Z Axis - Sliding Parallel Table
Posted by Mogal
Re: Z Axis - Sliding Parallel Table
December 15, 2018 03:04AM
I made some experiments with the 'parallel bar' cantilevered bed this summer, but focussed more on the cloverleaf-cable drive portion of the setup. One obvious lesson is, that the frame has to be sturdy, otherwise you can't tighten the cable enough.
I have plans to rebuild my CoreXY with the parallel bar at least, but 12 working-hours a day don't leave much room for tinkering...
February 11, 2019 11:09AM
Well, I have the printer up and running.
Works amazing! Accuracy is great!
Only complaint with it so far is the E3D extruder keeps plugging up.
About 4 times now, but it is easy to clear out.
I do like that the print bed is a lot more stable with the sliding knot. BUT, going with the dual
Z axis is still the way to go. I may upgrade in the future, but see no need to really.
When the power is turned off, the table does have a tendency to drop slowly.
Everything was printed in black PLA at 200c and 0.2mm layer heights except the eye pieces, they are 0.15mm.
Edited 1 time(s). Last edit at 02/11/2019 11:20AM by Mogal.
Custom all metal CoreXY
- Duet 2 Wifi w/ PanelDue 7i
- 330mm x 360mm x 500mm
- 750w Silicon heater
Custom Mendel90
(Backup printer - Old reliable!) - Sold
February 11, 2019 12:02PM
That looks pretty good!
Son of MegaMax 3D printer: [www.instructables.com]
