How can I fix belt shifting?
Posted by MatthewHall
January 20, 2017 08:53PM
So I built a printer and am trying to fix the remaining issues I have. I am surprised by the excellent quality of the printer - when it works. The only problem I still have is that the belt skips while doing diagonals, curves, or corners (sometimes). Basically the belt shifts whenever there is a fast speed change. The belts slip on the GT2 pulleys, the rest of the printer is rock solid.
I attempted to fix this issue in two ways:
1. Changing the acceleration values in Marlin to a lower value. This worked a little bit: now it shifts less often, but is still unpredictable.
2. Tightening or loosening the belts. I thought that maybe the slack in the belts was causing them to skip, but that is not the case. When I make the belts rather tight, the pulleys skip even more. If I make them really loose, it does better for constant speed movements but not for accelerate/decelerate moves.
Part of me feels that the printer should be able to accelerate at standard Reprap speeds, but who knows...
Thanks!
Re: How can I fix belt shifting?
January 20, 2017 09:44PM
Where did you get your pulleys? A photo perhaps? Some pulleys have too little depth, which causes the belt to slip.
January 20, 2017 09:53PM
Assuming you've inspected and found no physical problems (binding, loose pulley grub screws, etc.), try printing slower or reduce acceleration and jerk. CoreXY machines can run really fast when printing the perimeters of test cubes because both motors are contributing torque to create movements that are parallel to the X and Y axes. As soon as it switches to infill at 45 or 135 degrees, only one motor has to move the entire mass of the X and Y axes. The available torque is instantly cut in half and it can't run at the same speed.
January 20, 2017 10:47PM
Drive pulley may be too small.
Recommended minimum pulley size for GT2 belts is 40 teeth, and a minimum engagement of 9 teeth.
About the only way round this is use wider belts, or create more wrap on the drive pulley by adding an idler so the belt wraps the drive pulley by more than 180 degrees.
Guessing you have a CoreXY, as this is the CoreXY sub forum.
DD is right about the 45/135 move. Only one motor will be active, while the mass will be the Y (Y gantry+X-Carriage) plus the mass of the X-Carriage. 2 degrees of freedom, two contributing masses.
January 21, 2017 07:17AM
To the OP: if the belt is physically slipping it is not tight enough and the cure is obvious. It is far more likely that the motor is slipping due to a combo of excessively high acceleration/jerk/speed and/or too high or too low current. What are the settings you're using? Photos of the machine might help.
Prot0typ1cal: 40 teeth is the recommended (by SDP/SI) minimum equivalent diameter (about 25 mm) for a smooth pulley with belt teeth riding against it, not the drive pulley diameter. 16 and 20 tooth drive pulleys are common and fine with GT2 belt assuming the typical 180 degree wrap in a CoreXY printer. Using larger drive pulleys increases drive speed, reduces resolution, and reduces available force to move the mechanism. The width of the belt doesn't change the pulley diameter recommendation.
January 21, 2017 08:43AM
the_digital_dentist
You spoke of jerk. I changed the acceleration settings but never changed the jerk. Could you explain jerk to me?
January 21, 2017 10:35AM
Jerk is the allowable speed for "instantaneous" direction change. When the extruder is coming into a corner, the speed is decelerating. It will decelerate to the "jerk" speed and then try to change direction without coming to a complete stop. It's relying on the springiness of the belt and the motor torque to slam the extruder carriage around the corner. That is when layer shifting occurs if the jerk is set too high.
If you set jerk to zero, the extruder will come to a complete stop at every direction change and that will slow down printing. Curves are made up up short, straight segments and the extruder will crawl around curves. Jerk helps keep things moving along smoothly and quickly. You know it's is set too high when the motors start to skip steps which causes layer shifting.
Setting acceleration too high can cause layer shifting, as can setting speed too high. If the motor current is set too low or too high you can also have layer shifting.
See: [github.com]
Edited 1 time(s). Last edit at 01/21/2017 11:16AM by the_digital_dentist.
January 22, 2017 12:12AM
the_digital_dentist
Agreed. Wider belts help transmit more torque (less slip), which seems be the case here.
Thanks about the suggestion on lowering Jerk settings, something I'm not familiar with.
January 22, 2017 01:42PM
the_digital_dentist
See: [github.com]
So I see two options to fix this: get pulleys with more teeth/larger radius or lower the jerk settings to near 0 and work my way faster from there.
Edit: print speeds are slow during debug phase, 30-60 mm/s
Edited 1 time(s). Last edit at 01/22/2017 07:22PM by MatthewHall.
January 22, 2017 02:02PM
No, larger diameter pulleys will make the problem worse. torque=force x distance Torque is fixed by the motor current. If you increase the distance from the edge of the belt to the center of the shaft (i..e use a larger pulley), the force gets smaller.
I don't believe you ever said what speed you're trying to print. Forget about going 300 mm/sec. Start at a reasonable 50mm/sec and work up from there. Try starting with jerk set to 5 mm/sec^3 and work up from there. Start with acceleration set to 500 and work up from there.
It takes longer to type these messages than it does to tweak the settings. Start tweaking!
January 22, 2017 07:12PM
Thanks! Good point about it taking longer (I've already tweaked lots, back to it)
January 22, 2017 10:16PM
Yeah so I tried everything you guys said but it didn't fix all the issues. The jerk settings helped, but the printer still shifts. It shifts less predicable now. Any help would be appreciated.
Printing today @20mm/s (painfully slow) on all features
January 22, 2017 11:41PM
Dude, at that speed it isn't torque trouble, it's something jammed or sticking.
January 23, 2017 06:41AM
Post pictures of the machine.
January 24, 2017 08:09AM
Will do tonight. Again, thanks for all the help.
January 25, 2017 01:06PM
January 25, 2017 03:40PM
I think your problem is that the belt only goes 90 degrees around the driven pulley, so too few teeth are in contact with the belt. All the other designs I have seen use about 180 degrees. Ignore that, I was looking at the idler pulleys.
Edited 2 time(s). Last edit at 01/25/2017 04:12PM by dc42.
January 25, 2017 04:04PM
In the second and third images, the belt does not appear to be parallel to the X axis. That is going to cause distorted prints.
In the fourth image, the motor looks much too small to be driving any but a tiny coreXY mechanism. That is probably why your motors are slipping.
January 25, 2017 04:49PM
Those smooth idlers look kinda small.
Not that it matters much, but the offset idlers on you're Y carriage will torque the linear guide blocks. If they're cheap Chinese blocks they'll ratchet some.
Regarding your belt path to the X-carriage:
Since the back lengths are at an angle, this will cause the belt to stretch/slacken during X moves. Basic trigonometry, or simpler, Pythagorean theorem. Twisting them makes it even worse.
Only one end of each belt is angled, that length is the hypotenuese. Add that to the other end of the other belt (which is straight) from the Y carriage idler to the X-carriage, the sum needs to be the same at all X positions.
One principle of the CoreXY is the belts stay a constant length in all XY coordinates where the X-carriage is moved, as referenced by this image from CoreXY.com:
Edited 2 time(s). Last edit at 01/25/2017 04:53PM by prot0typ1cal.
January 25, 2017 06:55PM
the_digital_dentist
So should I get new motors?
January 25, 2017 07:18PM
You should probably invest in higher torque motors. How big is the printer? What are the moving masses of the X and Y axes?
January 25, 2017 08:35PM
The printer is rather large (bed 10x11 inches theoretically) but the only part I've used is the middle few inches. The mass of the axes is pretty light, just a few 3d printed components, the rails (12mm versions) and a bowden E3D.
Don't know if that helps. Back to debugging in a day or two once I get time away from education...
Edit: so if my motors aren't weak enough then it won't have enough to move in diagonal moves! (that is where it struggles - straights seem OK). Can I fix this without buying new motors?
Edited 1 time(s). Last edit at 01/26/2017 07:37AM by MatthewHall.
January 27, 2017 04:08PM
Those motors don't look ideal, but may have enough torque to run your printer if you give them enough current and use only modest values of acceleration and jerk, assuming you don't have too much friction in the axes. When you want to increase acceleration and jerk, you may need longer motors to provide higher torque.
What is the rated current and torque of those motors, and what current are you running them at?
January 27, 2017 05:32PM
I had these two options:
[folgertech.com]
[folgertech.com]
...and I picked the cheaper one.
January 28, 2017 04:48AM
If you bought the 12V 0.4A motor, that's the problem. You need to use stepper motors with a voltage @ rated current well below the supply voltage you are using.
January 29, 2017 11:11AM
What do you mean exactly? Is 12 volts too high for the power supply (12 volt output)?
January 29, 2017 12:03PM
Stepper motor torque comes from current, that is why torque ratings are at a specified current. Motors have coils of wire that create magnetic fields. The greater the current, the stronger the field, the higher the torque. Coils of wire have two properties- resistance and inductance. current = voltage/resistance or voltage = current x resistance. That is the voltage spec you see on a motor and has nothing to do with driving the motor except that it provides an indication of the inductance. Stepper drivers operate by setting current to drive the motor. A low voltage motor has less inductance than a high voltage motor and behaves in a more ideal way than a high voltage motor for a given supply voltage. It is normal to operate steppers from supplies that are 10-20x the rated voltage of the motor. A 3V rated motor will maintain torque at higher speeds when operated from a 12V supply than a 12V motor rated for the same current/torque.
TLDR: you want low voltage motors for a 3D printer. 2-4V rated motors are typical. Currents of 1-2.5A are also typical for NEMA-17 size motors. Don't buy 12V or higher voltage motors unless you're going to drive them with high voltage drivers and power supplies.
For a given motor size (say NEMA-17 which specifies the width/height of the motor as 1.7 inches) and current rating, say 1.8A for example, the length of the motor is proportional to the torque.
The normal way to design a motor into any device is to match the motor's torque/speed curve to the required performance. In hobbyist 3D printing that's rarely done- people tend to buy whatever motors they see, and are cheap, and hope they'll work, like you did, or copy what someone else has demonstrated working in their similar printer.
In my relatively high moving mass XY stage, I used this motor: [www.omc-stepperonline.com] and it seems to be capable of driving the mechanism at more than 150mm/sec (though not fully tested yet). There are many similarly spec'd motors available from different vendors. Note that they do not specify motor voltage, but they do specify current and resistance. From those numbers the voltage rating for this motor would be 2.8V. I will be running it from a 24V power supply, about 8X the rated voltage. That's OK, it's normal, it's desireable. The motor driver will deliver the current the motor needs and not let it burn up.
January 29, 2017 01:12PM
Is there any way I can use the motors I have now or will I have to order new ones?
January 29, 2017 10:02PM
I'd fix your belt routing first. Go ahead and rapid through your XY limits. Let us know how that works.
Regarding bigger steppers,
Smaller steppers won't effect overall print speed by lowering the accel/decel rates, as much as having to limit print speeds because the belts are out of plane and twisted. Wacked belt routing is also going to limit your available/reliable print volume.
Let me explain. If you can accelerate slowly to 60-100mm/sec normal print speeds, your total print time will still be less than trying to accelerate fast to only 20-30mm/sec for the entire print.
Yea, it'd be nice to accelerate quickly, and print super fast. However, until you make a new carriage that clamps your belts so they are in plane, and straight out, don't spend money on larger steppers just yet.
Just my 2 cents.
January 30, 2017 01:13PM
prot0typ1cal
Just my 2 cents.
So I should rout the belts to where they are parallel on their way to the x carriage: you say that may fix the skipping problem? So bigger motors won't keep the thing from skipping...
