Some quick questions regarding idler pulleys September 19, 2017 05:08AM |
Re: Some quick questions regarding idler pulleys September 19, 2017 09:12AM |
Re: Some quick questions regarding idler pulleys September 19, 2017 02:10PM |
Listen to the good dentist. He speaks the truth.Quote
the_digital_dentist
The problem with any of those pulleys is that the bearings they use are small and the bore is very small. You can't just stand those bearings on a screw because the belt tension will make the screw flex and then you'll have alignment problems with the belts. You have to support the screw's top and bottom in order to use those pulleys.
Re: Some quick questions regarding idler pulleys September 19, 2017 03:03PM |
Re: Some quick questions regarding idler pulleys September 22, 2017 05:11AM |
