Core XY vs Hbot Build May 10, 2017 03:33AM |
Re: Core XY vs Hbot Build May 10, 2017 06:22AM |
Re: Core XY vs Hbot Build May 10, 2017 01:13PM |
Re: Core XY vs Hbot Build May 10, 2017 05:36PM |
Re: Core XY vs Hbot Build May 10, 2017 06:22PM |
Re: Core XY vs Hbot Build May 10, 2017 08:19PM |
Re: Core XY vs Hbot Build May 30, 2017 10:42AM |
Qdeathstar
Mr Numbers,
You are saying that for a given result, the coreXY costs less that an HBot. Doesn't that make the coreXY objectively better?
Re: Core XY vs Hbot Build May 30, 2017 11:48AM |
Re: Core XY vs Hbot Build May 30, 2017 01:36PM |
If your build uses genuine linear guide with two well spaced blocks per rail I think H-Bot is superior. A rule of thumb is that the blocks centers should be seperated by at least half of the distance between rails.
Re: Core XY vs Hbot Build May 30, 2017 03:28PM |
CoreXY is better for low cost builds, but if your build has no risk of racking then it has no advantages.
A coreXY build requires twice as many inside idlers, tensioners, and anchors in the belt path. Not a problem if you are using skate bearings and zip ties, but if you are doing it with double bearing toothed idlers etc it becomes very expensive.
I personally find the CoreXY layout to be quite inelegant and would rather add a few inches of linear rail (to prevent racking) than run two belts on different planes. If you plan on maintaining reasonable belt tension you can't really mount the idlers with screws and t-slot nuts either because they will tilt under load.
Re: Core XY vs Hbot Build May 31, 2017 05:25PM |
Re: Core XY vs Hbot Build June 12, 2017 12:11PM |
I wouldn't necessarily assume that just because a "commercial" company does it, that it is done better. They have to worry about price points and profit margins.
Re: Core XY vs Hbot Build June 13, 2017 04:37PM |
I can't provide any definitive answers since there are so many other choices that need to be made. My view is that too many people consider H-Bot to be an inferior predecessor to CoreXY. Both designs have their place.
Any system with a single block per rail is unquestionably better as a CoreXY. If you are running two blocks in an H-Bot, the cost of a few extra inches of rail is negligible, and rigidity is always welcome. The alternative is to mount four idlers at two different heights along the back of of a CoreXY.
If anything, the competitive and cost pressures of industry make them more likely to choose the optimal solution.
Re: Core XY vs Hbot Build June 15, 2017 12:06PM |
So why not build a coreXY with more than one block?
Re: Core XY vs Hbot Build June 15, 2017 01:16PM |
Re: Core XY vs Hbot Build June 15, 2017 01:18PM |
...The primary disadvantage of CoreXY is that it requires belts on two separate planes...
Re: Core XY vs Hbot Build June 15, 2017 04:43PM |
Re: Core XY vs Hbot Build June 15, 2017 05:53PM |
Re: Core XY vs Hbot Build June 15, 2017 09:21PM |
Re: Core XY vs Hbot Build June 17, 2017 01:24PM |
Re: Core XY vs Hbot Build June 17, 2017 05:08PM |
adam440
Can you make some kind of list about advantages and disadvantages of CoreXY, H-Bot and possibly other drive systems (like D-Bot) with hot-end moving in X/Y direction?
Re: Core XY vs Hbot Build June 18, 2017 02:15AM |
Re: Core XY vs Hbot Build June 18, 2017 02:56PM |
Re: Core XY vs Hbot Build June 18, 2017 04:45PM |
Re: Core XY vs Hbot Build June 19, 2017 07:41PM |
prot0typ1cal
For a moment, imagine what a dual carriage H-bot looks like, then compare it to as you stated "complexity to be almost universally undesirable". Thankfully, I live in a different universe, the CoreXY.
Re: Core XY vs Hbot Build June 19, 2017 10:40PM |
Re: Core XY vs Hbot Build June 20, 2017 01:50AM |
Re: Core XY vs Hbot Build June 20, 2017 11:12AM |
Re: Core XY vs Hbot Build June 21, 2017 01:56AM |
Re: Core XY vs Hbot Build July 21, 2017 02:34AM |
