Re: Hlidskjalf, Dual CoreXY June 23, 2017 01:21AM |
Re: Hlidskjalf, Dual CoreXY June 23, 2017 04:00AM |
lars.arvidson
Great!Quote
dc42
Firmware 1.19beta7 includes the CoreXYU support. I hope to release it later today.
Did my first prints today! Still pretty ghetto and a lot to fix on the printer. I have seen better first layers but still a big milestone in my project!
[youtu.be]
Now I need more axis than 6 for bed leveling... Next firmware hack me think...
Re: Hlidskjalf, Dual CoreXY June 23, 2017 09:48AM |
Re: Hlidskjalf, Dual CoreXY June 23, 2017 11:02AM |
Re: Hlidskjalf, Dual CoreXY June 23, 2017 11:39AM |
Re: Hlidskjalf, Dual CoreXY June 23, 2017 01:04PM |
Re: Hlidskjalf, Dual CoreXY June 23, 2017 01:24PM |
Re: Hlidskjalf, Dual CoreXY June 23, 2017 03:34PM |
bobbyd
I am so far behind you guys. I'm still designing mine, and once I'm done that, I have to test all of the tolerances and then I have to save up because I'm just a poor college kid lol. I'm starting to doubt that I can finish by the end of summer.
Re: Hlidskjalf, Dual CoreXY June 24, 2017 01:42PM |
I have 3 independent steppers on the Z-axis so I will use Z axis auto bed leveling.Quote
bobbyd
Also are you also gonna try and do the triple Z axis auto bed leveling?
Take your time, just ordering and receiving the components can take a lot of time.Quote
bobbyd
Looks like theres no way to active CoreXYU in beta 7 but I have made a pull request to fix it: [github.com]Quote
lars.arvidson
I can post my config once I'm back home tomorrow evening. I home x left (low/min) and u right (high/max).
G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Axis and motor configuration M584 Y5 X7 U8 V6 E3:4 Z0:1:2 ; Set up steppers for x, y, u, v, z and e, use P4 once it works to hide V M574 X1 Y1 U2 S1 ; set endstop configuration (all endstops at high end, active high) ; Core xyu M669 K5 ; Select CoreXYU mode M208 X-5 Y-5 U30 V-5 Z0 S1 ; Set axis minima M208 X500 Y500 U563 V500 Z700 S0 ; Set axis maxima U600 - 37 = 563 M569 P0 S0 ; Drive 0 goes forwards Z M569 P1 S0 ; Drive 1 goes forwards Z M569 P2 S0 ; Drive 2 goes forwards Z M569 P3 S0 ; Drive 3 goes forwards E0 M569 P4 S0 ; Drive 4 goes forwards E1 M569 P5 S0 ; Drive 5 goes forwards Y M569 P6 S0 ; Drive 6 goes forwards V M569 P7 S1 ; Drive 7 goes forwards X M569 P8 S1 ; Drive 8 goes forwards U M569 P9 S1 ; Drive 9 goes forwards M350 X16 Y16 U16 V16 Z16 E16:16 I1 ; Configure microstepping with interpolation M92 X160 Y160 U160 V160 Z1600 ; Set steps per mm M566 X600 Y600 U600 V600 Z12 E60:60 ; Set maximum instantaneous speed changes (mm/min) M203 X24000 Y24000 U24000 V24000 Z300 E1400:1400 ; Set maximum speeds (mm/min) M201 X1500 Y1500 U1500 V1500 Z250 E120:120 ; Set accelerations (mm/s^2) M906 X1700 Y1700 U1700 V1700 Z1700 E800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Tool definitions M563 P0 D0 H1 ; Define tool 0 G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures ;*** If you have a single-nozzle build, comment the next 2 lines M563 P1 D1 H2 X3 ; Define tool 1 and bind it to U-axis (X3) G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures M92 E2500:2500 ; Set extruder steps per mmThe X3 in M563 for tool P1 is important!
G90 G1 X0 F18000tfree1.g
G90 G1 U558 F18000tpost0.g
M116 P0 ; wait for tool 0 heaters to reach operating temperature M83 ; relative extruder movement G1 E2 F3600 ; extrude 2mmtpost1.g
M116 P1 ; wait for tool 0 heaters to reach operating temperature M83 ; relative extruder movement G1 E2 F3600 ; extrude 2mmhomeall.g
G91 ; relative mode G1 S1 F3000 X-800 U800 Y-800 ; course home X, Y or U G1 S1 X-800 ; course home X G1 S1 U800 ; course home U G1 S1 Y-800 ; course home Y G1 F600 G1 X4 U-4 Y4 ; move away from the endstops G1 S1 X-10 ; fine home X G1 S1 U10 ; fine home U G1 S1 Y-10 ; fine home Y ; Z homing not yet implemented G90 G1 X0 Y0 U558 G92 V0
Re: Hlidskjalf, Dual CoreXY June 24, 2017 02:31PM |
Re: Hlidskjalf, Dual CoreXY June 24, 2017 06:03PM |
Re: Hlidskjalf, Dual CoreXY June 25, 2017 07:43AM |
Re: Hlidskjalf, Dual CoreXY June 25, 2017 10:41PM |
Re: Hlidskjalf, Dual CoreXY June 26, 2017 03:31AM |
Re: Hlidskjalf, Dual CoreXY June 27, 2017 03:37AM |
'Building target: RepRapFirmware.elf' 'Invoking: Cross G++ Linker' arm-none-eabi-gcc -L"C:\Eclipse\Firmware\CoreNG\RADDS" -Os -Wl,--gc-sections -Wl,--fatal-warnings -mcpu=cortex-m3 -TC:\Eclipse\Firmware\CoreNG\variants\RADDS\linker_scripts\gcc\flash.ld -Wl,-Map,C:\Eclipse\Firmware\RepRapFirmware\RADDS/RepRapFirmware.map -o "RepRapFirmware.elf" -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group ./src/Storage/FileStore.o ./src/Storage/MassStorage.o ./src/RADDS/Network.o ./src/Movement/Kinematics/CartesianKinematics.o ./src/Movement/Kinematics/CoreBaseKinematics.o ./src/Movement/Kinematics/CoreXYKinematics.o ./src/Movement/Kinematics/CoreXYUKinematics.o ./src/Movement/Kinematics/CoreXZKinematics.o ./src/Movement/Kinematics/Kinematics.o ./src/Movement/Kinematics/LinearDeltaKinematics.o ./src/Movement/Kinematics/ScaraKinematics.o ./src/Movement/BedProbing/Grid.o ./src/Movement/BedProbing/RandomProbePointSet.o ./src/Movement/DDA.o ./src/Movement/DriveMovement.o ./src/Movement/Move.o ./src/Libraries/sha1/sha1.o ./src/Libraries/Math/Isqrt.o ./src/Libraries/General/StringRef.o ./src/Libraries/Fatfs/ccsbcs.o ./src/Libraries/Fatfs/diskio.o ./src/Libraries/Fatfs/fattime_rtc.o ./src/Libraries/Fatfs/ff.o ./src/Heating/Sensors/CpuTemperatureSensor.o ./src/Heating/Sensors/CurrentLoopTemperatureSensor.o ./src/Heating/Sensors/RtdSensor31865.o ./src/Heating/Sensors/SpiTemperatureSensor.o ./src/Heating/Sensors/TemperatureSensor.o ./src/Heating/Sensors/Thermistor.o ./src/Heating/Sensors/ThermocoupleSensor31855.o ./src/Heating/Sensors/TmcDriverTemperatureSensor.o ./src/Heating/FOPDT.o ./src/Heating/Heat.o ./src/Heating/Pid.o ./src/Heating/TemperatureError.o ./src/GCodes/GCodeBuffer.o ./src/GCodes/GCodeInput.o ./src/GCodes/GCodeMachineState.o ./src/GCodes/GCodeQueue.o ./src/GCodes/GCodes.o ./src/GCodes/GCodes2.o ./src/Fan.o ./src/OutputMemory.o ./src/Platform.o ./src/PrintMonitor.o ./src/RepRap.o ./src/RepRapFirmware.o ./src/Roland.o ./src/Scanner.o -lCoreNG -Wl,--end-group -lm -gcc c:/arduino-1.5.8/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld.exe: cannot find -lCoreNG collect2.exe: error: ld returned 1 exit status make: *** [RepRapFirmware.elf] Error 1
Re: Hlidskjalf, Dual CoreXY June 27, 2017 06:24PM |
Re: Hlidskjalf, Dual CoreXY June 28, 2017 02:18AM |
dc42
The collect2.exe program should be part of your Arduino GCC installation I think. I suggest you search for it, and if you find it, make sure it is on PATH.
Re: Hlidskjalf, Dual CoreXY June 28, 2017 02:49AM |
Re: Hlidskjalf, Dual CoreXY June 29, 2017 02:48AM |
Re: Hlidskjalf, Dual CoreXY June 29, 2017 03:53AM |
Re: Hlidskjalf, Dual CoreXY June 29, 2017 04:44AM |
Re: Hlidskjalf, Dual CoreXY July 01, 2017 04:38PM |
make all 'Building target: RepRapFirmware.elf' 'Invoking: Cross G++ Linker' arm-none-eabi-gcc -L"C:\Eclipse\Firmware\CoreNG\RADDS" -Os -Wl,--gc-sections -Wl,--fatal-warnings -mcpu=cortex-m3 -TC:\Eclipse\Firmware\CoreNG\variants\RADDS\linker_scripts\gcc\flash.ld -Wl,-Map,C:\Eclipse\Firmware\RepRapFirmware\RADDS/RepRapFirmware.map -o "RepRapFirmware.elf" -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group ./src/Storage/FileStore.o ./src/Storage/MassStorage.o ./src/RADDS/Network.o ./src/Movement/Kinematics/CartesianKinematics.o ./src/Movement/Kinematics/CoreBaseKinematics.o ./src/Movement/Kinematics/CoreXYKinematics.o ./src/Movement/Kinematics/CoreXYUKinematics.o ./src/Movement/Kinematics/CoreXZKinematics.o ./src/Movement/Kinematics/Kinematics.o ./src/Movement/Kinematics/LinearDeltaKinematics.o ./src/Movement/Kinematics/ScaraKinematics.o ./src/Movement/BedProbing/Grid.o ./src/Movement/BedProbing/RandomProbePointSet.o ./src/Movement/DDA.o ./src/Movement/DriveMovement.o ./src/Movement/Move.o ./src/Libraries/sha1/sha1.o ./src/Libraries/Math/Isqrt.o ./src/Libraries/General/StringRef.o ./src/Libraries/Fatfs/ccsbcs.o ./src/Libraries/Fatfs/diskio.o ./src/Libraries/Fatfs/fattime_rtc.o ./src/Libraries/Fatfs/ff.o ./src/Heating/Sensors/CpuTemperatureSensor.o ./src/Heating/Sensors/CurrentLoopTemperatureSensor.o ./src/Heating/Sensors/RtdSensor31865.o ./src/Heating/Sensors/SpiTemperatureSensor.o ./src/Heating/Sensors/TemperatureSensor.o ./src/Heating/Sensors/Thermistor.o ./src/Heating/Sensors/ThermocoupleSensor31855.o ./src/Heating/Sensors/TmcDriverTemperatureSensor.o ./src/Heating/FOPDT.o ./src/Heating/Heat.o ./src/Heating/Pid.o ./src/Heating/TemperatureError.o ./src/GCodes/GCodeBuffer.o ./src/GCodes/GCodeInput.o ./src/GCodes/GCodeMachineState.o ./src/GCodes/GCodeQueue.o ./src/GCodes/GCodes.o ./src/GCodes/GCodes2.o ./src/Fan.o ./src/OutputMemory.o ./src/Platform.o ./src/PrintMonitor.o ./src/RepRap.o ./src/RepRapFirmware.o ./src/Roland.o ./src/Scanner.o -lCoreNG -Wl,--end-group -lm -gcc ./src/Heating/Sensors/TemperatureSensor.o: In function `TemperatureSensor::Create(unsigned int)': TemperatureSensor.cpp.text._ZN17TemperatureSensor6CreateEj+0x84): warning: undefined reference to `ThermocoupleSensor31856::ThermocoupleSensor31856(unsigned int)' ./src/GCodes/GCodes.o: In function `GCodes::GCodes(Platform&)': GCodes.cpp.text._ZN6GCodesC2ER8Platform+0x3a): warning: undefined reference to `RestorePoint::RestorePoint()' GCodes.cpp.text._ZN6GCodesC2ER8Platform+0x42): warning: undefined reference to `RestorePoint::RestorePoint()' GCodes.cpp.text._ZN6GCodesC2ER8Platform+0x4a): warning: undefined reference to `RestorePoint::RestorePoint()' ./src/GCodes/GCodes.o: In function `GCodes:etOrReportOffsets(GCodeBuffer&, StringRef&)': GCodes.cpp.text._ZN6GCodes18SetOrReportOffsetsER11GCodeBufferR9StringRef+0x18e): warning: undefined reference to `Tool::GetVariables(float*, float*) const' GCodes.cpp.text._ZN6GCodes18SetOrReportOffsetsER11GCodeBufferR9StringRef+0x1c4): warning: undefined reference to `Tool:etVariables(float const*, float const*)' ./src/GCodes/GCodes.o: In function `GCodes::ManageTool(GCodeBuffer&, StringRef&)': GCodes.cpp.text._ZN6GCodes10ManageToolER11GCodeBufferR9StringRef+0xec): warning: undefined reference to `Tool::Create(int, char const*, long*, unsigned int, long*, unsigned int, unsigned long, unsigned long)' ./src/GCodes/GCodes.o: In function `GCodes:etToolHeaters(Tool*, float)': GCodes.cpp.text._ZN6GCodes14SetToolHeatersEP4Toolf+0x10): warning: undefined reference to `Tool::GetVariables(float*, float*) const' GCodes.cpp.text._ZN6GCodes14SetToolHeatersEP4Toolf+0x2e): warning: undefined reference to `Tool:etVariables(float const*, float const*)' ./src/GCodes/GCodes.o: In function `GCodes::LoadFilament(GCodeBuffer&, StringRef&, bool&)': GCodes.cpp.text._ZN6GCodes12LoadFilamentER11GCodeBufferR9StringRefRb+0x104): warning: undefined reference to `Filament::IsInUse(char const*)' ./src/GCodes/GCodes.o: In function `GCodes::Reset()': GCodes.cpp.text._ZN6GCodes5ResetEv+0xfa): warning: undefined reference to `RestorePoint::Init()' GCodes.cpp.text._ZN6GCodes5ResetEv+0x102): warning: undefined reference to `RestorePoint::Init()' ./src/GCodes/GCodes.o: In function `GCodes:pin()': GCodes.cpp.text._ZN6GCodes4SpinEv+0x308): warning: undefined reference to `Filament::Unload()' GCodes.cpp.text._ZN6GCodes4SpinEv+0x59c): warning: undefined reference to `Filament::Load(char const*)' ./src/GCodes/GCodes2.o: In function `GCodes::HandleMcode(GCodeBuffer&, StringRef&)': GCodes2.cpp.text._ZN6GCodes11HandleMcodeER11GCodeBufferR9StringRef+0x58d0): warning: undefined reference to `Tool:efineMix(float const*)' ./src/RepRap.o: In function `RepRap:pin()': RepRap.cpp.text._ZN6RepRap4SpinEv+0x78): warning: undefined reference to `Tool:isplayColdExtrudeWarning()' ./src/RepRap.o: In function `RepRap::EmergencyStop()': RepRap.cpp.text._ZN6RepRap13EmergencyStopEv+0x10): warning: undefined reference to `Tool:tandby()' ./src/RepRap.o: In function `RepRap::AddTool(Tool*)': RepRap.cpp.text._ZN6RepRap7AddToolEP4Tool+0x34): warning: undefined reference to `Tool::UpdateExtruderAndHeaterCount(unsigned short&, unsigned short&) const' ./src/RepRap.o: In function `RepRap:rintTool(int, StringRef&) const': RepRap.cpp.text._ZNK6RepRap9PrintToolEiR9StringRef+0x2e): warning: undefined reference to `Tool:rint(StringRef&)' ./src/RepRap.o: In function `RepRap:tandbyTool(int)': RepRap.cpp.text._ZN6RepRap11StandbyToolEi+0x30): warning: undefined reference to `Tool:tandby()' ./src/RepRap.o: In function `RepRap:electTool(int)': RepRap.cpp.text._ZN6RepRap10SelectToolEi+0x1a): warning: undefined reference to `Tool::Activate(Tool*)' ./src/RepRap.o: In function `RepRap:eleteTool(Tool*)': RepRap.cpp.text._ZN6RepRap10DeleteToolEP4Tool+0x5a): warning: undefined reference to `Tool:elete(Tool*)' RepRap.cpp.text._ZN6RepRap10DeleteToolEP4Tool+0x76): warning: undefined reference to `Tool::UpdateExtruderAndHeaterCount(unsigned short&, unsigned short&) const' ./src/RepRap.o: In function `RepRap::GetProhibitedExtruderMovements(unsigned int, unsigned int)': RepRap.cpp.text._ZN6RepRap30GetProhibitedExtruderMovementsEjj+0x4e): warning: undefined reference to `Tool::ToolCanDrive(bool)' RepRap.cpp.text._ZN6RepRap30GetProhibitedExtruderMovementsEjj+0x6e): warning: undefined reference to `Tool::ToolCanDrive(bool)' ./src/RepRap.o: In function `RepRap::FlagTemperatureFault(signed char)': RepRap.cpp.text._ZN6RepRap20FlagTemperatureFaultEa+0x4): warning: undefined reference to `Tool::FlagTemperatureFault(signed char)' ./src/RepRap.o: In function `RepRap::ClearTemperatureFault(signed char)': RepRap.cpp.text._ZN6RepRap21ClearTemperatureFaultEa+0x18): warning: undefined reference to `Tool::ClearTemperatureFault(signed char)' c:/arduino-1.5.8/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libg.a(lib_a-sbrkr.o): In function `_sbrk_r': sbrkr.c.text._sbrk_r+0xc): warning: undefined reference to `_sbrk' collect2.exe: error: ld returned 1 exit status make: *** [RepRapFirmware.elf] Error 1
Re: Hlidskjalf, Dual CoreXY July 01, 2017 05:46PM |
Re: Hlidskjalf, Dual CoreXY July 01, 2017 09:55PM |
'Building target: RepRapFirmware' 'Invoking: Cross G++ Linker' arm-none-eabi-gcc -L"C:\Eclipse\Firmware\CoreNG\RADDS" -Os -Wl,--gc-sections -Wl,--fatal-warnings -mcpu=cortex-m3 -TC:\Eclipse\Firmware\CoreNG\variants\RADDS\linker_scripts\gcc\flash.ld -Wl,-Map,C:\Eclipse\Firmware\RepRapFirmware\RADDS/RepRapFirmware.map -o "RepRapFirmware" -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group ./src/Tools/Filament.o ./src/Tools/Tool.o ./src/Storage/FileStore.o ./src/Storage/MassStorage.o ./src/RADDS/Network.o ./src/Movement/Kinematics/CartesianKinematics.o ./src/Movement/Kinematics/CoreBaseKinematics.o ./src/Movement/Kinematics/CoreXYKinematics.o ./src/Movement/Kinematics/CoreXYUKinematics.o ./src/Movement/Kinematics/CoreXZKinematics.o ./src/Movement/Kinematics/Kinematics.o ./src/Movement/Kinematics/LinearDeltaKinematics.o ./src/Movement/Kinematics/ScaraKinematics.o ./src/Movement/BedProbing/Grid.o ./src/Movement/BedProbing/RandomProbePointSet.o ./src/Movement/DDA.o ./src/Movement/DriveMovement.o ./src/Movement/Move.o ./src/Libraries/sha1/sha1.o ./src/Libraries/Math/Isqrt.o ./src/Libraries/General/StringRef.o ./src/Libraries/Fatfs/ccsbcs.o ./src/Libraries/Fatfs/diskio.o ./src/Libraries/Fatfs/fattime_rtc.o ./src/Libraries/Fatfs/ff.o ./src/Heating/Sensors/CpuTemperatureSensor.o ./src/Heating/Sensors/CurrentLoopTemperatureSensor.o ./src/Heating/Sensors/RtdSensor31865.o ./src/Heating/Sensors/SpiTemperatureSensor.o ./src/Heating/Sensors/TemperatureSensor.o ./src/Heating/Sensors/Thermistor.o ./src/Heating/Sensors/ThermocoupleSensor31855.o ./src/Heating/Sensors/ThermocoupleSensor31856.o ./src/Heating/Sensors/TmcDriverTemperatureSensor.o ./src/Heating/FOPDT.o ./src/Heating/Heat.o ./src/Heating/Pid.o ./src/Heating/TemperatureError.o ./src/GCodes/GCodeBuffer.o ./src/GCodes/GCodeInput.o ./src/GCodes/GCodeMachineState.o ./src/GCodes/GCodeQueue.o ./src/GCodes/GCodes.o ./src/GCodes/GCodes2.o ./src/GCodes/RestorePoint.o ./src/Fan.o ./src/OutputMemory.o ./src/Platform.o ./src/PortControl.o ./src/PrintMonitor.o ./src/RepRap.o ./src/RepRapFirmware.o ./src/Roland.o ./src/Scanner.o -lCoreNG -Wl,--end-group -lm -gcc c:/arduino-1.5.8/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m\libg.a(lib_a-sbrkr.o): In function `_sbrk_r': sbrkr.c.text._sbrk_r+0xc): warning: undefined reference to `_sbrk' collect2.exe: error: ld returned 1 exit status make: *** [RepRapFirmware] Error 1
Re: Hlidskjalf, Dual CoreXY July 02, 2017 11:53AM |
Re: Hlidskjalf, Dual CoreXY July 02, 2017 01:42PM |
Re: Hlidskjalf, Dual CoreXY July 02, 2017 04:11PM |
Re: Hlidskjalf, Dual CoreXY July 02, 2017 09:08PM |
Re: Hlidskjalf, Dual CoreXY July 02, 2017 10:32PM |
Re: Hlidskjalf, Dual CoreXY July 03, 2017 02:41AM |
