to the bed heater.
Edited 1 time(s). Last edit at 11/22/2016 08:35AM by the_digital_dentist.
November 22, 2016 09:09AM
If I were to mount some, do they need to be surface mount or can they be standard with the legs cut way down?
November 22, 2016 03:22PM
No. Yes.
November 22, 2016 03:24PM
thanks
November 27, 2016 01:13AM
What does it mean when your z axis motor makes a strange whine at idle?
November 27, 2016 02:43AM
dthomas6184
It probably means that the Z motor driver is going into subharmonic oscillation. This is a common problem when using DRV8825 drivers configured in fast decay mode. It's harmless. If it bothers you, then if you have two Z motors wired in parallel, try wiring them in series instead. Don't forget to turn the Z motor current down to half its previous value.
March 16, 2017 12:18AM
So after having to put the project on the back burner for a while I've been able to pull it back out. I'm running into an issue (I think) with z axis, It homes at a snail's pace and it travels in the wrong direction, the bed travels down| away from the hotend and endstop. Is there away to change those in the firmware?
March 16, 2017 12:22AM
dthomas6184
You can almost certainly fix it by reconfiguring the firmware, but how you do it depends on which firmware you are using.
March 16, 2017 08:23AM
I'm using Repetier firmware
