Newbie to CoreXY with DBOT build January 23, 2017 09:32AM |
Re: Newbie to CoreXY with DBOT build January 23, 2017 02:35PM |
prawnabie
300x200 D-bot with 4 Z gantries instead of 2 and some aluminium parts instead of printed. Do you mean 4 screws instead of 2? You might find that 4 is overkill. 3 is a good number, as 3 points define a plane and so you can actually level your bed with 3 (Firmware update incoming for the duetwifi where you can use 3 steppers to level it). Alternatively, you may find 2 well supported gantries/screws works just as well. Quality over quantity.
Duet Wifi running @ 24V
0.9 steppers on Z and XY - not sure about extruder as I'm not sure if I should go Bowden or Titan 0.9 stepper isn't really needed on the Z axis, you might find 1.8 with a good gear ratio to work better as it has a bit more power for the weight. 0.9 could well be adequate though.
Closed belt between 2 Z steppers to keep position when the machine is off. A closed belt between 2 motors will fight each other. You're better off using 1 motor with a closed loop belt to power x number of screws. (EDIT - or is it a belt providing linear motion to the bed??)
6mm MIC-6 aluminium bed with 300w 24v silicone heater Sounds decent. CoreXY is a good candidate for mains voltage beds as well using a relay. It's arguably overkill, but heating times less than 30 seconds to get to 120c and you're laughing.
600w 24v 25A PSU.
I am hopefully also going to enclose it aswell with Perspex/acrylic in the slots but not reasearched that yet!
Most of the parts are on order as I type so I will update the thread with photos/question etc ASAP!
Thanks,
Shaun
Re: Newbie to CoreXY with DBOT build January 23, 2017 03:22PM |
Re: Newbie to CoreXY with DBOT build January 24, 2017 02:45PM |
Re: Newbie to CoreXY with DBOT build January 24, 2017 03:35PM |
Re: Newbie to CoreXY with DBOT build January 24, 2017 04:39PM |
Re: Newbie to CoreXY with DBOT build January 25, 2017 04:29PM |
