The location of the Z endstop
Posted by flydeprutten
November 27, 2017 07:23AM
Hi every one.
I have a small question about z-endstops.
I know where to put my endstops for X and Y, but I do not know where to place Z. For me, it would be logical to place it at max (that's when my bed is completely down), but when I look online at other builds, I can see that they have placed them at minimum (ie when the bed is completely up and close to the extruder). However, I can not see how this can be done without the endstop getting in the way of autoleveling and the first couple of layers.
Will the Z endstop not be pressed down every time the bed moves up to the extruder, and is there not a risk that the endstop will be compressed excessively?
Re: The location of the Z endstop
November 27, 2017 07:34AM
Here are three options:
1. Z endstop at Z max. This is a popular choice. If your Z axis is slow, this can slow down things a little, because of the need to move from Z=max to near Z=0 at the start of a print.
2. Z endstop at or close to Z min. In this case the endstop arrangement should be designed so that the bed can move a little past the endstop trigger position without damaging the switch; or else you must have solid mechanical endstops to prevent the bed moving significantly past the trigger position.
3. No endstops. Use the Z probe for homing. I've read that Smoothieware doesn't support this, but all other firmwares do AFAIK.
HTH David
Edited 2 time(s). Last edit at 11/27/2017 08:44AM by dc42.
Delta printer calibration calculator, mini IR Z probe, and colour touch screen control panel: [escher3d.com]
Large delta printer, and other 3D printer blog postings: [miscsolutions.wordpress.com]
Disclosure: I have a financial interest in sales of the Panel Due, Mini IR height sensor, and Duet WiFi/Duet Ethernet.
November 27, 2017 07:47AM
Ahh, of course I can use my z-probe. It's already right there. thank you. smiling smiley
