Full Graphic Smart Controller screen flickering
Posted by MatthewHall
January 02, 2017 12:31PM
The green lights are on on the Arduino, but the green light on the Ramps is flickering constantly. I have reset and re-uploaded the firmware, but still getting the same results. Does anyone know what would cause the screen to flicker like this? The light on the RAMPS seem to flicker at the same frequency. I was having a few endstop short circuits recently (may be the problem). I have those chinsy 3-wire endstops that short circuit if you plug them in the wrong way.
Any help would be greatly appreciated. Thanks!
Re: Full Graphic Smart Controller screen flickering
January 02, 2017 08:21PM
If you plug in an endstop the wrong way it is very likely you have damaged the voltage regulator on the mega
January 03, 2017 07:51AM
Dust
How would I fix this? I measured the voltage earlier and it was all OK
January 03, 2017 02:21PM
The full graphic displays take a bit more power than the Arduino can provide. I had to add a separate 5 volt power supply to keep my Arduino running more than a few seconds with my display plugged in.
