True bed levelling using multiple Z leadscrews July 18, 2017 02:27PM |
Re: True bed levelling using multiple Z leadscrews July 19, 2017 09:38AM |
Re: True bed levelling using multiple Z leadscrews July 19, 2017 12:30PM |
Re: True bed levelling using multiple Z leadscrews July 19, 2017 03:03PM |
badrobit
Could this also work for a belt based z-axis? something like one belt on each side of the bed?
Re: True bed levelling using multiple Z leadscrews July 19, 2017 03:09PM |
Origamib
Will be interesting to see if anyone goes to the expense of 4 screws just to utilise this feature on a terrible bed! To be honest, the expense of even the 2 motor set up is quite high given you also need an expansion board.
Even so, this is a great option to have and I can see it having a lot of value in industrial spec printers. Great job.
Re: True bed levelling using multiple Z leadscrews July 19, 2017 05:43PM |
dc42
Origamib
Thanks! A Duet 085, Duet Wifi or Duet Ethernet has 5 stepper outputs, so in a single extrusion printer you have 1 spare for the second Z motor without needing an expansion board
I don't normally advise using 4 leadscrews, because (as DD is fond of pointing out), 3 points define a plane. However, I have seen a very large printer that utilised 4 leadscrews and a steel bed frame about 30mm thick, and it had sufficient flexibility that adjusting all 4 leadscrews independently made sense. So I don't discount the notion that 4 independent leadscrews may make sense in some situations. Also we have customers that want to drive 4 leadscrews independently. The maths for 4 leadscrews is complicated (see [github.com] line 131 onwards), but on an ARM processor it takes only a fraction of a second.
