Re: Core XY vs Hbot Build July 21, 2017 05:56PM |
sangthip
The question is that, is this rough sketch-up, CoreXY, is it possible and will it work
Re: Core XY vs Hbot Build July 21, 2017 11:13PM |
Re: Core XY vs Hbot Build July 22, 2017 01:20AM |
Re: Core XY vs Hbot Build July 22, 2017 03:12AM |
sangthip
I don't seem to be able to find a belt layout of the Markforgd, can you point me to a site that shows this.
Re: Core XY vs Hbot Build August 13, 2017 05:31AM |
Re: Core XY vs Hbot Build July 18, 2019 05:51PM |
Re: Core XY vs Hbot Build July 21, 2019 03:34AM |
Re: Core XY vs Hbot Build July 21, 2019 06:04AM |
Admin Registered: 11 years ago Posts: 3,096 |
piper3d
This is questionable as a single belt in coreXY will be about 4.8m in the same configuration.Quote
Peter Stoneham
In my opinion it is superior to the twisted belt core xy and is particularly suited to larger builds e.g. the belt length per 'H' in my build is 7.2m...
Re: Core XY vs Hbot Build July 21, 2019 08:58AM |
Re: Core XY vs Hbot Build July 21, 2019 05:25PM |
the_digital_dentist
I think it would be more reasonable to compare the stacked-belt dual H-bot to a stacked-belt corexy.
the_digital_dentist
How can an H-belt path be shorter than the belt path for a corexy that prints over the same area?
the_digital_dentist
How is it cheaper to use 4 motors than to use 2? You need 2 extra motors, cables, drive pulleys, motor mounts, and maybe two more drivers, too. What does that do to the size of the machine and the cost of the electronics?
the_digital_dentist
In a corexy machine, each belt passes over 5 pulleys including the drive pulley. In the dual H-bot I count 8 pulleys on each belt.
the_digital_dentist
I'm having trouble seeing the superiority of the dual h-bot design...
Re: Core XY vs Hbot Build July 21, 2019 05:31PM |
Ohmarinus
I'm building a large format pen plotter and am definitely going for CoreXY as belt length will be a big factor in how precise my drawings will be. More stretch = more artifacts. Especially visible in a pen plotter running superfast while drawing a thin line. A shorter belt also meant less mass to move and I'm willing to ditch as much weight as possible for gain in speed and precision. I haven't seen any better proposal other than having a corexy without the belt crossing.
Re: Core XY vs Hbot Build July 21, 2019 07:19PM |
Re: Core XY vs Hbot Build July 21, 2019 08:29PM |
the_digital_dentist
4 motors to move a pen seems excessive.
the_digital_dentist
What is "driven length"?
Re: Core XY vs Hbot Build July 21, 2019 08:30PM |
Length between the motor and carriage.Quote
the_digital_dentist
Re: Core XY vs Hbot Build July 21, 2019 09:08PM |
Re: Core XY vs Hbot Build October 16, 2019 05:56AM |
Re: Core XY vs Hbot Build October 16, 2019 10:50AM |
