CoreXY Enclosure, frame, and tips Questions.
Posted by Qdeathstar
Re: CoreXY Enclosure, frame, and tips Questions.
April 24, 2017 05:34AM
Basically, any belt section that changes length during xy movement needs to be parallel to the movement direction
June 12, 2017 11:00PM
Hello,
My name is Sergio and I really need some help, like a lot of help.
I am currently building a Hypercube by Tech2c and I'm having a motion issue
when I hit the home button in pronterface none of my motors move, but that's not it
instead of moving the make this weird high pitched sound and my z-axis motor starts to move then stops.
I thought it was binding so, I took out the lead screw and it
still, does the same thing, also my x and y-axis don't move and make a high pitched
sound, I have a feeling that I'm not doing something right whether it be a Marlin Setting or
something else.
Someone Please Help I really need it
June 12, 2017 11:02PM
Have you programmed the steps/mm for each axis yet? If not the controller may be trying to drive the motors much too fast.
June 13, 2017 01:29AM
Some steppers don't follow the cable color standard. Then one coil tries to step clockwise and the other counterclockwise.
You can switch either of the coils to make a test. ( black/green OR red/blue )
