Newbie looking for some setup guidance...
Posted by ampapa
Re: Newbie looking for some setup guidance...
November 28, 2017 08:09AM
Most people use a Z probe to establish where Z=0 is prior to printing. A few people don't use a Z probe, but have a Z min endstop switch (i.e. a switch that triggers when the nozzle is close to touching the bed). If you only use a Z max endstop switch, I suspect you may have a problem with differential thermal expansion of your frame (probably aluminium) and your leadscrews (some type of steel), which will change the number of motor steps you need to go from endstop triggered at max Z to Z=0.
Edited 1 time(s). Last edit at 11/28/2017 08:10AM by dc42.
November 28, 2017 02:15PM
Bare with me as I try to understand fully... So, currently I have 1 switch at the top of the Z axis. In this scenario, when I home the machine the switch is below the hot end and the Z axis is essentially set to Zero when it touches the switch.
If I move the switch to be above the hot end obviously the hot end will bury into the bed before it zero's.
So, I see 2 options then for homing the Z axis to the hot end.
- move the switch in accordance with the hot end so that the hot end just touches the bed and then lock the switch in to place.
- use a Z probe on the hot end
If that is the case, if using a Z probe, what is the purpose of the Z end stop at the top of the Z axis as shown in the image below on the left?
Using a Z Probe on the hot end I would think is the only solution?
November 28, 2017 05:43PM
You can set up a Z min homing switch so that it triggers when the nozzle is close to the bed but not touching (e.g. 1mm off) and configure the firmware to know what the height is when the switch is triggered. But many people use just a Z probe, and no Z homing switches at all.
November 28, 2017 08:55PM
Anyone have suggestions for a compatible probe for the Duet?
I was looking at either, LJ18A3-8-Z/BX or LJ12A3-4-Z-BX...
Edited 1 time(s). Last edit at 11/28/2017 09:05PM by ampapa.
November 29, 2017 02:49AM
ampapa
See [duet3d.com] and [duet3d.com].
November 29, 2017 09:15PM
After looking at the list on the Duet page I'm really leaning towards the piezo design.. can anyone speak to its performance and accuracy?
ampapa,
December 09, 2017 03:31PM
Making some progress today but having some problems zeroing my Z axis... my Z axis hits the end stop and reverses direction but never attempts to touch off the end stop a second time?
Original
G91                ; Relative positioning
G1 Z350 S1 F300   ; Move Z down until the switch triggers
G1 Z-2.5 F150
G1 Z10 S1 F150   ; Move Z down until the switch triggers
G90                ; Back to absolute positioning
G92 Z10           ; Tell the firmware where we are
Shouldn't it go 350+ then 2.5- then 10+?
ampapa,
December 09, 2017 04:22PM
You told it to drop 350 from whatever the starting point or until it hit the switch, then go up 2.5, then drop 10, or hit the switch. Then you're telling it the absolute coordinate is Z=10, but it seems to me it's going to leave the bed near the bottom of the Z axis.
Is there some reason you don't put the switch at Z=0 and then just use a normal homing command to zero the bed?
The firmware should be set to turn the motor toward the home switch when a home command is executed. Then, when the switch is triggered, you set the Z ordinate- Z=0 if the home switch is at the physical top of the Z axis near the extruder, or Z=300 or 350 or whatever it is if the switch is near the bottom of the Z axis.
The "normal" way to set up a switch for that is to bolt the switch to the printer's frame and have a screw on the bed/moving assembly that bumps the switch. Fine adjustments to the Z=0 position are made by turning the screw.
Here's an example from a Taz printer - the screw moves up and down with the X axis and bumps a switch that is mounted on the printer's frame. Turning the screw sets the Z=0 position. Part of what makes this a poor design is that one turn of the screw moves the nozzle 700 um (0.7 mm pitch screw), so fine adjustments can be tricky:
Here's the Z=0 switch on my CoreXY printer:
UMMD Z=0 switch
In this design, the cam bumps the switch that is bolted to the frame. The cam moves up and down with the bed, and allows for very fine adjustment of the Z=0 position (1 turn of the screw moves the Z=0 point by about 100 um).
You could mount the switch on the moving part, such as the bed or even on the extruder carriage, but then you have to run wires to a moving part and deal with the complications that frequent flexing may create. The switch is usually mounted on the frame so the wiring doesn't have to move. If you don't want the Z=0 switch to actually put the bed at the nozzle for fear of damage, offset it a few mm and then use a Z offset in your slicer or in the firmware. Triggering the switch close to the extruder in Z is more precise than triggering it at the physical bottom of the Z axis and then moving the bed up to the nozzle by 300 mm or so. It's also quieter and much faster than running the bed down and up at the start of every print, and reduces mechanical wear on the Z axis components.
My printer has a Zmax switch as well as a Z=0 switch. The Zmax switch is there to protect against driving the Z axis too far- the drive has a lot of torque and it may do some damage if the Z axis attempts to keep moving beyond the physical bottom of the machine. The Zmax switch stops the motion about 0.5 mm above the green TPU bumper.
Edited 6 time(s). Last edit at 12/09/2017 04:45PM by the_digital_dentist.
December 09, 2017 07:22PM
the_digital_dentist
My current Z axis home switch is located at the top of the axis so that should be Z=0 for me if I'm not mistaken.
When running the command G1 Z350 S1 F300 what happens when it hits the switch, should it just stop? If I took all the other commands out is that what would happen?
G1 Z350 S1 F300   ; Move Z up until the switch triggers
Slightly modified...
G1 Z-2.5 F150        ; Move Z down towards the table/bottom
G1 Z10 S1 F150     ; Move Z up until the switch triggers
G92 Z0                   ; Tell the firmware where we are. Will this effectively set my Zmax?
I also realize that this is not the hot end Z0 that has to be accomplished by an offset of some type...
ampapa.
December 10, 2017 12:26AM
Z=0 is/should be at/near the physical top of the Z axis, at the level of the extruder nozzle. Z=350 should be at/near the physical bottom of the Z axis. G1 Z 350 should send the bed downward, not upward. That means it will go away from the switch if the switch is at/near the top of the Z axis.
Why aren't you using a G28 command? The G28 command will send the bed toward the switch (if you have set the motor rotation correctly), then, when it bumps the switch, it will back off a few mm and slowly go up to hit the switch again and stop. You don't have to manually write that behavior using multiple G code commands, it's part of the G28 execution.
The first step in setting up the machine is to set the motor rotation directions so that a G28 command sends the extruder and bed toward the limit switches. The limit switches define specific, absolute coordinates, usually, (0,0,0), unless you tell the controller otherwise. G28 XYZ or just G28 should send all three axes toward the limit switches. G28 Z will home just the Z axis. If you send G28 Z and the bed moves away from the switch, the motor is turning the wrong direction. You can reverse the rotation direction of the Z axis motor by reversing the connector (kill the power before unplugging the motor!) or by inverting the direction signal to the Z axis driver in the firmware configuration.
Maybe it would help if you post a photo of the machine and point out the location of the switch, and the thing that bumps the switch.
Take a look at this and see if it helps.
Edited 3 time(s). Last edit at 12/10/2017 01:00AM by the_digital_dentist.
December 10, 2017 02:43AM
DD is right, your homing orientation is the wrong way round. You have to change signs of the moves and probably also revers the z-stepper direction.
z-350
z2.5
z-10
December 10, 2017 05:58AM
the_digital_dentist
The OP is using Duet electronics so G28 simply calls a macro. The macro contains the specific G code commands. G28 with no parameters will call the homeall.g macro. G 28 with an X,Y,Z (any other axis) parameter will run the associated macro i,.e homex.g, homey.g homez.g etc. The default macros usually work well but you can edit them. I think the OP is doing just that.
The Duet board will work with CoreXY, Cartesian, Scara, Polar, Idex etc, and the homing command will always be G28 but the behaviour will necessarily differ depending on the machine kinematics. Hence the use of (editable) macros which contain the specific gcode commands for any machine configuration.
December 10, 2017 08:06AM
Here is the location of the Z switch..
Why is the Z axis backwards from a CNC
I guess I should have paid more attention to the following, my Z axis is backwards.. no wonder why I'm having homing problems.
So, looking at the CoreXY from the front (Z stop back right) home or 0,0,0 will be front left with the bed at the top.
When beginning a print do you always start from 0,0,0 or start in the middle of the build plate like 150,150,0?
open | download - SNAG-0115.jpg (84.5 KB)
December 10, 2017 08:52AM
Z-0 is when the nozzle is just touching the bed. If the bed moves in the Z axis, that is when the bed is at the top of its travel. If the bed doesn't move in the Z axis but the gantry does, that is when the gantry is at the bottom of its travel. So whether Z=0 is when the moving part of the Z axis is at the top or the bottom of its travel depends on which is moving, the bed or the gantry.
HTH David
December 10, 2017 09:20AM
As the bed is lowered during a print, the nozzle deposits plastic higher on the model being printed. That's why Z + is downward in a printer with the bed being lowered in Z. In machines that lift the X axis, including the extruder carriage, Z + is upward. As the nozzle moves upward, it deposits plastic higher on the model being printed.
I saw this posted earlier, so initially I thought he had it figured out,
but the problem description and the picture didn't match.
December 10, 2017 09:26AM
That got me sorted out, thanks guys.
I guess since a 3D printer deposits material and CNC removes material maybe that's the reason for the difference.
On to setting up the extruder and maybe printing something today..
ampapa,
December 10, 2017 10:55AM
When configuring the extruder and measuring the filament output is it necessary for the printer to be at operating temperature?
Can this be done "offline"?
I guess the real question is should this be done through the hot end as I was going to take measurements with the PTFE tube out of the hot end...
Edited 2 time(s). Last edit at 12/10/2017 06:28PM by ampapa.
December 10, 2017 12:47PM
If you are just testing the extruder and not trying to force filament through the nozzle, you can send M302 P1 to enable cold extrusion.
