Re: Hypercube xy distortion June 09, 2017 08:54PM |
Re: Hypercube xy distortion June 10, 2017 01:37AM |
Re: Hypercube xy distortion June 10, 2017 03:08AM |
mjoyce
Hello,
Sorry for the delay in responding, it's been a hectic week.
I really appreciate the comments and responses.
I have attached a top down picture of my printer, I hope it's useful.
The bottom of the photo, is the front of the printer, where the xy motors are.
That's where the distortion is.
Regards
Matt
Re: Hypercube xy distortion June 11, 2017 10:14AM |
Re: Hypercube xy distortion June 11, 2017 10:19AM |
Re: Hypercube xy distortion June 11, 2017 02:00PM |
Re: Hypercube xy distortion June 11, 2017 02:04PM |
mjoyce
Could you attached the image you marked-up, I can't see it.
Thanks for the detailed reply, I'll, respond more fully tomorrow.
Re: Hypercube xy distortion June 11, 2017 09:11PM |
Re: Hypercube xy distortion June 11, 2017 11:43PM |
lkcl
yes. okay, this is a classic mistake. here's highlighted in red where you'll need to ensure that the belts come off the idlers exactly at right-angles (at all four locations). the right-hand motor looks to be just about ok (but might not be - you'll have to check it carefully, it could be out by as little as 1mm), but the left one is out by a whopping 10mm at least (yellow arrow).
lkcl
now, the other thing: i notice you've copied a cantilevered bed design. those look like 8mm rods, which you should be aware are hopelessly inadequate for the job of supporting a 250mm span. you can check this easily by grabbing the front of the printbed and pushing it up and down. it should be possible to apply a tiny amount of pressure to achieve an alarming amount of "travel". also, you only have a single z lead screw, and you're using plastic pieces to hold the linear bearings. the combination of these two things means that the entire printbed will wobble about. for more details about this see [reprap.org]
lkcl
one other important thing to check: the belt parts that i've marked in red MUST be all at the exact same height. the other parts (not marked) are not so critical but you really should do an "offset" design (like the Fusebox - the belt arrangement in the Fusebox is its one really really good design aspect). on the right-hand belt i can see that the inner part of the belt is not straight: it "coils" so that about half-way along it faces UPWARDS. this tells me that there is the strong possibility that the right-hand motor's height is not properly alighned: either it is at an angle (not properly vertical) or the belt is not properly horizontal. a photo from the right side would confirm this suspicion.
lkcl
also: the 20x20 corner-pieces are hopelessly inadequate. you should source at least some 50x50 metal triangles (don't laugh: i use sheet steel 1.5mm corners that were designed for wood-working: they're cheap and amazingly strong). you'll also need to stiffen up all the other five faces: do not be tempted to miss one of them out. think of a cardboard box with its lid open: it's hopelessly structurally unsound. close the lid and it becomes amazingly strong. for more on this (including some video demonstrations) see [reprap.org]
lkcl
so... sorry to be the bearer of bad news! you have a lot of redesign work ahead of you. but... it's not all bad: sometimes you have to try things without consulting people first, in order to value their input and to know what they're talking about. if you hadn't started at all you would not have the experience to know what corrections needed to be made. you'll do ok
Re: Hypercube xy distortion June 12, 2017 06:43AM |
mjoyce
lkcl
I think the angle of the photo, has altered the perspective, the left side is not 10mm out.
Looking at the STL files, and taking some measurements.
The idler centre is 11.25mm from the square post.
The bearing used in the ilder are 10mm, so the belt would be 11.25-5= 6.25mm from the post.
The centre of the motor spindle is 12.5mm from the post, the gear diameter is 12mm.
So the belt at the front is 7.5mm from the post
Seems all I need to do is change the idler bracket to shift in 1.25mm.
lkcl
Well, to be fair, I'm just using the design from here : [www.thingiverse.com]
Some of your points have been raised in that community and the consensus is, it's fine.
lkcl
Thank you for sharing FuseBox, the xyjoiner on that design looks really elegant.
lkcl
All faces have 4 corner brackets. They are metal, and as you correctly identified, 20mm. It seem pretty solid to me, but I can see how bigger brackets would be better, but perhaps not noticeably in this situation.
lkcl
Not at all, you're clearly knowledgeable about these things, and you've taken the time to share information and concepts.
I did not have a proper understanding about the mechanics, and frankly it seems a bit obvious not that you point out the relationship between the belts and the y axis.
thank you
but do those photos ok! they're important to double-check before you go ahead, make sure we're absolutely talking about the same thing(s).
if i document things, that stops *me* from forgetting. it also means that other people benefit, and that in turn helps me.
Re: Hypercube xy distortion June 12, 2017 07:37AM |
Re: Hypercube xy distortion June 12, 2017 10:17AM |
the_digital_dentist
If "the community" says the belts don't need to be parallel to the guides rails, "the community" is wrong. It isn't difficult to find HUGE examples of how wrong communities can be. Turn on the news- at any given moment the top story is liable to be an example of how wrong "the community" has been. Unfortunately for those of us who are able to learn from our own and others' mistakes, "the community" that can't seems to get larger every day.
Re: Hypercube xy distortion June 12, 2017 10:40AM |
Re: Hypercube xy distortion June 12, 2017 10:59AM |
Re: Hypercube xy distortion June 12, 2017 01:03PM |
Re: Hypercube xy distortion June 12, 2017 10:39PM |
tgmorris99
As an exercise I lined up the various parts (motor mount, idler, XY Joiner, belt, pulleys) for the left motor in 123D and the belt path at the XY joiner *should* be well under 1mm tolerance. Assuming I lined everything up correctly the belt path from the motor pulley to the idler pulley looks to be out by 1mm or so.
Re: Hypercube xy distortion June 12, 2017 11:03PM |
Re: Hypercube xy distortion June 13, 2017 06:52AM |
Re: Hypercube xy distortion June 13, 2017 07:54AM |
the_digital_dentist
"Well, to be fair, I'm just using the design from here : [www.thingiverse.com]
Some of your points have been raised in that community and the consensus is, it's fine."
Well, you wouldn't want to go against something that "the community" has decided is OK, would you?
When you start digging into machine design and performance you'll find that what "the community" considers acceptable is often terrible, and even dead wrong. Look at the four screw bed leveling error that has been around for years and shows no signs of ever going away. Any idiot who didn't sleep through the first week of highschool geometry can tell you that 3 points define a plane, not 4. So why are there 4 screws? "Duh, I dunno... the bed has 4 corners?"
If "the community" says the belts don't need to be parallel to the guides rails, "the community" is wrong. It isn't difficult to find HUGE examples of how wrong communities can be. Turn on the news- at any given moment the top story is liable to be an example of how wrong "the community" (a different one) has been. Unfortunately for those of us who are able to learn from our own and others' mistakes, "the community" that can't seems to get larger every day.
Re: Hypercube xy distortion June 13, 2017 08:57AM |
Re: Hypercube xy distortion June 13, 2017 09:22AM |
Re: Hypercube xy distortion June 13, 2017 09:40AM |
Re: Hypercube xy distortion June 13, 2017 10:44AM |
Re: Hypercube xy distortion December 15, 2023 08:42AM |
