True bed levelling using multiple Z leadscrews
Posted by dc42
July 18, 2017 02:27PM
Of possible interest to CoreXY printer builders is that the latest release of RepRapFirmware supports bed levelling using 2, 3 or (if you insist) 4 Z leadscrew motors driven from individual stepper drivers. The procedure is described at [duet3d.com]. It uses a least-squares algorithm similar to our famous delta printer auto calibration algorithm.
When multiple motors are used to drive the Z axis it is not uncommon for them to lose sync when the printer is powered off and on again. This feature provides automatic resynchronization.
We had expected to be the first firmware to support bed levelling using multiple leadscrews, but Repetier beat us to it.
Re: True bed levelling using multiple Z leadscrews
July 19, 2017 09:38AM
Could this also work for a belt based z-axis? something like one belt on each side of the bed?
July 19, 2017 12:30PM
Will be interesting to see if anyone goes to the expense of 4 screws just to utilise this feature on a terrible bed! To be honest, the expense of even the 2 motor set up is quite high given you also need an expansion board.
Even so, this is a great option to have and I can see it having a lot of value in industrial spec printers. Great job.
July 19, 2017 03:03PM
badrobit
Yes, that should work too.
July 19, 2017 03:09PM
Origamib
Thanks! A Duet 085, Duet Wifi or Duet Ethernet has 5 stepper outputs, so in a single extrusion printer you have 1 spare for the second Z motor without needing an expansion board
I don't normally advise using 4 leadscrews, because (as DD is fond of pointing out), 3 points define a plane. However, I have seen a very large printer that utilised 4 leadscrews and a steel bed frame about 30mm thick, and it had sufficient flexibility that adjusting all 4 leadscrews independently made sense. So I don't discount the notion that 4 independent leadscrews may make sense in some situations. Also we have customers that want to drive 4 leadscrews independently. The maths for 4 leadscrews is complicated (see [github.com] line 131 onwards), but on an ARM processor it takes only a fraction of a second.
Edited 3 time(s). Last edit at 07/19/2017 03:13PM by dc42.
July 19, 2017 05:43PM
dc42
Origamib
Yes that's a good point on the 2 Z motor set up, I'm thinking of my own printer at the moment with 2 extruders and making assumptions!
