Building a custom CoreXY July 02, 2017 12:12PM |
Re: Building a custom CoreXY July 02, 2017 05:02PM |
Re: Building a custom CoreXY July 02, 2017 05:35PM |
Re: Building a custom CoreXY July 02, 2017 11:07PM |
Re: Building a custom CoreXY July 03, 2017 01:43AM |
Re: Building a custom CoreXY July 03, 2017 08:12AM |
Lykle
Good points Origamib,
I looked at how I could lower the filament as well, but in the end it needs to be vertical by the time it enters that hot end.
Using an Aero style hot end will lower that point, but the issue remains.
(btw, I found old PLA to be the most brittle filament, you know anything more brittle?)
And as to the print area, yes, it all depends on how the drive cable and other wires are routed. So, again, agree.
The main thing is that it gives a choice, it is simply another option for an extruder that might work for somebody. That the ultimate usefulness is limited, I have no doubt, it might just be the perfect fit for Outcast. We will see.
But oh, it was such fun to design it and get a working model out so fast!
Re: Building a custom CoreXY July 03, 2017 03:03PM |
OutcastZeroOne
custom made Zesty Nimble extruder
Re: Building a custom CoreXY July 03, 2017 05:35PM |
Re: Building a custom CoreXY July 04, 2017 01:44AM |
Re: Building a custom CoreXY July 04, 2017 10:52AM |
Re: Building a custom CoreXY July 04, 2017 11:54AM |
lkcl
here's the thing: zesty is extremely short on technical specs. they go into a lot of promotional aspects about how clever the shape is, but make absolutely no mention whatsoever about really critical things like the materials specification of the gears and the flexible driveshaft. i also note that there appears to be no outer casing on the flexible shaft (no closeup photos so it's hard to tell). this has me concerned.Quote
OutcastZeroOne
so whilst i know that the flexible drive concept is a huge leap over both bowden and direct drive, zesty's lack of critical information should prompt you to be asking questions before committing to their products. if it was a properly open design there would be no problem. you could analyse the design and parts.
Re: Building a custom CoreXY July 04, 2017 12:13PM |
Re: Building a custom CoreXY July 05, 2017 09:59PM |
Re: Building a custom CoreXY July 05, 2017 10:43PM |
Re: Building a custom CoreXY July 06, 2017 07:12AM |
Re: Building a custom CoreXY July 06, 2017 03:25PM |
Re: Building a custom CoreXY July 08, 2017 06:57AM |
Lykle
Hi guys,
@lkcl Thanks for the compliment. Worked hard to get it compact.
Just a quick mention of a couple of facts.
We have published the POM used in the gears, can't find it now but will get back to you on that. Was back in the Kickstarter days.
Everything in the Nimble is designed by me, working with Brian. The only off the shelf components are the bearings and the nuts and bolts. The hob, the gears, the shell, it is all my own work.
Re: Building a custom CoreXY July 08, 2017 07:12AM |
Re: Building a custom CoreXY July 08, 2017 07:19AM |
Qdeathstar
I don't think anyone is calling you an idiot.... you are too sensitive. What i saw was someone asking questions and giving you something to consider. Wood expands when it is heated and warps over time...
Re: Building a custom CoreXY July 09, 2017 02:35AM |
Lykle
All the design files for the adapters, adapter bases and groove mount adapter are freely available.
Re: Building a custom CoreXY July 09, 2017 02:41AM |
Re: Building a custom CoreXY July 09, 2017 02:55AM |
Lykle
Thingiverse does not allow open license. We picked the least restrictive one.
Re: Building a custom CoreXY July 09, 2017 03:20AM |
Re: Building a custom CoreXY July 09, 2017 03:58AM |
Lykle
We will, in time. Brian is one of the main contributors to Drupal, so we certainly know the value of Open Source.
Re: Building a custom CoreXY July 09, 2017 01:04PM |
Re: Building a custom CoreXY July 09, 2017 04:53PM |
Re: Building a custom CoreXY July 09, 2017 05:24PM |
chris33
i think you all out of order trying to guess what mutley used for his gears im sure that does infringe anything they have set up between them with the license agreement, please could you stop using mutleys gears into any comparison to the zesty nimbles please as they not the same
Re: Building a custom CoreXY July 09, 2017 06:39PM |
Re: Building a custom CoreXY July 09, 2017 06:55PM |
