CORE XY Enclosure April 03, 2017 06:41PM |
Re: CORE XY Enclosure April 05, 2017 06:32PM |
Re: CORE XY Enclosure April 06, 2017 06:24AM |
Re: CORE XY Enclosure April 08, 2017 06:58AM |
Re: CORE XY Enclosure April 09, 2017 12:51AM |
Re: CORE XY Enclosure April 09, 2017 03:31AM |
RepRot
Thanks Origamb,
Looking at using one of theses 12v 60W heaters. Plan to use a 12VAC supply and use Marlin firmware by enabling another extruder (only using 1 at present) to control the enclosure temperature and hopefully display the temperature on my 4 x 16 LCD.
Been printing a few objects and the enclosure has been getting up to 40C after a short time.
What I need is something to get the temperature up a bit higher and quicker (about same time as it takes the heat bed to get up the temperature) and keep it stable.
60W is half of the rating of the print bed so hopefully it will do the job without being an overkill and should be easy to mount within my printer and I should have enough room to mount a small transformer to power it and a solid state relay.
Thanks for your help as it lead me to find this heater.
Cheers REPRAP.
Re: CORE XY Enclosure April 11, 2017 06:11PM |
Re: CORE XY Enclosure April 12, 2017 07:54AM |
Re: CORE XY Enclosure April 13, 2017 04:25AM |
Re: CORE XY Enclosure April 30, 2017 01:27PM |
Re: CORE XY Enclosure May 01, 2017 02:01AM |
Re: CORE XY Enclosure May 01, 2017 02:04AM |
Re: CORE XY Enclosure May 01, 2017 07:57AM |
Re: CORE XY Enclosure May 02, 2017 02:55AM |
Re: CORE XY Enclosure May 11, 2017 02:03AM |
Re: CORE XY Enclosure May 11, 2017 02:51AM |
if (code_seen('S')&(code_value()>0)) .....
Re: CORE XY Enclosure May 11, 2017 03:49AM |
Re: CORE XY Enclosure May 11, 2017 11:38AM |
Re: CORE XY Enclosure May 11, 2017 04:12PM |
