It's Begun
November 16, 2017 04:50PM
So in the Engineering Block Program at my high school my friend and I are building a larger CoreXY printer. Here's the first picture.
Like a Tank [imgur.com]
All I can say is that Aluminum Extrusion is a tank. This frame weighs 30 lbs right now, which is honestly lighter than I expected. Let me know if there's any major problems you see with the design.
Re: It's Begun
November 16, 2017 11:43PM
It's definitely over-built- I don't think you need any of the corner braces or associated hardware, but hey, there's no kill like overkill.
Re: It's Begun
November 17, 2017 03:07AM
You could add some brackets in the bottom horizontal plane. It has to be perfect 90°.
Re: It's Begun
November 17, 2017 08:41AM
the_digital_dentist
Yeah overkill was kind of the plan. We hit the jackpot, all of this material was in the shop already. We haven't bought a single part yet.
Re: It's Begun
May 04, 2018 02:49PM
UPDATE:
Printer is complete!
Take a look here
Any questions?
Re: It's Begun
May 04, 2018 10:51PM
Deets?
Re: It's Begun
May 05, 2018 03:17AM
What wrong in that picture? winking smiley
Re: It's Begun
May 05, 2018 04:06PM
o_lampe
[attachment 104776 cable_guide.JPG]
Probably a lot but notably the filament tube bends around the belt.
Re: It's Begun
May 05, 2018 04:11PM
the_digital_dentist
Deets?
Yeah I probably should have said some stuff earlier.
Basically it's a CoreXY system with a belt driven Z Axis. Uses RAMPS 1.4 and a Full Graphic Display. Goals were extremely sturdy and reliable. I think the sturdy part has been achieved.
Entire system is enclosed, as it will stay in the school environment for hopefully a long while after I graduate.
This was a school project in my engineering block class.
Edited 1 time(s). Last edit at 05/05/2018 04:11PM by MatthewHall.
Re: It's Begun
May 06, 2018 03:23AM
MatthewHall
o_lampe
I meant the wires guided through sheer metal. Better use a rubber grommet or some other insulation method.
Re: It's Begun
May 06, 2018 08:55AM
o_lampe
MatthewHall
o_lampe
Oh yeah that could be a problem. We figured it'd be ok because it's aluminum and they are fixed tight so hey can't move. It's supposed to eliminate the stress on the connections to the extruder.
